Wags Posted May 26, 2022 Posted May 26, 2022 1 hour ago, gav240z said: So are you going to find a donor rear half? Haha great minds…I was thinking exactly that but just didn’t want to say it. gav240z and OdinZ 2 Quote
Agno Posted May 26, 2022 Posted May 26, 2022 after all that work to get the car straight that has to be seriously disheartening Wags 1 Quote
Wags Posted May 26, 2022 Posted May 26, 2022 (edited) This is why I would personally never buy a classic without the view of restoring it. At least he has C.A.R on the job. A lot of other shops would just end up putting makeup on a pig, whereas Locky does it to last. Edited May 26, 2022 by Wags Rephrase C.A.R. and gav240z 1 1 Quote
C.A.R. Posted May 26, 2022 Author Posted May 26, 2022 7 hours ago, gav240z said: So are you going to find a donor rear half? Wags and gav240z 2 Quote
Oliphips Posted May 26, 2022 Posted May 26, 2022 On 5/23/2022 at 2:14 PM, C.A.R. said: Dodgy sods... geez some people are rough Quote
C.A.R. Posted June 15, 2022 Author Posted June 15, 2022 The RH side seemed like a reasonable place to start, so we repaired the top of the sill first: The top was cut out, and piece was folded up and welded into place: gilltech, 240ZBUILTBYME and Mike_F 3 Quote
C.A.R. Posted June 20, 2022 Author Posted June 20, 2022 RH dogleg was next. The back of the sill was repaired, then a new dogleg was folded up, welded into place and linished smooth: (I've since pulled the slightly sunken weld out & re-linished it.) Mike_F, Dragonball240z, 240ZBUILTBYME and 3 others 5 1 Quote
hmd Posted June 21, 2022 Posted June 21, 2022 @C.A.R. when are you going to get your PhD in rust? We can call you Dr Rust? Quote
C.A.R. Posted June 21, 2022 Author Posted June 21, 2022 (edited) The RH rear lower quarter was a mess, and the inner panel was rusted though as well. No choice but to replace both, so Graeme (my employee) tackled this while I repaired the panels... Edited June 21, 2022 by C.A.R. gilltech, Dragonball240z and Mike_F 3 Quote
C.A.R. Posted June 29, 2022 Author Posted June 29, 2022 Repeat on the LH side with some shrinking required for good measure: 240ZBUILTBYME, gilltech and Oliphips 3 Quote
C.A.R. Posted June 29, 2022 Author Posted June 29, 2022 The area around fuel door was rusted through, so I fabricated a new section to replace it: Yuck...: gilltech, 240ZBUILTBYME, Dragonball240z and 1 other 4 Quote
C.A.R. Posted June 29, 2022 Author Posted June 29, 2022 (edited) Onto the LH floor - I worked out the cost for new KFVintageJDM floor pans + freight + installation, and the figures said it was going to be cheaper to fabricate & install patch repair panels: I'm not taking credit for this - it's Graeme's handywork. Edited June 29, 2022 by C.A.R. KatoKid, OdinZ, 240ZBUILTBYME and 3 others 6 Quote
C.A.R. Posted June 30, 2022 Author Posted June 30, 2022 (edited) RH footwell: Then the rails were removed: Also the RS30 LH sill (which we'll be modifying), floor rails and bonnet hinge gussets arrived from @kfvintagejdm: Edited July 1, 2022 by C.A.R. gilltech, OdinZ, Dragonball240z and 4 others 7 Quote
C.A.R. Posted July 11, 2022 Author Posted July 11, 2022 (edited) The back of the RH floorpan - under the rear seats - was rusted out, so the section was cut, rust treated, then new sections were fabricated and welded into place. Then the RH rail assembly could be installed. The RH door hinges also came back from Leon - they've been been re-pinned and re-bushed, along with a new roller and leaver: Edited July 11, 2022 by C.A.R. gilltech, JDM-TOY, Dragonball240z and 2 others 5 Quote
C.A.R. Posted July 26, 2022 Author Posted July 26, 2022 A section of quarter panel below the LH quarter glass had rusted out, so I fabricated a replacement section, cut the old section out & welded in the new patch: It just needs a little tapping about to smooth it up, so I'll come back to it in due course. The LH sill was rusted out at the front and back, along with accident damage. We decided to remove it & replace it with a new one, but as it was a Bus, it's not that simple... Cut off, de-rusted and KBS'd: I bought a 260Z/280Z LH sill from @kfvintagejdm, then cut the end off and fabricated an extension. This was then KBS'd inside and welded into position: gav240z, OdinZ, gilltech and 7 others 10 Quote
C.A.R. Posted September 20, 2022 Author Posted September 20, 2022 Due to me taking a little holiday & the workshop being busy, I haven't had time to update this thread. Suffice to say we are done & Michael is collecting the bodyshell shortly. Here comes the photo dump: Yes, I made a new rear valance: Hot Tip: RS30 and GRS30 rear tail light panels ARE NOT the same. They are deeper (not wider as generally thought). 240ZBUILTBYME and gav240z 2 Quote
C.A.R. Posted September 20, 2022 Author Posted September 20, 2022 Finally the 'piste de resistance'. The RH door skin was stuffed - dented to the moon & rust holes everywhere. I couldn't get a decent rust / damage free Bus door locally, so I repaired frame which only needed a small section at the top & bottom... ...then made a new door skin from scratch. I'm not taking full credit - my employee Paul did 75% of the fabrication. Taking a paper pattern off the old skin: Cut out some 1mm cold rolled steel: Wheeling & folding up the new skin: 'Blocking' in the handle recess: Ti And fitting the skin to the frame: NickF, gilltech, gav240z and 5 others 6 2 Quote
240ZBUILTBYME Posted September 21, 2022 Posted September 21, 2022 Amazing work @C.A.R. !!! What was the coating for inside the cowl? Kbs? C.A.R. 1 Quote
C.A.R. Posted September 21, 2022 Author Posted September 21, 2022 20 hours ago, 240ZBUILTBYME said: Amazing work @C.A.R. !!! What was the coating for inside the cowl? Kbs? Yes. KBS Rust Seal. Quote
C.A.R. Posted September 23, 2022 Author Posted September 23, 2022 And done. I forgot to mention, the hatch was stuffed but I obtained an 'ok' replacement that needed some minor rust repairs in the screen lip and lots of panel beating across the deck... AndBir, 240ZBUILTBYME, OdinZ and 3 others 6 Quote
Administrators gav240z Posted September 23, 2022 Administrators Posted September 23, 2022 Certainly left better than it arrived. C.A.R. 1 Quote
Agno Posted September 25, 2022 Posted September 25, 2022 Thats some high quality work, love that door fabrication! C.A.R. 1 Quote
