240ZBUILTBYME Posted November 6, 2020 Author Posted November 6, 2020 So finally finished the teardown! Thank god. Now comes the hard part.... check out the blu tack repairs. Classic stitch up... Ryan Quote
240ZBUILTBYME Posted November 11, 2020 Author Posted November 11, 2020 (edited) Received some goodies in the mail... really glad I was able to support an Australian supplier instead of send money to the US. Thanks Lurch I have to say quality is fantastic. Fitment is unknown but I am highly confident they will fit well. Two questions for the maestro of metal @C.A.F. 1. What is this cut out for? Is it the tie rod brackets? I was trying to look through my photos to work it out but didn’t have a underside shot of my rails. 2. I won’t be installing these for a while, do you recommend I chuck some easyphos or something for protection in the meantime? ryan Edited November 29, 2020 by 240ZBUILTBYME AndBir and CBR Jeff 2 Quote
C.A.R. Posted November 11, 2020 Posted November 11, 2020 That notch will need to be cut back to match the inner skirt. It'll become clear when you offer it up into position. If you are not installing them soon, a coat of silver gal or cold gal is advisable. Also before you install them, paint the inside with KBS/POR15/Rust Bullet. Quote
240ZBUILTBYME Posted November 11, 2020 Author Posted November 11, 2020 2 hours ago, C.A.F. said: That notch will need to be cut back to match the inner skirt. It'll become clear when you offer it up into position. If you are not installing them soon, a coat of silver gal or cold gal is advisable. Also before you install them, paint the inside with KBS/POR15/Rust Bullet. Ok no worries yep was planning on a inner coat of kbs, no worries I’ll throw some gal down. Cheers Lurch Quote
240ZBUILTBYME Posted November 28, 2020 Author Posted November 28, 2020 Front diff carrier frame all welded up and bolted in place... one more to go! Quote
240ZBUILTBYME Posted November 28, 2020 Author Posted November 28, 2020 Angle welded onto the front cross member frame, holes drilled and bolted up into place Quote
240ZBUILTBYME Posted November 30, 2020 Author Posted November 30, 2020 In this one I removed the hatch glass and started breaking down the rear suspension. Hopefully the last dismantle video for a while... Ryan Dragonball240z 1 Quote
C.A.R. Posted November 30, 2020 Posted November 30, 2020 I hope you bagged and tagged where all the specific rear suspension bolts went... Quote
240ZBUILTBYME Posted November 30, 2020 Author Posted November 30, 2020 44 minutes ago, C.A.F. said: I hope you bagged and tagged where all the specific rear suspension bolts went... What bolts?..... haha of course I did, I think there’s some footage of the bagging and tagging. I’ve been pretty meticulous about that stuff Quote
240ZBUILTBYME Posted December 2, 2020 Author Posted December 2, 2020 So I’ve decided to start doing some small parts restoration at home. As anyone who is following along knows, the car is not at my place but about 35-40 mins away. I only work on it once a fortnight, basically a day of my R&R. So to keep motivation and progress rolling I’m doing these mini projects. First Mini Project is... Quote
240ZBUILTBYME Posted December 2, 2020 Author Posted December 2, 2020 As you all know I’ve never done any of this before so I’m relying on you wise sages to correct my mistakes and give your worldly advice... I was thinking about doing one SU at a time just to have one to reference off when rebuilding but I’ve taken a lot of photos and feel confident I can put them back together using those. Let me know your thoughts. Planning to: -order a Ztherapy rebuild kit -vapour blast intake manifold, bodies and dome -replate hardware -new hoses let me know if I’ve missed anything critical few photos of dismantle on front SU Dragonball240z 1 Quote
240ZBUILTBYME Posted December 2, 2020 Author Posted December 2, 2020 Anybody got any advice on getting the needles out of the piston? They seem pretty stuck in there. The Ztherapy rebuild kit will have new needles but I’d rather not damage anything just in case. And before you ask yes the grub screw is out... Ryan Quote
