HomeBuiltByJeff Posted April 18, 2019 Author Posted April 18, 2019 It is finally time to do something a bit more permanent about my spray booth. Quote
HomeBuiltByJeff Posted May 1, 2019 Author Posted May 1, 2019 Many of you have been asking me what is happening and I finally have an update for you, and some info on where I am planning to go in the future. Quote
Riceburner Posted May 2, 2019 Posted May 2, 2019 Thanks for posting all the progress Jeff, it must be a big effort doing all the video work as well as the build. Keen to see how it goes on the dyno! HomeBuiltByJeff 1 Quote
HomeBuiltByJeff Posted May 11, 2019 Author Posted May 11, 2019 In this episode I delve a bit deeper into the tuning issues on the 680G. Quote
HomeBuiltByJeff Posted May 15, 2019 Author Posted May 15, 2019 I finally sort out the running issues and no surprises it was my fault. We then tune it up on the dyno and get that final figure. Enzo 1 Quote
MaygZ Posted May 16, 2019 Posted May 16, 2019 Good work mate. I love seeing the joy on your face. I know that it doesn't take wind resistance into consideration but 148Hp at the wheels and 170km/h is nothing to sneeze at. Well done. HomeBuiltByJeff 1 Quote
HomeBuiltByJeff Posted May 18, 2019 Author Posted May 18, 2019 Now the car is running I just have a few bits and pieces to sort out before I can get it registered. Quote
HomeBuiltByJeff Posted May 22, 2019 Author Posted May 22, 2019 I finally have my meeting with the engineer to see if he is happy to sign off on all of my modifications. Fingers crossed. Enzo 1 Quote
HomeBuiltByJeff Posted June 27, 2019 Author Posted June 27, 2019 The 680g is finally registered and in this episode I get to take it out on the road. Spoiler, it sounds awesome! AndBir and Enzo 2 Quote
Administrators gav240z Posted June 27, 2019 Administrators Posted June 27, 2019 1. They make tappet noise at higher rpm. That's normal. 2. The windows not winding up and down right? Did you have 260z or 240z doors? I found on my 72 240z it had a 260z door passenger side and was modified to fit a 240z regulator but it's not right and hence the window is a pain to put up and down. 3. Cold start shouldn't be a problem, at least it isn't on my Mikuni's even without choke. A few squirts of the accelerator pumps and it seems to fire up fine. 4. Have fun. HomeBuiltByJeff 1 Quote
HomeBuiltByJeff Posted June 27, 2019 Author Posted June 27, 2019 The I thought one was a 260 door, but I think I worked out it wasn't (can't remember exactly now), but the bailey channel is complete toast, and I know as soon as I changed it on my 911, it made a huge difference, so I at least hope that is the bulk of it I might have had a bit of a baffle in the exhaust just to make sure it was quiet enough for rego, that I may have only taken out today. So if that was the case, the tune may have been affected by that Quote
Administrators gav240z Posted June 27, 2019 Administrators Posted June 27, 2019 Yes bailey channel / rubbers will make a huge difference. RE: OER carbs, no idea what they are like with cold starts or choke mechanisms? You said they didn't have a starter circuit? But I found that my Solex/Mikuni 44s didn't even need the starter circuit hooked up. Just a pump or 2 of the accelerator and away she goes. I actually find it starts a lot easier than with the factory SU carbs which often have sticky chokes by now anyway. Oh and re: tappet noise, they do make a lot of noise but remember it's an old engine. Also later P90A heads had hydraulic lifters which were a lot more quiet, but failed over time. Hence it's better to have noisy ones that work. Quote
HomeBuiltByJeff Posted June 28, 2019 Author Posted June 28, 2019 The issue I find, is I give it a few pumps, but it coughs and misses on at least 2 cylinders and gets worse. If I then pull the plugs and give them a quick clean it is Ok, but it will still generally have a miss, so I have to hold some revs into it to get it to clear it's throat and then it's fine. gav240z 1 Quote
