CBR Jeff Posted June 11, 2021 Posted June 11, 2021 15 hours ago, C.A.F. said: Starts getting a bit scary when you cut away this much... Not from here. I'm finding it quite interesting, almost exciting. Jeff OdinZ, C.A.R. and gav240z 1 2 Quote
gilltech Posted June 12, 2021 Posted June 12, 2021 Quote Starts getting a bit scary when you cut away this much... Quote Not from here. I'm finding it quite interesting, almost exciting. Ditto. Having restored a Mustang ragtop with a myriad of rust issues under the paint (more cosmetic than structural, thankfully) and knowing the long time it took me, I'll not rush to tackle another. So AFAIAC maximum credit to those intent on saving this car. Just goes to show what increasing Zed values are doing, making very rusty cars like this one more financially viable to rebuild. Which saves more of them. Whereas a decade or so ago it would surely have been a source of parts and the remainder eventually scrapped. gav240z 1 Quote
C.A.R. Posted June 20, 2021 Author Posted June 20, 2021 LH inner and outer sill assembly is now done. I can't do anything about the doglegs (rockers) until I receive quarters... The bottom of the LH A-post was gone, so I made a new section and welded it into place. And I remade the lower section of the LH rear door jamb area as that was badly repaired previously. Liberal application of KBS Rust seal: Outer sill screwed into position and the door fitted to check the gaps: Onto the RH side next... gilltech, OdinZ, CBR Jeff and 6 others 9 Quote
C.A.R. Posted July 5, 2021 Author Posted July 5, 2021 RH side was next, so the door was gapped so I had something to compare the gaps too. And the bad repairs: Nothing for it, but to start cutting it all out: And then start reinstalling the funky green panels: Outer sill on, bottom of A post repaired and welded back in along with the bottom of the B post: While I was installing the sills, I had one of my guys - Paul - straighten the original LH guard as it had been beaten around more than a honeymooners wedding tackle: Floors are next... OdinZ, HS30-H, 240ZBUILTBYME and 1 other 4 Quote
C.A.R. Posted July 12, 2021 Author Posted July 12, 2021 After a bit of farnarkling and swearing, the RH Funky Green floorpan is in. LH Side is next... Enzo, CBR Jeff, gilltech and 4 others 7 Quote
C.A.R. Posted July 16, 2021 Author Posted July 16, 2021 LH floor is now complete: gilltech and Mike F 2 Quote
C.A.R. Posted July 16, 2021 Author Posted July 16, 2021 The footwells will be repaired at a later time... Today I started on the plenum top & got the RH side repaired, less the inspection flap mount: LH side next week... gav240z and Mike F 2 Quote
gilltech Posted July 16, 2021 Posted July 16, 2021 Jesus that car has had a tough life... your impressive work though is bringing it back from the brink. Looking at that butt joint in the lower part of the last photo, what's the plan to deal with the cut'n'shut front quarter? Quote
240ZBUILTBYME Posted July 16, 2021 Posted July 16, 2021 59 minutes ago, gilltech said: Jesus that car has had a tough life... your impressive work though is bringing it back from the brink. Looking at that butt joint in the lower part of the last photo, what's the plan to deal with the cut'n'shut front quarter? I believe that’s a stock join isn’t it? From memory it’s the join of the a pillar and air plenum that goes the the nose of the car. gav240z 1 Quote
C.A.R. Posted July 16, 2021 Author Posted July 16, 2021 1 hour ago, gilltech said: Jesus that car has had a tough life... your impressive work though is bringing it back from the brink. Looking at that butt joint in the lower part of the last photo, what's the plan to deal with the cut'n'shut front quarter? That's where they repair was joined, but it's also where they join them with stich welds from the factory. Quote
gilltech Posted July 17, 2021 Posted July 17, 2021 What I meant is that the structural welding, by a repair person unknown, looks extremely poor (an understatement). One can presume that the rest of the welding used to attach the replacement front quarter, way back when, is of a similar low standard. So, what to do? Take the quarter off again and make all good? Quote
