nat0_240_chevZ
  1. mmm sounds like the higher speed stability could be helped with the rear end, maybe new wheel bearing and adjustable toe on the rears, makes a huge difference even doing highway speeds, i know its not your car but just a thought for everyone else to consider.
  2. try any l series manual throwout sleeve ie l4s 200b 180b stanze etc etc. i also realised the rb and the sr forks, sleeves and slaves are the same or interchangeable, and swapping with the L would not suprise me either as these boxes can be used behind the L with a front case swap. nato
  3. id sell you some for that price, as they only cost me 45$ from ebay delivered, with 95-98% pads. EBC still do green syuff pads for the hilux calipers, however the now greenstuff is the best available except for firehawks ex US but much of a muchness. i have solid version with 32 & 38mm pistons aswell as vented version with all 38mm pistons. the smaller pisteon versions require less fluid in comparo to the 4x 38mm. meaning you can ge away with a 15/16' MC instead of the patrol 1"MC. dont try and use the 7/8" MC as this is will be spongy and almost dangerous as mentioned above. nato
  4. :-\ have one on a f54 block not doing much for me at present!!!!!
  5. yes they do fit, easily too. Do NOT go a button typr clutch driven plate (friction disc), this is a comprimise type arrangement where the are trading in friction area for clutch pressure (ie bite, by not increasing the actual clamping force of the pressure plate)$ go for a high clamping force pressure plate with either a carbon metailic or carbon/organic type friction/driven plate. NEVER ever go for an extreme button clutch (or other brands similar) as they are crap, their pressure plates warp due to overheating caused by reduced friction area of the driven plate resulting in excessive heat, like under rated brakes copping a caining. Most nissan clutches can be used from the l4's through l6's rb, sr ca fj etc etc etc as nissan has blessed its owners with interchangeability. my prev built l24 had an r32 gtr clutch complete, the dowles wernt drilled 100% concentric from prev owner so there was a slight shudder under heavy launches. but it would always give 100% lock up evan at 7600rpm all day long... nato
  6. really only seen them on 260's 2 & 4 seaters. none of my 240z's ever had them. but one of my 2+2's did
  7. just make your own adjustable. its easier than you might think. or get another good pair do the work and then swap them over. machine the step down on your existing rod to the threads major dia, then run the threading die all the way down to you new step, run 2 slim nuts to locate the washer position and same on the other dide, only need to ad 25mm of extra thread to the rod. but if you want to make them longer then a new rod would be req'd as you only have about 10 - 15 mm you can extend the existing rods with shims!!
  8. well if its a 2+8 then just replace the rear srut tops only with either a front or an early 260 or 240 strut top, instant 1.25 inch drop with no effect on bump/suspension travel, think of it as a free 1' drop @ no expense of anything else. If youre not aware the 2+2 rear stru tops are about 2.75" high where the fronts and the earlier models are only about 1.5" people normally dont know this so i have to bring it up everytime someone wants to lower their car!
  9. still awaiting a response from the seller via email!!!!
  10. Shave smchave. Shave as much as you like untill you reach minimum recommended thickness of the head. it just means you will have less life in respect to facing and re-facing for future rebuilds. You can either shim the cam towers with the appropriate shims, (which i happen to make!! ) or slot the cam chain guide holes to allow a bit more adj to take up the slack in chain and to maintain tension from the cam chain tensioner. (or remove the factory tensioner and replace with a far superior adj ubit as seen on kameari engine works site and another 2 or 3 usa sites somewhere, uses the block off section @ front of head. allows these motors to safely run at 11,000 rpms, with resq'd mods of course.) Piston to valve clearance does have to be considered, bit i ran (about 5 - 7 years ago) l24 dished pistons, N42 head with 2.25mm shaved, about 10.8-11.1 CR and this thing hummed, high revving high comp, big advance too, just had a small amount of ping when laboured at low engine speeds, but you never would do this unless just lazy with gear changes, (shouldnt anyway ya lazy pug). lets just say that motor taught a few of the commy v8 fellas a few things from a 1/2 size six cyl, all in a 2+2 mind you too. Mind you this was back when the VR-VS hsv only had 185-195kw anyways stuck with them and nudged a few off that werent driven or mantained very well. The destruction however of this motor was the dizzy nut comming loose, timing went balistic and melted a piston @ 8500rpm, however the head was fine. Piston replacement and light hone was only costing me 200$ but had to sell this and my 240z to fund a new education!! hence where i am now! shaving does not pose any other cooling issues except the higher comp makes more heat, but it certainly does not soften the head material, overheating the motor does. look i found it works wonders, if i am to do it again iw ould only shave 1.5-2.0mm off depending on pistons and desired comp ratio, but would run forgies with a slight peanut on the top to quench even harder, oh yea did i mention i ran it on 92 ron? and on 95-98 it went even better with less rattle if you were lazy. nato
  11. CHANGE THE tie rod to lower cont arm angle through bump travel. ie bump steer, as it bumps it wants to steer or 'wander' lower the lca pickup @ the strut or lift the rack postion a lil, try to maintain parallel between the 2 arms, however some bump steer is desirable, but not the whole hog Z bump steer. nato. ps give me a buzz if u like, chat more about it.