RLY240 Posted June 28, 2019 Posted June 28, 2019 1 hour ago, HomeBuiltByJeff said: The issue I find, is I give it a few pumps, but it coughs and misses on at least 2 cylinders and gets worse. If I then pull the plugs and give them a quick clean it is Ok, but it will still generally have a miss, so I have to hold some revs into it to get it to clear it's throat and then it's fine. I find the main thing is to make sure the bowls are all full, on mine that means perhaps 10 cycles on the ignition to reset the relay if it's been sitting for more than a few days. Putting an override on the relay for priming is a good idea (that I should steal). Then two full pumps on the pedal should be enough for a cold start but it will need some throttle to idle on that cam while cold unless you have the idle set quite high. Mine is still a pig to start when cold regardless but the above certainly helps. But it's still a whole lot better than my road car on SU's which fouls the plugs and takes 5 mins driving to really clear. Roger HomeBuiltByJeff 1 Quote
AndBir Posted June 28, 2019 Posted June 28, 2019 15 hours ago, HomeBuiltByJeff said: so I at least hope that is the bulk of it Cleaning and then adding white grease to the window winder roller guides/channels? should also help. HomeBuiltByJeff 1 Quote
AndBir Posted July 5, 2019 Posted July 5, 2019 From your last video, if you find you do need a new oil pressure gauge then try Rob at : http://www.zfactory.com.au/contact.htmlhttp://www.zfactory.com.au/contact.html HomeBuiltByJeff 1 Quote
HomeBuiltByJeff Posted July 6, 2019 Author Posted July 6, 2019 20 hours ago, AndBir said: From your last video, if you find you do need a new oil pressure gauge then try Rob at : http://www.zfactory.com.au/contact.htmlhttp://www.zfactory.com.au/contact.html Thanks mate. It is actually working ok now. It does read low, but it reads, so I can still see what is going on. Quote
HomeBuiltByJeff Posted July 13, 2019 Author Posted July 13, 2019 It was a long build, but my Datsun 240z affectionately know as the 680g is done. Here is the whole build from start to finish. my_mad_z and RLY240 2 Quote
HomeBuiltByJeff Posted July 17, 2019 Author Posted July 17, 2019 This is my 3rd attempt at repairing my dash and hopefully the last. This time I have a go at flocking. Quote
AndBir Posted July 17, 2019 Posted July 17, 2019 Re the Bailey Channel, the Rare Spares replacement bailey channel does go the whole way round the window channel. The "in door" channel had a felt / fiber type material (at least it was on my 260Z) : Quote
HomeBuiltByJeff Posted July 17, 2019 Author Posted July 17, 2019 Still not happy with the windows. They wind up and down slightly better, but they are still not right. Quote
Linton Posted July 18, 2019 Posted July 18, 2019 did you put some rubber grease on the sliders and lubricate the winder mechanism? that will help HomeBuiltByJeff 1 Quote
CBR Jeff Posted July 18, 2019 Posted July 18, 2019 What condition were your rollers in? I just replaced the 3 on each regulator with the Bunnings option. Jeff HomeBuiltByJeff 1 Quote
HomeBuiltByJeff Posted July 18, 2019 Author Posted July 18, 2019 4 hours ago, Linton said: did you put some rubber grease on the sliders and lubricate the winder mechanism? that will help I did use some white grease on the sliders and I spent a fair bit of time trying to adjust the alignment. The window is still not tracking straight, so I think it needs somefurther attention. 1 hour ago, CBR Jeff said: I just replaced the 3 on each regulator with the Bunnings option. Jeff Bunnings option? What option is that. Please tell Quote
CBR Jeff Posted July 18, 2019 Posted July 18, 2019 https://zclub.nz/viewtopic.php?p=20818&sid=5d62fecbc695791fdf2d1796f2e5ee19 The rollers are for sliding doors. There is a large selection of them in most bunnings. I used the RollTrak ones. The bolt is a 1/4 thread and from memory the rollers were 20mm or 25mm. They may have been # "4361"? Jeff Quote
