stevofoxono Posted October 10, 2012 Posted October 10, 2012 Afternoon all, Stumbled across this picture (I know its not the 432 rim but its by KS) and found this listing on ebay for "Rx5" mags. Shame the stud pattern isn't 114.3 http://www.ebay.com.au/itm/Rx5-Mags-14-/330807242965?pt=AU_Car_Parts_Accessories&hash=item4d05a5f0d5#ht_500wt_1288 I know that they're not quiet the same but blacked out and from a distance+squinting they may look the part lol. Is there anything pretty similar with the right stud pattern? Or anyone making repros? There was a pomy making them for 500 pounds a pop but that was back in 2010. I'm pretty content with my hubcabs+steelies but having that extra lil wow would be wicked Quote
Administrators gav240z Posted July 13, 2017 Administrators Posted July 13, 2017 I know I know old thread, but I've been doing more research on these wheels as of late.. Yes RX5 wheels are very similar looking. Perhaps they could be re-drilled to suit 114.3 PCD on the S30Z? Not sure about offsets? The ones being remade were limited and all sold (around 2012) http://www.classiczcars.com/topic/34397-kobe-seiko-rally-wheels-on-ebay/?do=findComment&comment=306522 The photo you have appears to be the later Kobe Seiko Magalloy production run believe that was in the 80s. You can tell because it has the embossed magalloy on the outer rim area. Where as earlier ones didn't have those markings on them. See also: http://www.classiczcars.com/topic/40986-the-journey-of-my-fairlady/?do=findComment&comment=369608 and here: http://motor.geocities.jp/atakausa/miscellaneous.html Here is a set of reproduction Z432 style Kobe Seiko alloys made by XX Auto back (in Japan) around the mid 90's. They appear the same as original except for the center hub area. No holes for the center cap drilled. NB: The raised hub area for the center cap on the Z432 and some export market cars like HLS30 and HS30s that had the D cap here. Here is an actual original (poor shape). and fitted to the Z432 as debuted in Japan. NB: The wheel hub area. Designed to accept these D caps. Ponyo240z 1 Quote
Administrators gav240z Posted August 23, 2017 Administrators Posted August 23, 2017 This just popped up on Yahoo! Japan. https://page.auctions.yahoo.co.jp/jp/auction/x501470933 They look like some kind of reproduction using a standard outer wheel but custom center piece. Ignore the price, that's a fantasy in my opinion. As you can see they look a little 'off' compared to an original wheel. Quote
rajon1972 Posted August 23, 2017 Posted August 23, 2017 I must admit to getting a bit excited when I saw them but then realised they are certainly a little off.. Quote
Administrators gav240z Posted August 23, 2017 Administrators Posted August 23, 2017 I sent some photos to a 3D modeler who came up with these renderings.. Alan (HS30-H) had some made up a few years back in Magnesium! They were also made in 15" diameter as opposed to 14" for better tyre selection etc.. CBR Jeff 1 Quote
24 Dat Posted August 24, 2017 Posted August 24, 2017 Nice, Hmmmm group buy of re-manufactured , I'll be in for a couple of sets of 15x7's or 8's Quote
Administrators gav240z Posted August 24, 2017 Administrators Posted August 24, 2017 Nice, Hmmmm : : : group buy of re-manufactured , I'll be in for a couple of sets of 15x7's or 8's Revive Jalopy in Japan I believe has or does make reproduction runs. Possibly my favorite wheel on the S30Z. Quote
mossy Posted August 24, 2017 Posted August 24, 2017 I reckon it would be extremely expensive to make up a small batch of wheels, unless you maybe had a big market like in the US. Gav you could always contact 949 racing and propose your idea to them, see what they think. I think it was Emilio there started his own business to supply wheels to the mx5 crowd, seems to have worked out very well for him. He could probably give you an idea on costs. http://949racing.com/about-us.aspx Quote
Administrators gav240z Posted August 24, 2017 Administrators Posted August 24, 2017 Thanks Mark, I have no ambitions to make these wheels yet. As you say that would be an expensive project and at this stage I should focus on getting the body work done and the motor running on #150. Then I can worry about those luxuries. mossy and OdinZ 2 Quote
