Enzo
Everything posted by Enzo
  1. Happy Birthday old fella. I hope you got a nice new 240z wrapped up as a present. Donation on the way. Don't spent it on car parts. Regards David.
  2. If using the mechanical fuel pumps, disassemble one to see if the rubber diaphragm is perished.
  3. Hi guys, (Previous post lost due to server upgrade). I have for sale a set of British 2'' SU carbs on a modified manifold and cool air intake. Formally belonged to James Flett and used on his race car. I will be heading east on the 5th November, heading to Orange NSW and Canberra. I can bring them over which will be cheaper than postage if any takers. $900.00 plus post/freight. David (Enzo) zero four hundred, two zero two, six seven eight.
  4. Hi Guys, Due to a server update the post was deleted. I have a modified N42 head for sale ready to go and unused. Built by Brett and James at MIA Engines in Dee Why, Sydney. Parts from Datsun Spirit in Virginia USA. .560 thou lift propriety camshaft with DSI big bore valves (Ferrea), new valve guides and seats, reshaped combustion chambers (40cc), injection notches welded closed, new rockers, pressure tested etc. (No flow charts available) $5000.00 I will be travelling through from WA to Orange NSW and Canberra in November and can transport it over east if anyone is interested to save freight. Leaving on 5th November. Regards David. (Enzo) Zero four hundred, two zero two, six seven eight.
  5. Brass Exhaust Manifold Nuts - Metric Pitch High Temp Inlet M8 M10 & UNF UNC | eBay
  6. I was reading an article about using the bell housing section to bolt a 6speed gearbox to the L6 but can't find it at the moment. I would probably keep that and throw the rest.
  7. No.1 at the box office.
  8. 260Z Carb Adjustment Manual1.pdf
  9. Hoke have stopped making these now. The better option is a bell housing designed by Derek ( he makes the twin cam heads on hybridz). This is sold through Godzilla Raceworks and uses the original flywheel and clutch. You can buy the parts or the complete conversion. I have a bell housing adapter and tail shaft in transit now. Also the CD00A has better syncro’s than the CD009, otherwise they are the same box. I will buy the box in Australia to save transport costs. David.
  10. Ask @CAF as he posted regarding a restoration he is doing.
  11. Like trying to put your pants on after taking a little blue pill .
  12. Hi Ryan, Mine was posted on the 8th I think and arrived on the 18th. With Christmas getting closer now postage is probably starting to back up. Don’t stress. You will be happy when you see the quality. merry Christmas David
  13. Hi Sean, Mine arrived today and I am impressed with the quality and quick delivery from France. Have a safe Christmas and New Year. Regards David. (Enzo)
  14. Hello Sean, I would like to take one. Regards David
  15. From the USA with the Beru Blue coil.
  16. I used the Crane XR700 for years but fried it when I stuffed up some other wiring. Great unit. I now have the Hot Spark ignition module (as in the first post) with the Beru Blue coil. No resistor is required for this setup ( Full 12V). A coil with more than 3.0 ohms of primary resistance is also required. You have to be careful with voltage polarity with the Hot Spark unit or you can fry it as well. I am currently using the above with the FiTech 30003 4 barrel EFI on a Arizona Z dual plane manifold. The standard 260z Tacho works with this setup. The crane XR700 requires the existing resistor in line. The Crane XR3000 deletes the resistor. I have never used a Pertronix unit but would go back to Crane (Now Fast) unit if using an original distributor. I do keep a spare original distributor with points in storage behind the seat just in case. Regards David.
  17. Nice Seinfeld reference.
  18. Hi Rob, I have a 1976 260z . The distributor black wire goes to the distributor neg (-) side. The black/white wire goes to the Coil pos (+) side. There should be a second B/W and G/W that went to the resistor but if you have bypassed that they should be joined together. 260z RHD wiring..docx
  19. Congratulations Gavin and Maria from WA. Hope that you are all safe and well in these trying times. Life changes for the better now for you. (I just had a flashback to Brian in Fast and Furious taking the kid to school in the people mover). Regards David.
  20. Welcome to the Forum. 6K is a great price for a 2 seater. I also have the 1976 RS30 model. The carbs are the desired 240z Hitachi/SU models as opposed to the flat top original 260z carbs. I noticed that the rear carb has the top fitted 90 degrees clockwise. The little bump should face the air cleaners like the front carb. When realigning make sure the piston moves up and down freely. Good luck with the build and have fun. ( opps! Sorry guys, I thought that they looked like the Hitachi/SU carbs of the 240z. I stand corrected). David.
  21. 1: Yes, 2:Yes, 3: Yes, 4: Brake Booster, 5: Not sure. 6 and 7, flow through water to warm carbs,9Noone ever uses these). 8: usually to distributor vacuum cannister (Vacuum advance). Block spare off. 9: Vent to air cleaner back plate. There will be another one on the second carb fuel bowl. 10: PCV (Positive crankcase ventilation) connected to the front of the block below the headers. David
  22. Hello Craig, If you have the 2nd one available could I please have that one. Cheers David.
  23. Hi Guys, Just finished watching this video of "Iconic engines", Datsun "L" series. Thoroughly enjoyable and a bit of humour. I'm not sure if it has been posted before. David.
  24. Hi Guys, Having put up with a dicky starter motor for a while it was time to look for a new one. I have 3x 40 plus year old starters with issues and I was quoted an amount to fix them which was more than buying a new one. I ordered a gear reduction starter from one company but he cancelled the Ebay order saying that couriers would not pick up from his address because of the Covid-19 situation. I then ordered for another company which supplied me a nice starter which was smaller and lighter than the original. $140.00 plus $22.50 standard delivery from Thomastown in Victoria. I think it spins the engine quicker than the old starter. I'm stoked. If anyone is in the market for a new starter I would suggest that they look at these. https://www.ebay.com.au/itm/Starter-Motor-Nissan-240K-240Z-L24-2-4L-260C-260Z-L26-2-6L-280C-L28-2-8L-Petrol/282603946312?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 Happy motoring David
  25. I had a day off work today so the front panels and bonnet went back on the car and I hit the road to the office for cheesecake and coffee. The new ignition system ( MSD6AL and Hot Spark)is great and the engine is crisp. The brakes need work. From sitting so long, I may have a seized caliper piston or two. Scared myself at the first traffic lights. Over the weekend I will have to look at them. I'm pretty stoked though since I haven't had the car on the street for about 3 years. With the Covid-19 lockdowns and cutting back hours at work, I am enjoying working on the car again. Ok guys, Stay safe and remember you don't have to stay 1.5 metres away from your Datsun. Only your friends. David
