smugley Posted October 25, 2016 Posted October 25, 2016 Red 1971 240Z on carsales from VIC $96,500 ...YES ...$96,500 http://www.carsales.com.au/private/details/_/SSE-AD-4344650?WT.seg_4=AutoAlert;PCAA Don't think it's a 71 240z as in the pick above it's got a side repeater on the rear quarter panel . Also for $96k you could put a mirror on the drivers side door ? My guess is that image is of a LHD car . Quote
Agno Posted October 25, 2016 Posted October 25, 2016 RHD cars should have a mirror on the right (driver's) side, a mirror is optional on the passenger side. In that ad though there is no mirror on the driver's side so it's a photo of a LHD car... with a cream interior. Quote
ScottyD Posted October 25, 2016 Posted October 25, 2016 Back to the 96k car, his internal photo is from kodies old cat which is for sale in the uk. See the link below. http://m.carandclassic.co.uk/car/C755524 Curtis240z is correct about the interior picture, check out the link, the picture is from a right hand drive car with dual mirrors Quote
Mark B Posted October 25, 2016 Posted October 25, 2016 Don't think it's a 71 240z as in the pick above it's got a side repeater on the rear quarter panel . Also for $96k you could put a mirror on the drivers side door ? My guess is that image is of a LHD car . Wipers are a give away, definitely a pic of a LHD car. d3c0y and 600Z 2 Quote
ScottyD Posted October 25, 2016 Posted October 25, 2016 (edited) Maybe it isn't restored yet and is fishing for interest levels at that price? Yeah there's something Fishy about this add. Edited October 26, 2016 by ScottyD Quote
Administrators gav240z Posted October 26, 2016 Author Administrators Posted October 26, 2016 Bowral NSW 1973 Datsun 240z for sale. http://www.gumtree.com.au/s-ad/bowral/cars-vans-utes/datsun-240z-1973/1127802407 $35,000.00 Has L28 which is 3.0 with triple 45mm dellorto's.extractors,stainless exhaust head work, Pete Brock USA spec cam, R200 diff, Auto with 2800rpm stall.front and rear strut braces,front camber and castor adjusters,heavy duty springs and sway bars,rebuilt brake master cylinder, Brand new 16" tyres front and back. Has been in storage for approx 7 years. These are the only pics at the moment. I have had this car approximately 30 years. Car is complete and goes. Some rust in the usual places that is not that bad. All these old Zeds have rust. If you are looking at this you know what it is. A lot of money has been spent over the years though ideally requires some work and a paint. Original interior in black with original steering wheel. Has factory a/c which still has gas 134a though drive belt isn't connected.Best to message me and I will get back to you asap. Too much to list. This ad is for expressions of interest at this stage and if you haven't got 30 plus k don't bother. Thank you Car will not be available for inspection for approx 2 weeks as that's when I get it out of dry storage. NO REGO. Remember the car is 43 years old though drives very well. Also the car has been regularly maintained whilst in storage with regular brake fluid changes etc and started quite regularly. This old girl goes hard!! Quote
Macdat Posted October 29, 2016 Posted October 29, 2016 http://www.gumtree.com.au/s-ad/narre-warren/cars-vans-utes/1973-datsun-240z-coupe-restored-body-unfinished-project-1uz-fe/1128208114 1973 Datsun 240Z Coupe. Restored body. Unfinished project. 1UZ-FE $35,000.00 240Z for sale 1973, 2 seater S30 Body restored from bare metal even though it was a very good example before being stripped without any bog. Only place requiring new section was the drivers floor. Painted in a White with a slight Pearl in it Chassis rails extended and strengthened Chassis rails and pillars filled with a 2-pac structural foam. This is NOT the usual sound deadening foam that holds moisture and creates problems it is a very expensive automotive foam that is used in some production cars for strength, stiffness and durability. It sets hard like concrete inside the steel section providing an extremely strong, light and stiff body. I am just explaining because it’s not everyone’s cup of tea but for me I wanted an ultra-stiff body for handling and performance without a roll cage. Bonnet, guards and hatch are fibreglass. I don’t have the panel between the windshield and the bonnet. A panel beater lost it on me years ago. I have a Lexus/Toyota 1UZ-FE mounted to a Supra 5 speed with the lay-back shifter. Sits perfectly and was done without modification to the original body. Custom engineered high grade alloy brackets were fabricated to join the V8 to Hilux diesel engine mounts and then to the 240Z. It ended up being a very neat and strong fit. A modified gearbox mount was made to mount the gearbox in the correct alignment for the rear drivetrain, again mounting to the original, strengthened 240Z mounts. Rear diff is from a Jap spec GTR Skyline and is a longnose R200 Clutch plate LSD. Was very hard to find and expensive but perfect for this build. Have a complete set of brakes, adjustable control arms, links, moustache bar, etc… from Arizona Z Car. Have the required and upgraded adapters from Modern Motorsports for stronger axles, CV conversion, new driveshaft, etc… Also have the CVs from a 300ZXT. Have a box full of replacement parts purchased new for the build (bushes, nuts, bolts, etc). I have very hard to find and expensive forged aluminium wheels. These