back off your tyre pressures, say around the 24-28 psi
lay off on the shock & swaybar on the front (softer),
add more front castor with shims and see how it goes (steering will get heavier, but bites on initial turn in more, also helps the inside of the tyre to)
toe out will help the car load the front outer corner gradually, not snap & loose grip
cant go a stray with camber, within in reasonable limits, keep an eye on tyre temos & wear patterns.
Dont go widest tyre the rim can take as you only end up with profile 'roll' not cornering load on sidewalls.
from personal exp., id stay away from the khumo's for trackwork or anything with high lateral loads as their sidewalls give way far too easily and you end up doing as you say stripping tread from the first groove out to the walls, try yokis, i havent yet had, seen heard any neg reports of them, however $$$ may or may not be a problem for you.
Lurch, please feel free to add, shoot down in flames, and/or make any suggestions/comments. as remember we are talking about another racing bus driver here, (more up your alley than mine.)
chers nat0