Administrators gav240z Posted December 2, 2020 Administrators Posted December 2, 2020 Getting the needles out can be a pita. I was gonna check you removed the grub screw. Basically what's holding it in is a bunch of carbon build up (probably from the PCV being fed into the intake). You could try soak it in kerosene or use lots of carb cleaner on it and let it sit for a while. I butchered my needles getting them out (with pliers) because I ran out of patience. I kind of regret doing that too! Z-Therapy will give you new needles but the original L24 sized ones are hard to find now and generally the Z-therapy ones are SM needles which are a bit rich..from what I've seen. You won't regret getting Z-therapy rebuilds. I had a bunch (4 sets) done a while ago. I think I sold 2 sets and kept 2. Can get a little expensive. 240ZBUILTBYME 1 Quote
240ZBUILTBYME Posted December 2, 2020 Author Posted December 2, 2020 26 minutes ago, gav240z said: Getting the needles out can be a pita. I was gonna check you removed the grub screw. Basically what's holding it in is a bunch of carbon build up (probably from the PCV being fed into the intake). You could try soak it in kerosene or use lots of carb cleaner on it and let it sit for a while. I butchered my needles getting them out (with pliers) because I ran out of patience. I kind of regret doing that too! Z-Therapy will give you new needles but the original L24 sized ones are hard to find now and generally the Z-therapy ones are SM needles which are a bit rich..from what I've seen. You won't regret getting Z-therapy rebuilds. I had a bunch (4 sets) done a while ago. I think I sold 2 sets and kept 2. Can get a little expensive. Thanks gav! I’m not in too much of a rush with this as I just I’m just doing these mini projects when my 2 year old is napping. He loves waking up to find tools on the coffee table.... I’ll try the kerosene and carb cleaner soak and see what happens. I have read your SU rebuild thread over a few times so knew you had troubles too. Can I ask how much a restored set up retails for nowadays? Ball park figure? I’m still undecided on if I am running SUs or going straight to Weber’s, I think it will depend on if a decent second hand Weber set up comes available before the decision needs to be made (which will be a couple years away....) I’m not willing to buy new, cost is insane.... Ryan Quote
Administrators gav240z Posted December 2, 2020 Administrators Posted December 2, 2020 I can't recall the cost now for the Z-Therapy rebuilds. It wasn't cheap though. They should be able to quote you, but shipping there and back gets expensive. I bought a bunch of cores in the US and sent them direct that way. Problem is getting stung on import duties on the way back. Depends on what you want from the car, but I am a big fan of Triple Mikunis. Weber's tend to be a mixed bag based on when and where they were cast. Mikuni really improved the Solex design over the years.. but they are not cheap either (for good reason). https://www.hemmings.com/stories/article/mikuni Quote
240ZBUILTBYME Posted December 2, 2020 Author Posted December 2, 2020 44 minutes ago, gav240z said: I can't recall the cost now for the Z-Therapy rebuilds. It wasn't cheap though. They should be able to quote you, but shipping there and back gets expensive. I bought a bunch of cores in the US and sent them direct that way. Problem is getting stung on import duties on the way back. Depends on what you want from the car, but I am a big fan of Triple Mikunis. Weber's tend to be a mixed bag based on when and where they were cast. Mikuni really improved the Solex design over the years.. but they are not cheap either (for good reason). https://www.hemmings.com/stories/article/mikuni Ahhh sorry I meant I’m going to do the rebuild myself, using the Ztherapy DIY kit they supply. I know they do roller bearings etc but I’m not convinced it’s essential. You mentioned to me you thought the rebuild you did yourself was nicer than the Ztherapy rebuild you had done, so I’m going DIY. Will probably be half the price of sending them to Z therapy to do. As you say shipping and import duties are killer. What I meant was you said you sold a couple of pairs, how much does a rebuilt SU setup sell for these days? I have heard 1500-2000$ Unrestored but haven’t seen anything myself. Quote