PZG302 Posted August 25, 2017 Posted August 25, 2017 Yup, very expensive to get small runs made. When TCM started up the competitors approached minilite to get the original minilites remade in 15x10", apparently was near eye watering for us mere mortals, and the needed to make some horrendous numbers to make it worth while, but for those guys the numbers made sense. I approached rebel wheels in Unanderra a few years ago to get some rebel 15x8 wheels made, was told they do batches when they get enough orders and they were around $700 a piece and that was near 15 years ago. I have no idea if they can still be ordered. Quote
Brabham Posted August 26, 2017 Posted August 26, 2017 Dragway may be worth talking to as well. I would love a set of Kobe Seiko works wheels in original dimensions, prefer the works 4 spokes to the rally wheels. You could add extra material to them so they would not have to be lifed. Quote
Administrators gav240z Posted August 30, 2017 Administrators Posted August 30, 2017 To continue on.. here is the Z432 center caps. http://motor.geocities.jp/atakausa/miscellaneous.html NB: No D in the center. The cap on the far left is original, the rest were reproduced later. Also not quite the same but these are very similar to Italian wheels I saw on a Fiat 500 (Cromodora wheels) Which were also found on the Ferrari Dino's. Quote
Administrators gav240z Posted August 30, 2017 Administrators Posted August 30, 2017 Original Works Rally Mags made by Kobe Seiko. In this photo you can see the unique rotating nuts. What they look like on an S30Z. Good comparison shot of 3 versions. Left = Original Z432 rim. Middle = Later reproduction wheel with different center hub (accepts wheel cap). Right = Later reproduction (mid 2000's) and scaled up to 15" diameter. Has cutouts in spokes like the works rally wheels. Original Kobe Seiko wheels on Portuguese delivered HLS30. Pristine set of Z432 style wheels. Good reference post here from Alan (HS30-H) also. http://www.viczcar.com/forum/topic/13347-cams-australia-and-eligible-parts-for-s30zs/?p=157558 Quote
Administrators gav240z Posted August 30, 2017 Administrators Posted August 30, 2017 Another Kobe Seiko wheel design is the "Gotti" wheels. http://www.viczcar.com/forum/topic/6711-researching-a-le-mans-260z-info-appreciated/?p=77723 And here are the 8-spokes which to quote Alan everyone and their dog confuses with Watanabe's. See here: http://www.viczcar.com/forum/topic/14558-the-ebay-thread-2-post-ebay-parts-here/?p=194982 Quote
Mr Camouflage Posted August 30, 2017 Posted August 30, 2017 Another Portuguese 240z with these wheels: http://ozdat.com/forum/viewtopic.php?f=66&t=34623 gav240z 1 Quote
1600dave Posted August 31, 2017 Posted August 31, 2017 "Unique rotating nuts" - are these available as reproductions anywhere ? Or any alternatives ? Stew Wilkins sells "Nissan Works Type" wheel nuts (at $20 each...) which I have been led to believe are rotating ones to suit the Enkei "Works" rally wheels used in the late 70's / early 80's on stuff like Stanzas, curious if these are the same as the Kobe Seiko nuts and whether I can get a set for les than $360. Reason I ask is that I have half a dozen of the Enkei wheels but need a set of nuts. (Perhaps I should rephrase that last bit.......). May be useful info for anyone with the Kobe Seiko wheels as well. gav240z, andyk_79 and ScottyD 3 Quote
Administrators gav240z Posted August 31, 2017 Administrators Posted August 31, 2017 Do the ones Stewart Wilkins sells look like (deez nuts) this? http://www.classiczcars.com/topic/23900-datsun-240z-vs-fairlady-z432/?do=findComment&comment=525095 Quote
1600dave Posted August 31, 2017 Posted August 31, 2017 (edited) Don't know, he doesn't put pictures against the items he has for sale on his website. He does have a generic pic on the top of each page of items, the one on the "Nuts" page shows (amongst others) a nut that looks suspiciously like that. I might have to bite the bullet and buy some. Edited August 31, 2017 by 1600dave Quote