are in the largest size you can legally engineer in Australia (16x6.5 iirc). Have two shelves worth of parts and spare parts. Interior is all there from what I recall but was painted black by the previous owner. I would not say the interior is in good condition but that never bothered me. Original seats are there but need some restoration. I had Honda Integra seats in it. This is all going off memory from 10 years ago as it’s been in storage for 10 years and I have moved multiple times since then. I need to stop typing otherwise I will start crying. Let me know if there is anything specific you want pics or info on. I am not interested in letting it go for too cheap at this point as I am not yet desperate but if someone who is after this sort of build gives a fair price I will reluctantly say good bye. Let me know your ball-park figure if you wanted to come have a look and please don’t try to bargain me, I am ok with you telling me what you think it’s worth to you but not interested in bouncing prices back and forth – sorry, it’s just too depressing. Quote
MichaelT Posted October 29, 2016 Posted October 29, 2016 I guess if you want to help artificially inflate the market for your own Interest, this kind of ad could be one strategy. Quote
Cliff Posted October 29, 2016 Posted October 29, 2016 http://www.gumtree.com.au/s-ad/edgewater/cars-vans-utes/1974-datsun-260z-2-vin-000933-one-of-the-first-1000-produced/1128116787 1974 Datsun 260Z+2 VIN: 000933!!! one of the first 1000 produced $4,000.00 More photos in HD here: http://imgur.com/a/D8nqp up for sale or swaps for a registered long wheel base van is my 1974 datsun 260z+2 which was one of the first 1000 of the production line, it is in no way good condition but has 95% of the parts to go with it towards restoration or parts. it has an L26 with electronic ignition module and roundtop factory carbs and mesh filters. car also has fiberglass bonnet gives it a muscle car look and lowering springs which sits at a nice height. will also come with the wheels for the right price otherwise you bring your own, not shown in photos but it has all glass and panels most trims and badges. car does have extensive rust to the chassis, lower portion of the car and passenger/driver footwells. the rear seats have no rust holes nor does the entirety of the boot area. have fired the engine once on an external battery and fuel tank and did run however i'd clean up the wiring and give it an oil change and carb rebuild as the car sat at the previous owners house for 2 years. have a Revs check on paper aswell to view for buyer with no finance, theft or crash history. do not lowball, these cars are becoming increasingly rare and to find one of the first 1000 built is highly uncommon, only a handful on zcar register under 1000, car suits complete restoration to the right buyer/collector. Quote
cracker Posted October 29, 2016 Posted October 29, 2016 I guess if you want to help artificially inflate the market for your own Interest, this kind of ad could be one strategy. Not sure if it's a strategy, but it is a bunch of expensive bits with a very good looking shell. You could do worse with some of the others on the market at present! richard260 1 Quote
NGDCTeam Posted October 29, 2016 Posted October 29, 2016 Seeing these posts with odd sales pitches, such as, "I need to stop typing otherwise I will start crying" and "This ad is for expressions of interest at this stage and if you haven't got 30 plus k don't bother.", are a little funny but more so tasteless. Yes, i understand these cars were bought for much less back in 2010 (this includes me) and are now worth double, but how do folks who are trying to get into the Z car scene over here (Australia) get their foot in, when unfinished projects or poorly restored zeds are this expensive? Quote
MichaelT Posted October 29, 2016 Posted October 29, 2016 Nah I'm talking about the dodgy ad above. Orange car. The White one looks sweet. Quote
cracker Posted October 29, 2016 Posted October 29, 2016 Ah, sorry, hard to keep up! Few popping up at he moment haha. Orange ad is peculiar... Perhaps genius? More likely embarrassing. Quote
Macdat Posted October 30, 2016 Posted October 30, 2016 http://www.gumtree.com.au/s-ad/doncaster-east/cars-vans-utes/1975-datsun-260z-coupe/1128296774 1975 Datsun 260Z Coupe $7,000.00 Datsun 260z 2+2 1975. Car hasn't been used in a while, and I'll never get around to restoring it, so selling it as is. It used to be red, but being under a car cover for an extended period of time stripped much of the paint on the top. I think the white areas on the car (where it should be red) is the clear coat that has been stripped. It starts and runs, however the battery is dead. The engine is the L28 model (2800cc), not the standard L26. It includes twin SU carbies, electric fuel pump. 5 speed manual. Has some rust coming through in the usual places - mainly under the door area on both sides in front of the rear wheels, at the back of the hatch, and other areas. Has a front spoiler, louvres on the bonnet, standard 14" wheels, with a spare in the back. Has CD player, (but not sure if it still works) and Air-Con. Also includes some extras including another set of rear tail lights, and some rubber gaskets. Quote