240ZBUILTBYME Posted December 10, 2020 Author Posted December 10, 2020 Well sorry it’s taken time to get back to updating the needle sitcho. but this little thing has been keeping me busy, she arrived last week. But I did get round to trying to get the needles out, I decided to first try some rubber and some vice grips as it was the easiest to conjure. And long story short it worked! Just needed the grip of the rubber to apply enough torque to twist it free! The second needle came out by hand. One of the needles had N27 on it, the other had nothing. I believe these are 240z needles? Ryan gav240z, AndBir and Ponyo240z 3 Quote
C.A.R. Posted December 10, 2020 Posted December 10, 2020 Nice knowing you Ryan - see you in 20 years gav240z, ScottyD, 240ZBUILTBYME and 1 other 4 Quote
AndBir Posted December 10, 2020 Posted December 10, 2020 51 minutes ago, 240ZBUILTBYME said: this little thing has been keeping me busy, she arrived last week Congratulations, you will be busy on multiple fronts for many years 240ZBUILTBYME 1 Quote
240ZBUILTBYME Posted December 10, 2020 Author Posted December 10, 2020 @AndBir @C.A.F. thanks guys! Haha this is my second so I have risen from the grave before and I’ll do it again! gav240z 1 Quote
240ZBUILTBYME Posted December 10, 2020 Author Posted December 10, 2020 My Haynes service manual photos were terrible and unusable so I made these to remember how everything goes back together when I rebuild everything Maybe this might help someone at some point Ponyo240z 1 Quote
AndBir Posted December 10, 2020 Posted December 10, 2020 And (hopefully) by the time you have the car back on the road the WA Govt. may have in place their proposed classic car rego scheme (similar to that in NSW/Vic) : https://www.transport.wa.gov.au/licensing/concessions.asp Work has commenced on regulatory changes to introduce the Concessions for Classics scheme (C4C) – a voluntary conditional licensing scheme which will be available to eligible street rods and vehicles manufactured prior to 1990, including motorcycles. A vehicle licensed under the C4C scheme: can be used for a maximum of 90 days annually, being 60 days to participate in approved motoring club sanctioned events; and 30 days for personal use, testing, maintenance and repair. cannot be used for fee, hire or reward; and must display an approved plate or label stating ‘restricted use’, which is to be affixed to the top or bottom of the vehicle number plate(s) to identify that the vehicle has restricted road use. Vehicle owners who wish to apply for the C4C scheme will need to be a financial member of a DoT approved motoring. DoT approved motoring clubs will be required to maintain a record of vehicle use by their members for auditing and compliance with the scheme. Eligible vehicle owners who apply for the scheme will receive a 75% vehicle licence fee discount, along with a reduced motor injury insurance premium. COVID-19 has delayed the implementation of this initiative however DoT is continuing to progress the legislative changes and upgrading systems to support the Concessions for Classics scheme. Ponyo240z and 240ZBUILTBYME 2 Quote
Administrators gav240z Posted December 10, 2020 Administrators Posted December 10, 2020 Hey mate, Here are some SU reference photos for you.. https://photos.app.goo.gl/ewb1ZWYoF5QJH7ey2 240ZBUILTBYME 1 Quote
CroS13 Posted December 11, 2020 Posted December 11, 2020 Haha congrats on the little one mate!!! I was wondering when it would arrive because you mentioned on my thread you were due soon! I've started to get "some" time back in the shed now. My little one is pretty chill now (she is 3 months old next week) On weekends I can usually get up at the crack of dawn to give her a morning feed, put her back to bed and she will sleep for another 4 or 5 hours and that's when I'll sneak into the garage and get as much done as I can. Rudi. Quote
240ZBUILTBYME Posted December 12, 2020 Author Posted December 12, 2020 On 12/10/2020 at 4:33 PM, AndBir said: And (hopefully) by the time you have the car back on the road the WA Govt. may have in place their proposed classic car rego scheme (similar to that in NSW/Vic) : Yeah my mate sent me that not long ago, good scheme, makes owning a classic slightly more affordable! Quote