Administrators gav240z Posted August 31, 2017 Administrators Posted August 31, 2017 Yes that 1 on the left looks very similar. Quote
csp-311 Posted August 31, 2017 Posted August 31, 2017 Gav, In post 13, the description of the 3 wheels is slightly wrong (and adding more info) Left, original Kobe Sieko "z432" wheel (which came from Portugal). Middle, is a Magalloy wheel, the same as the top of this thread. Made by Kobe Seiko and to their design, as it does differ from the "z432" or rally wheel. 14" and came with centre cap. Right, this one of the 15" magnesium Kobe Seiko rally wheel replicas that was made up here in the UK. My understanding is Alan had a hand in getting these made, but wasn't the driving or money force. They were made in aluminium too. How do I know, the photo was taken by me as they are my wheels! Talk of making reproduction will need deep pockets and time, and I don't know how it stands in Aus. but here the 15" replica rally wheels had to be tested as it was a different wheel to the 14" (correct me if I am wrong Alan) from a safety aspect (crash tested). There is a lot of work needed to get these done. Cheers Ian gav240z 1 Quote
EJ101 Posted September 2, 2017 Posted September 2, 2017 I had a LJ Torana XU-1which I sold to a bloke back in the early 90's.He found me on facebook recently and has still got the car. The car had the original 13x6 Sprintmaster wheels. Back in 1973 the XU-1 race cars ran 13x8 & 13x9 magnesium sprintmasters. I always wanted a set but they were extremely rare as they were made in small numbers for racing only. This bloke also wanted them and so he went about getting some 13x9 made in Thailand. He hasn't said how much they cost or how many he is getting made, but he has a pair. He didn't get the 13x8 made. They are made by a proper wheel manufacturer in Thailand and are alloy, not magnesium. He managed to get an original wheel which was 3D scanned and modelled. So it is possible. I'm just surprised that with the popularity and value of Zeds that a wheel manufacturer such as Enkei hasn't managed to put the Kobe seiko style wheel in their classic lineup. Quote
HS30-H Posted September 2, 2017 Posted September 2, 2017 I'm just surprised that with the popularity and value of Zeds that a wheel manufacturer such as Enkei hasn't managed to put the Kobe seiko style wheel in their classic lineup. I think it's probably fair to say that 99.999% of S30-series Z owners are oblivious to their existence and their history. Anybody who simply must have a set - either of the 5.5j x 14" OEM wheels for the 432, or the 7j x 14" 'Rally Mag' - will probably end up with them somehow. There are long gaps between reproduction batches, but they do get made from time to time. I'd rather not see them get the pile-em-high, sell-em-cheap Rota treatment myself. It'd be nice if at least some things were kept sacred... gav240z and CBR Jeff 2 Quote
Administrators gav240z Posted September 2, 2017 Administrators Posted September 2, 2017 I'd rather not see them get the pile-em-high, sell-em-cheap Rota treatment myself. It'd be nice if at least some things were kept sacred... That is my sentiment also really, if reproductions are made I would rather see them made as a quality or faithful reproduction and in appropriate sizes etc.. than suddenly flood the market with cheap imitations which would only make it more difficult to verify originals. What makes them special is also their rarity. Quote
rajon1972 Posted September 5, 2017 Posted September 5, 2017 I have searched hi and low for these wheels for years and are very rare in Australia. Only in recent years have I managed to stumble on some which I was lucky enough to purchase. Quote
Administrators gav240z Posted September 5, 2017 Administrators Posted September 5, 2017 I have searched hi and low for these wheels for years and are very rare in Australia. Only in recent years have I managed to stumble on some which I was lucky enough to purchase. Rally version or z432 version? Quote
