Wags Posted March 24, 2021 Author Posted March 24, 2021 24 minutes ago, C.A.F. said: I'm glad to see it will be 'mirroring' the original. I don’t know why you made me get another one...that one looks mint! And the dent on the back was for efficiency after extensive wind tunnel testing. gilltech and C.A.R. 2 Quote
Wags Posted March 25, 2021 Author Posted March 25, 2021 Would you look at this beautiful update today: C.A.R. and 240ZBUILTBYME 1 1 Quote
Wags Posted March 25, 2021 Author Posted March 25, 2021 And would you look at what Les Collins at LCR has done for me with this Nissan diff. Should handle the extra BHP with ease. Ponyo240z, C.A.R., gav240z and 1 other 4 Quote
Wags Posted March 25, 2021 Author Posted March 25, 2021 And just this second Locky tells me that the rest of our replated items are back!! 240ZBUILTBYME, Ponyo240z, gav240z and 1 other 3 1 Quote
Administrators gav240z Posted March 25, 2021 Administrators Posted March 25, 2021 I love getting back a box of replated bolts, it's like jewellery for car guys! Wags, C.A.R. and Ponyo240z 3 Quote
C.A.R. Posted March 25, 2021 Posted March 25, 2021 Diff is based around a late model MR30 Skyline unit with a 3.9 ratio - it'll be going in tomorrow Wags 1 Quote
Wags Posted March 25, 2021 Author Posted March 25, 2021 59 minutes ago, C.A.F. said: Diff is based around a late model MR30 Skyline unit with a 3.9 ratio - it'll be going in tomorrow Locky at CAF has has the oversight and the vision to bring this all together. Props to that man! Not long to go now folks! gav240z 1 Quote
240ZBUILTBYME Posted March 25, 2021 Posted March 25, 2021 Color photos already!!! The suspense is killing me! Wags and CBR Jeff 1 1 Quote
Wags Posted March 26, 2021 Author Posted March 26, 2021 And now for some more car porn to get you all through the weekend! Drive line is in...Locky is a machine! (although I think he really enjoys this part of the build) KatoKid, Mike_F, gav240z and 1 other 4 Quote
Administrators gav240z Posted March 26, 2021 Administrators Posted March 26, 2021 I feel like I'm stuck in the first half of the wizard of Oz. 240ZBUILTBYME, C.A.R. and Wags 3 Quote
C.A.R. Posted March 29, 2021 Posted March 29, 2021 A mate of mine is a professional automotive photographer and he stopped by the shop today to take a few photos... Wags, 240ZBUILTBYME, Ponyo240z and 1 other 3 1 Quote
AndBir Posted March 29, 2021 Posted March 29, 2021 Looking more of a red colour now? C.A.R., gav240z and Wags 3 Quote
CBR Jeff Posted March 29, 2021 Posted March 29, 2021 Only thing that is definite is that the tires are black Jeff Wags, C.A.R. and 240ZBUILTBYME 3 Quote
Wags Posted April 10, 2021 Author Posted April 10, 2021 Pump and pre-filter have arrived along with this pretty looking wiring harness. C.A.R. 1 Quote
C.A.R. Posted April 13, 2021 Posted April 13, 2021 (edited) So the wiring harness caused Jon and I some consternation - when I got the wiring loom out to install it into the freshly painted body it struck me that this was probably unwise to put a 48yo wiring harness back into an effectively new car... I spoke with Jon and he agreed that something should be done about it, so I called Vintage Wiring Harness's to enquire about a new loom. I was rather taken aback when I was told it was a 6 month wait for a new loom! But upon reflection, this is not out of the ordinary for the restoration industry at the moment. After informing Jon of this he rang around all the numbers in the phone book looking for a company that could make us a new loom, but it was the same story - they were all booked out for months. In a last ditch attempt to rectify the situation, I spoke with a fellow forum member and Z owner to see if he would be interested in at least refurbishing the original loom for us, as he is a bit of a wiring guru and Jon's Z loom was in good, original condition - and thankfully he said yes. All new plugs (where available) were replaced along with the pins, then it was all lovingly retaped in proper loom tape - no electrical tape here. It was also a damn sight cheaper than a complete new loom... So that's the story of Jon's 240Z loom! Edited April 13, 2021 by C.A.F. gav240z, Ponyo240z, Wags and 1 other 4 Quote
