1,000 -
54
Everything posted by AndBir
Have you snapped up the last remaining turquoise blue set ?
Nope, a 260z has a simple "slide type" single pole double throw (center off) switch while the 240z has a complicated toggle/rocker type "switch" that I read could be described as a modified double pole double throw (center off) switch. Not sure about the light stalk/switch wiring.
Ross Dunkerton and Graham Alexander discuss Datsun 240/260Z's with James Nixon at Rally Retro 2020.
No Idea what these numbers mean, mine has # 2_10_15
I was lucky to get the one I pictured from a forum member here, just need to work out how to either modify the vacuum controls or add something similar to the original vacuum system.
An interesting video covering a bare metal (underbody) strip and various methods that can be used :
Looks like Nissan may have missed their chance as the Toyota Supra looks very much like (albeit less angular) the online concept drawings of the 400Z.
Yep, hard to tell how the core dimensions compare but the shorter copper hard lines could be replaced / extended to suit.
More "talk" of the 400z today : https://www.caradvice.com.au/842485/nissan-z35-400z-370z-successor-could-appear-this-year/
AndBir replied to XRQTR's topic in Parts and Tools for Sale
For those in Canberra : 240z seats x 2 Price : $150 Good working condition with rails. Passenger seat fair, drivers needs cover replacing https://www.gumtree.com.au/s-ad/reid/other-parts-accessories/datsun-240z-original-seats/1245633921 -
Triple mikuni 44 for sale : https://www.gumtree.com.au/s-ad/mount-waverley/engine-engine-parts-transmission/triple-solex-mikuni-44-phh-s5-datsun-motorsport-240z-fully-restored/1245184342 -
Not from what I have seen mentioned.
From my (fading) memory, this gate never had the shiny silver hot dip gal "crystaline" finish, it was always a dull grey colour. One has to ask, given the benefits of zinc for rust prevention, how do the alternatives POR15 and KBS rust seal achieve their "rust protection" properties - is it just through "sealing" out oxygen/moisture from contacting the metal?
A search of the forums only turns up one reference to using Cold Gal(v) as a rust prevention coating whilst there are more mentions of using POR15 and KBS rust seal paint treatments. Not sure of the principal behind the POR15 and KBS paints however given the proven characteristics of galvanising I suspect the cold gal(v) type paints with >90% zinc content would be the better option especially when painted onto the bare metal as an undercoat either on internals of the doors/hatch, the floor pans and/or on the underbody. The photo below shows how a fence/gate post in a coastal location (~100m from the beach) has survived 50 years of salt exposure with a coat of cold gal(v) whilst the barbed wire has not fared well! Anyone used Cold Gal on their Zed?
Back to the farm to work on the Zed. Put in the internal sound deadener to replace the factory sisal and rubber under the carpet and installed the Kia door seal as the internal rear hatch seal (with about 3cms to spare). After a couple of test drives I tried out the internal heater and yes the inevitable happened there was a leak of coolant and it appeared the heater stop cock was leaking so I had to then remove just about everything for under the dash to extract the unit and do the required repairs. The offending item. After syncing the carbs and adjusting the idle speed and mix screws out for another drive to check on other roadworthy requirements. Found a nice 370Z on the way. So almost ready for the pre rego roadworthy, just need to get the windscreen wipers to reliably operate along with the internal blower/fan that only operates randomly and then see what works best for the PCV requirements for it to be a closed circuit (ie not just a filter on the rocker cover ;-( )
Seems you got lucky as I read sometimes these can be diabolical to get out! Your home made SST (special service tool) looks just the thing. Giving away your age there - when did the last one of those run?
That looks like a lot of alloy !
If it is just some limited damage then a custom fix would seem to be the better option.
GROUP BUY 240Z/260Z NEW rear hatch glass $495
AndBir replied to 240ZR's topic in Parts and Tools for Sale
Maybe they could be encouraged to get a "direct print" Vista View defroster print machine? https://www.frostfighter.com/frost-fighter-new-product-news.htm -
OEM NEW Datsun 240Z 260Z 280ZX 1600 Inspection Light Lamp Buy it now : $199 https://www.ebay.com.au/itm/Datsun-240Z-260Z-280ZX-1600-Inspection-Light-Lamp/114046281984?hash=item1a8db02900:g:WQMAAOSw2QteDpfj (Interesting other items that the seller has for sale!! - not Z car related) Edit : Just to clarify not interesting to me but others may be inclined ;-) -
If you do, be aware the front and back bushes are different sizes and the workshop manual states the large fixing bolts on the ends should be tightened / torqued up with the car loaded with the equivalent weight of two small adults sitting in the car as well as a full tank fuel.
IMHO the original rubber type will be better for road driving but you will pay more for them.
I found the documentary of the development of Shelby cars quite interesting. Late in the show there is a reference to the Datsun roadsters and Brock racing. https://www.netflix.com/au/title/81218074
I saw the product Peel Away being used to remove paint off painted bricks on a house and thought it may work for car paint removal. https://www.peelaway.com.au/