NickF Posted July 17, 2021 Posted July 17, 2021 (edited) The welding from factory was very rough in that area. Lucky what do you use on the raised joint between the air tube and plenum its seems to be a non hardening mastic (brand?) Nick Edited July 17, 2021 by NickF Quote
RestoZ Posted July 17, 2021 Posted July 17, 2021 That's Lucky without a U 240ZBUILTBYME, OdinZ, gilltech and 1 other 4 Quote
C.A.R. Posted July 20, 2021 Author Posted July 20, 2021 On 7/17/2021 at 4:16 PM, gilltech said: So, what to do? Take the quarter off again and make all good? Watch this space... On 7/17/2021 at 5:17 PM, NickF said: Lucky what do you use on the raised joint between the air tube and plenum its seems to be a non hardening mastic (brand?) I'll just be sealing it with regular seam sealer, Nock. On 7/17/2021 at 10:15 PM, RestoZ said: That's Lucky without a U You seam to be having the same issue as Nock above... Are you two related? NickF 1 Quote
C.A.R. Posted July 20, 2021 Author Posted July 20, 2021 (edited) With the plenum to panel sides repaired... I tapped it with a hammer and the panel came off: And this is the reason I removed it - I needed access to repair this: Onwards........ Edited July 25, 2021 by C.A.F. OdinZ, gav240z, 240ZBUILTBYME and 1 other 4 Quote
240ZBUILTBYME Posted July 21, 2021 Posted July 21, 2021 On 7/20/2021 at 11:26 AM, C.A.F. said: And this is the reason I removed it - I needed access to repair this: I need to do this exact same thing to repair mine, wanted to take that panel off exactly as you have, but I’d never seen it done. Good to know it’s doable! Great work! Quote
C.A.R. Posted July 25, 2021 Author Posted July 25, 2021 (edited) I decided to remove the plate inside the plenum that reinforces the pedal box mounts on the inside - no exactly easy to get at, but I eventually got it removed: Tasty... I wire brushed the area, then I make a repair patch to follow the curves, cut the rusted section out and welded in the new piece into place. Edited July 25, 2021 by C.A.F. CBR Jeff, gav240z, AndBir and 3 others 6 Quote
gilltech Posted July 25, 2021 Posted July 25, 2021 Wow. Rust damage every which way you turn. The impressive repair work continues. gav240z 1 Quote
AndBir Posted July 25, 2021 Posted July 25, 2021 4 hours ago, gilltech said: Rust damage every which way you turn. And how many of our cars have this insidious rust "infection" quietly eating away from the inside out? - the answer is all of them - it just varies as to how extensive it is :-( And sellers on Carsales want you to pay ~$100k when you have no idea as to what is happening under the shell of the car - crazy! gilltech, 240ZBUILTBYME and OdinZ 1 2 Quote
Administrators gav240z Posted July 26, 2021 Administrators Posted July 26, 2021 Applies to any vintage cars for sale of that era. Quote
AndBir Posted July 26, 2021 Posted July 26, 2021 2 hours ago, gav240z said: Applies to any vintage cars for sale of that era. Unless they have had the C.A.F. restoration treatment :-) Quote
gilltech Posted July 26, 2021 Posted July 26, 2021 Quote Unless they have had the C.A.F. restoration treatment :-) Ah, yes, but restoration implies putting the subject back to as-made. From what I'm seeing I'd go further and describe that detailed work as preservation, better than the factory's effort of the day, with enhanced longevity for enjoyment by future generations. Perhaps pass the car down to ones grandchildren... Except petrol may be a limited commodity by then so conversion to an electric power plant might be required along the way... 240ZBUILTBYME 1 Quote
Administrators gav240z Posted July 26, 2021 Administrators Posted July 26, 2021 9 hours ago, AndBir said: Unless they have had the C.A.F. restoration treatment :-) This is why I like to buy the cleanest car possible to begin with... Because otherwise you're doing exactly what is being done here. Everything! AndBir and 240ZBUILTBYME 2 Quote
C.A.R. Posted July 26, 2021 Author Posted July 26, 2021 32 minutes ago, gav240z said: This is why I like to buy the cleanest car possible to begin with. And when are you going to buy said Z? OdinZ, gilltech, gav240z and 1 other 4 Quote
