CroS13 Posted March 27, 2018 Posted March 27, 2018 Hey mate how much did outer west charge you to blast the car and have it Epoxy primed? Are you happy with the blasting and priming work they did?I went and saw 2 other blasters, and was about to pull the trigger with stripco in Revesby. They were hesitant to epoxy the car, as they wanted to leave it in bare steel with a phosphoric coating so the panel beater could exactly see any damage on the metal. They said that if its epoxy coated it would mask potential issues with the metal. They only do blasting.The other mob i was going to go with, they blast then etch prime the shell. They wanted to charge me a additional $1000 just for labor to epoxy the car, without materials, which leads me to believe that they were going to outsource the epoxy work to a smash shop they know, so i was hesitant to use them.Outer west was going to be my 3rd option, i had heard 1 good review on them, a mate got his doors blasted there, but i never ended up calling them as i was going to go with stripco.Issue is my painter who was going to epoxy my car at home is going to america for 2 months. So its either wait till he gets back and get it blasted at Stripco, or find another solution.Rudi. Quote
lightmaster240z Posted March 27, 2018 Posted March 27, 2018 My car is currently having a door skin done from rare spare. The pain is that the door handler is not quite right and need some work. and some minor work to make it fit according to the panel guy. Say that I am happy with the over all look but it is still a few week away from see the light of day again. It been a quite the project so far. Bruce Quote
Administrators gav240z Posted March 27, 2018 Administrators Posted March 27, 2018 My car is currently having a door skin done from rare spare. The pain is that the door handler is not quite right and need some work. and some minor work to make it fit according to the panel guy. Say that I am happy with the over all look but it is still a few week away from see the light of day again. It been a quite the project so far. Bruce Yeah the lock hole isn't big enough and the skin is a bit short at the top edge under the windscreen A pillar and front fender. I need to mig along the edge of mine to close the gap. Given my time again I'd probably have repaired the original skin by replacing the lower section. Live and learn.. Quote
JDM-TOY Posted April 3, 2018 Author Posted April 3, 2018 (edited) Hey Guys Passengers door skin was delivered from Rare Spares pretty happy with the quality. Also ordered a drivers side Also had the rear passenger side inner and outer guards welded in. Now just need to have the new door skin adjusted correctly to have the correct gaps. Waiting on Tabco to deliver the drivers side inner and outer. Edited June 23, 2018 by JDM-TOY Quote
JDM-TOY Posted April 3, 2018 Author Posted April 3, 2018 (edited) Hey Guys Passengers door skin was delivered from Rare Spares pretty happy with the quality. Also ordered a drivers side Also had the rear passenger side inner and outer guards welded in. Now just need to have the new door skin adjusted correctly to have the correct gaps. Waiting on Tabco to deliver the drivers side inner and outer. Edited June 23, 2018 by JDM-TOY RAP260 1 Quote
JDM-TOY Posted April 4, 2018 Author Posted April 4, 2018 (edited) Hey Guys Finally recieved my order from MSA and I got slammed with duty and GST of $550. What can I say, its been one of those experiences. Starting with the 432 Rear Bobtail, all quality. Solid with mould to sit above the rear quarters and bolts for fitment on the boot, will not complain at all. Same goes with the Fairlady badges, made from good quality metal. The steering wheel is of high quality for a reproduction. Taillights well what can I say, smooth as can be. Rubbers all tught and wiring done to a high standard. Cant wait to ge the bobtail fitted. I know Gavin and Jeff would be intrested on how it sits Edited April 4, 2018 by JDM-TOY OdinZ 1 Quote
JDM-TOY Posted April 10, 2018 Author Posted April 10, 2018 Hey guys Went past to day to drop off the drivers inner rear repair panel and two front fender repair panels I finally recieved from Tabco. Passengers door skin has been replaced and currently working on the drivers door skin. Lucky I made the decision to replace both door skins. Between the outer and inner panels was heaps of hidden rust. It wouldn't have taken long for the rust to bubble through the doors. Tomorrow the work starts on the drivers rear inner and outer guards. Then in between, have the lower front fenders replaced on both sides. Im also considering getting new aftermarket bonnet from Ebay. The current one I have is workable but needs work. Happy Restorations Guys Quote
Administrators gav240z Posted April 10, 2018 Administrators Posted April 10, 2018 Let me know if you don't intend to keep the old door skins? JDM-TOY 1 Quote
GongZ Posted April 12, 2018 Posted April 12, 2018 Hi Youhan, I just saw your the photo of the inside of your car here; http://www.viczcar.com/forum/topic/17125-s30-seat-rails/?do=findComment&comment=203051 - and wondered if you are aware of the fact that you should fit a clutch pedal stop. See this topic; http://www.viczcar.com/forum/topic/11780-clutch-pedalstop/ Now would be a good time to fit one. JDM-TOY 1 Quote
JDM-TOY Posted April 13, 2018 Author Posted April 13, 2018 Hi Youhan, I just saw your the photo of the inside of your car here; http://www.viczcar.com/forum/topic/17125-s30-seat-rails/?do=findComment&comment=203051 - and wondered if you are aware of the fact that you should fit a clutch pedal stop. See this topic; http://www.viczcar.com/forum/topic/11780-clutch-pedalstop/ Now would be a good time to fit one. Hi Ian, good point thanks for the heads up. I will speak to the panel beater when I head out there next week. Also im getting him to cut the gear hole on the tunnel. Good post Cheers Quote