ScottyD Posted October 31, 2016 Posted October 31, 2016 (edited) 1973 240z $75,000 VIC. http://www.carsales.com.au/private/details/_/SSE-AD-4354367?WT.seg_4=AutoAlert;PCAA Up for sale is 1973 Datsun 240z This car is a shining example of a period correct performance orientated 240z. It has been my dream car for many years but I must now focus my attention towards other things. The car features a fully built L28 that has been take out to 3L with heavily modified internals. Running standard looking inlet and ex manifolds, distributer and carbies. Restored in 2008 with the intention to enter the occasional tarmac rally/ hill climb event however has been nothing more than a cruiser in my time of ownership. Body is in great condition. All inspections welcome. Also to come with the car is the original standard bore matching numbers L24 engine. Car has had oil and filter replaced every 5,000km. Built, bored and stroked L28 to 3.0L Rebuilt 5 speed close ratio gearbox with short throw shifter (thousands spent) Crow Cams Performance Camshaft Semi competition type Clutch Xtreme Lightened moly flywheel Genuine Datsun door well plates New window trim Front Disc brakes Rear Drums with upgraded compounds Original Steering wheel Original re trimmed vinyl front seats Koni adjustable shocks and custom springs Custom built bolt in bolt out roll cage with trip meter and speedometer Extractors Recent tune Passenger door lock re fitted New bushes Superlite Performance wheels with Yokohama semi slicks all round Happy to organise inspections or shipping for interstate buyers Fast car, making around 150kw at the wheels. Will not disappoint. All modifications are tastefully done and are able to be taken back to standard easily. Please no tyre kickers/ dreamers. No joy rides. May be tempted to swap for a BNR34. Car will be sold with current and valid Victorian RWC. I am in no rush to sell. Please text for all genuine enquires. Thank you Edited October 31, 2016 by ScottyD gav240z 1 Quote
Administrators gav240z Posted October 31, 2016 Author Administrators Posted October 31, 2016 Gotta love the lead up to Christmas, that's the best time to pick up an S30Z. Quote
ScottyD Posted October 31, 2016 Posted October 31, 2016 yeah this one sold on Carsales around 1 year ago, can't find the ad was around the $40k mark I was very interested at the time. Quote
BNE Posted October 31, 2016 Posted October 31, 2016 Really interested in this car - is there a local who could have a look over it? 1977 Datsun 260Z Coupe on Gumtree http://www.gumtree.com.au/s-ad/1128409690 Quote
Administrators gav240z Posted October 31, 2016 Author Administrators Posted October 31, 2016 I might be able to help later this month I'm currently in California until the 11th of November though. So hopefully someone else can look for you? Quote
ScottyD Posted October 31, 2016 Posted October 31, 2016 Found it. 1973 Datsun 240Z. $40khttps://www.carsales.com.au/private/details/Datsun-240Z-1973/SSE-AD-3914533 This 240z was fully restored around 2008 and modified to suit the occasional tarmac ralley , hillclimb or track day. It has a 2.8 litre L series engine taken out to 3.0 litre and still running standard looking inlet and ex manifolds and carbies. Standard distributer and other accessories but heavily modified internals producing 149 rear wheel kilowatts. It has a custom built bolt in bolt out roll cage and a cams log book. It uses standard configuraton brakes with upgraded compounds, koni adjustable shocks , and custom springs. the gearbox is a rebuilt later model unit and the diff an original 240 type, the clutch is a semi competition type with a lightened moly flywheel, the combination works well and the car has been driven to every event and home again and never needed a trailer . All modifications are tastefully done and are able to be taken back to standard easily, with the car comes the original standard bore matching numbers 2.4 litre motor. The car has been garaged for about the last 5 years with very little use and probably needs to go to someone that will use it a bit more. gav240z and cracker 2 Quote
BNE Posted November 1, 2016 Posted November 1, 2016 I might be able to help later this month I'm currently in California until the 11th of November though. So hopefully someone else can look for you? Thanks I love the look of it bar the sunroof, but if that is the only downside I am all over it. I will see how I go in the Melbourne Cup maybe I can afford it anyway Quote
RLY240 Posted November 1, 2016 Posted November 1, 2016 yeah this one sold on Carsales around 1 year ago, can't find the ad was around the $40k mark I was very interested at the time. Wow, $25k profit in 18 months, beats the markets. ric240z 1 Quote
Mark B Posted November 1, 2016 Posted November 1, 2016 Wow, $25k profit in 18 months, beats the markets. Only a profit if he actually gets the $75k for it, it seems lately the stuff that is cheap, even if it is rough or rusty sells pretty quick, but movement in the $60k plus bracket seems to be very slow !! no harm in asking, but what you ask and what you get seem to be two different things !! Just my humble opinion Mark B Quote
Administrators gav240z Posted November 1, 2016 Author Administrators Posted November 1, 2016 Agree with Mark, although those thinking they can restore some of the rough examples to the level of the 60k cars and still come out ahead are probably living in a delusional state. No harm in that, but they will soon find out the costs of doing a restoration properly . Quote
