  • 3 weeks later...
On 9/24/2020 at 11:15 PM, 240ZBUILTBYME said:
nice one Gary!
very delicious build so far wags, you must be so excited.
Really sucks not being anywhere near these amazing distinguished vendors, CAF, LCR, MCA etc
ryan
Thanks mate!
yes I am really excited. It’s in for paint now and the last of my huge new parts shipment is coming in. Very close now!
  • 3 weeks later...
Posted (edited)
Exciting times Jon. I’m guessing your not going to make the dyno run?
Jeff
Edited by CBR Jeff
Jeff
No mate, I’m on a deployment with work and also still can’t cross the border to Vic.
Posted (edited)
The dyno cells fuel supply pump failed, so a new one has been ordered, then it has to be fitted.
Engine won't be dyno'd until next week now.
Edited by C.A.F.
Thanks mate :-) Les shot me a message re that. Oh well, thems the breaks.
Posted (edited)
While setting the panel gaps I noticed that the RH door hinges had a small amount of slop.
I contacted my friendly Z door pin and bush supplier but he was out of stock. I had to wait, but a couple of weeks ago they arrived and I finally had time to fit them.
The pins were obviously slightly worn, however the new pin and bushes (along with a good greasing) have completely removed any movement from the hinges. Should be good for another 50 years now!
Edited by C.A.F.
You’re the man Locky! Stoked with your workmanship and dedication!
35 minutes ago, C.A.F. said:
Obviously they got the dyno fixed!
Those figures should keep you entertained 'ol boy...
Yes sirree! ;)
On 10/17/2020 at 2:34 PM, mossy said:
Nice, makes me glad I'm staying with the 2.4
For sure mate. These things are getting too valuable the swap out a matching numbers engine.