C.A.R. Posted April 13, 2021 Posted April 13, 2021 (edited) I'm concentrating on the fuel system at the moment as some customization is required, due to the triplets. On the engine dyno, Les Collins ran the fuel in from the rear of the engine, but because the factory fuel hard lines are being used I need to run the fuel lines in from the front. Les was against this idea due to heat soak from the radiator causing vapor lock and wanted me to run the fuel across the back of the firewall or across the top of the radiator support panel. I understand Les's concern, but both options are unsightly and difficult to implement neatly. Now I could just use rubber hose and P clips to run from the fuel filter on the RH side of the engine bay and across the front of the tappet cover, but that's unsightly and unprofessional so I decided to make my own short fuel rail from some 3/8" (8mm) bundy tube. I've since remade this again with the mounts being silvered soldered on instead of the unsightly TIG welds (bundy is difficult to weld nicely!) I'll be adding some heat shielding to it once it's come back from plating. Second problem was the straight fuel banjo fitting on the front Weber - it needed to have a 90deg bend on it to point at the new fuel rail. I called Weber Performance to see if a suitable fitting was available but Daniel informed me no such fitting exists. Bugger! My only option was to cut and rotate the banjo fitting. First I dipped the fitting into Hydrochloric acid to remove the plating, then - sweating bullets - I carefully cut the end off the fitting at 45deg. This would then allow me to rotate it to 90deg. I then TIG welded it into position at the correct orientation. A quick leak check and it can now go off to be replated. The fuel pump is a 'pusher' Pierburg rollercell item rated to 600hp (should be 'just' adequate) and this needs to be mounted as close as possible to the fuel tank with a 30micron pre-filter before it. There's not much room to make it a neat install, so watch this space... Also because of the higher pressure the Pierburg delivers, a fuel pressure regulator is now required. I procured a Malpassi FPR from Weber Performance and I've mounted it on a bracket just below the fuel filer on the RH inner skirt (photo to come). Edited April 13, 2021 by C.A.F. Ponyo240z, gilltech, 240ZBUILTBYME and 1 other 4 Quote
AndBir Posted April 13, 2021 Posted April 13, 2021 2 hours ago, C.A.F. said: some customization is required, due to the triplets You're not a fan of the original fuel rail with the fuel return? Quote
C.A.R. Posted April 13, 2021 Posted April 13, 2021 2 minutes ago, AndBir said: You're not a fan of the original fuel rail with the fuel return? It's only got two outlets... Quote
Wags Posted April 16, 2021 Author Posted April 16, 2021 New engine oil pressure switch arrived. C.A.R. 1 Quote
Wags Posted April 21, 2021 Author Posted April 21, 2021 Another couple of things back from the platers, the wiper arm assembly etc...looking very tidy! CBR Jeff, gilltech, KatoKid and 2 others 4 1 Quote
Wags Posted April 25, 2021 Author Posted April 25, 2021 Now onto the seats: So we have brand new foams and brand new black seat covers to go to the trimmers to be fitted. Now for a little TLC on the seat frames and sheet steel backing. Locky will have them sand blasted then painted. Good as new! C.A.R. 1 Quote
Wags Posted May 3, 2021 Author Posted May 3, 2021 (edited) More updates: Guard seals on; guards on; Wiper motor and bracket installed. Locky is going to sure up the gaps on the guards once again and they are good to go. Getting closer to being ready for an external paint. Edited May 3, 2021 by Wags Spelling 240ZBUILTBYME 1 Quote