GregTas Posted April 13, 2018 Posted April 13, 2018 Looking good. Nice to see the original rear guards back on it. JDM-TOY 1 Quote
JDM-TOY Posted April 13, 2018 Author Posted April 13, 2018 Looking good. Nice to see the original rear guards back on it. Thanks Greg It coming along nicely but its a shame that the original guards had been butchered. Just happy its coming back to life Quote
kamarchi Posted April 13, 2018 Posted April 13, 2018 (edited) nice, i can not wait until i get to the repair stage of my build :-) keep up the awesome work Edited April 13, 2018 by kamarchi JDM-TOY 1 Quote
JDM-TOY Posted April 13, 2018 Author Posted April 13, 2018 (edited) Small update. Put in a order for new number plates for the 240z a few weeks back, S30Z. Recieved a letter from RMS yesterday that the plates are in. Cant use them now so I have put them on hold till the cars ready for the road. Should add to the style of the car once complete. I just hope the size is correct and its not larger than my current plates Edited April 13, 2018 by JDM-TOY gav240z, RAP260, George and 1 other 4 Quote
George Posted April 14, 2018 Posted April 14, 2018 Nice plates. I'm surprised they were available. JDM-TOY 1 Quote
JDM-TOY Posted April 15, 2018 Author Posted April 15, 2018 Nice plates. I'm surprised they were available. Yeah me too. There are other options out there too Quote
OdinZ Posted April 15, 2018 Posted April 15, 2018 Hey Guys Finally recieved my order from MSA and I got slammed with duty and GST of $550. What can I say, its been one of those experiences. Starting with the 432 Rear Bobtail, all quality. Solid with mould to sit above the rear quarters and bolts for fitment on the boot, will not complain at all. Same goes with the Fairlady badges, made from good quality metal. The steering wheel is of high quality for a reproduction. Taillights well what can I say, smooth as can be. Rubbers all tught and wiring done to a high standard. Cant wait to ge the bobtail fitted. I know Gavin and Jeff would be intrested on how it sits Hi Youhan, Just out of curiosity, how much was duty? and do you think you would have been better off doing two seperate orders/shipments to avoid the GST/duty, and pay the extra freight instead? Feel free to pm me if you don't want to disclose publicly. Quote
260DET Posted April 15, 2018 Posted April 15, 2018 Goods made in the USA are supposed to be duty free but it is up to the supplier to at least state this prominently in the paperwork. OdinZ 1 Quote
OdinZ Posted April 16, 2018 Posted April 16, 2018 Goods made in the USA are supposed to be duty free but it is up to the supplier to at least state this prominently in the paperwork. Yeah I am aware of the AUSFTA paperwork they need to fill out, which you have ask them to fill out each time. But I am assuming that some of the items above are not made in the US Quote
JDM-TOY Posted April 16, 2018 Author Posted April 16, 2018 Hi Youhan, Just out of curiosity, how much was duty? and do you think you would have been better off doing two seperate orders/shipments to avoid the GST/duty, and pay the extra freight instead? Feel free to pm me if you don't want to disclose publicly. Hey OdinZ All I recieved a receipt for the $550 I paid to FedEx via credit card. Theres no break down just the total amount and ststus paid. It has my details on it so wouldn't post it up. Cheers Quote
bjszed Posted April 17, 2018 Posted April 17, 2018 I'm in Canada and when I buy US parts I always request other carriers. UPS which uses FedEx overcharges for brokerage fee's, handling fee's etc. I always request USPS as there usually isn't any brokerage fee's. Not sure if that's an option for you guys. Its bad enough with our poor exchange rate to the US which is the same as Aus to US. Quote
OdinZ Posted April 17, 2018 Posted April 17, 2018 Hey OdinZ All I recieved a receipt for the $550 I paid to FedEx via credit card. Theres no break down just the total amount and ststus paid. It has my details on it so wouldn't post it up. Cheers Hey mate, all good. FedEx are supposed to send you the invoice (not receipt) which gives you the whole break down. I'm in Canada and when I buy US parts I always request other carriers. UPS which uses FedEx overcharges for brokerage fee's, handling fee's etc. I always request USPS as there usually isn't any brokerage fee's. Not sure if that's an option for you guys. Its bad enough with our poor exchange rate to the US which is the same as Aus to US. It's not so much the brokerage fees, it's the import duties (if parts are not made in the US) we have to pay our government plus GST when total value of imported goods is over AUS$1000 Quote
Administrators gav240z Posted April 17, 2018 Administrators Posted April 17, 2018 It's not so much the brokerage fees, it's the import duties (if parts are not made in the US) we have to pay our government plus GST when total value of imported goods is over AUS$1000 Not entirely true, when I import panels via sea freight I get charged GST (on goods under $1000 AUD worth), I believe it's because they charge GST based on the container value and so GST is applied to all items within. Not individual items. There is no free ride, hence find stuff locally if you can. Quote
OdinZ Posted April 17, 2018 Posted April 17, 2018 Not entirely true, when I import panels via sea freight I get charged GST (on goods under $1000 AUD worth), I believe it's because they charge GST based on the container value and so GST is applied to all items within. Not individual items. There is no free ride, hence find stuff locally if you can. Sorry, was referring to air-freight only. We don't sea-freight a lot at my work, too much of a delay for our products. Quote