  12. ever think its had a hit like all of the zeds available, except those mysterious ounes in country vic somewhere. check the chassis dimensions, and checkthe rails for parallelism, also squarenes of the whole front end. this would be my first point of call, as even a small gutter hit can chip your bonnet on the guards and kink severely the rail @ the tc rod support. nato
  13. yep yep and thanks, wit til its painted, going all out, as a good mate is a killer painter, ill get him to do final prep, all for favous, i swap your engine u paint my car!! lovin it!
  14. how do you explain the low oil level, to her up and see how you go, you mates suggestion IS plausable however, and likely. but doesnt explain the low oil level, keep us all posted nato
  15. looks similar to the one one of my mates sold, her have a look!!!! http://thezgarage.com/forum/viewtopic.php?t=1222 early series 1 too # 230, had a massive l28 turbo, but was replaced with a strong l28 na with a 350 holly and pipe etc etc, has some sik recaros in but!!. id just go the t56 6 speed from the us camaro, a straight bolt on and far cheaper, just a lil harder to find, i missed ones on ebay for 1300 ages ago, and havent looked since as im ditching my engineered 283 sbc for a nissan v8 as the chev is a bloody boat anchor!!! have some vids on utube when the chev e=was in it running, but poorly, had a farkeded fuel pump, but burnouts were nice and easy!!! nato
  16. basically same box, some have diff ratios, some dont. later 280zx's have new shifter bearings and mostlikely less use overall, main probs with shifter are external of the bok, ie gearleaver bush and clevis pin, but the can have bad syncros, shifter/selector collars and shifter linkage dentents which click and hold the gear some what, but the worn synchros on 2nd are most common, can be sort of fixed just by flipping the collar around so 1st has bad sync, but how often should you really downchange to 1st, nato!!
  17. try getting your arm around and use the spanners above the t/shaft. use a bigish screw driver through the uni to stabilise if you cant any other way, ie handbrake and 1st gear. nato
  18. get a vh45 de front cut, 340crank hp stock which should give you about the figure youre after. cost me under 2k delivered from qld to adel, and then to put it in about that again. but nearly all work done by myself and a mate. so its a realistic figure. if you dont plan to do it yourself allow about 3-5k, no matter which way you go!!! nato have a look @ this
  19. OK, IVE HAD THIS ON A FEW ENGINES, NOT ALL L SERIES, IT LOOKS AND SOUNDs LIKE A High (sorry bout caps) high pressure oil leak from the timing cover, could be either gasket or a crack in the alloy cover itself over on the passenger side. now YES your oil pump is on the drivers side but im almost certain one oil port goes over the pass side, now this is/was where my g/f's gemmi was leaking as was an ol L4 of mine (datto 200B, ie L20). Track down the source by degreasing and spinkling baby powder around the timing cover and oil pump (as it also could be spraying from there). yes baby powder the lot so it looks like casper (or use cooking flour??? up to you.) And as for highway driving, this increases you oil pressure to its near max, as oil pressure (if your pump is good and oil too) doesent get much greater after 2000 rpm just flow increases, so prolonged highish rpms makes the oil piss out in a very fine spray, and gets blown by the engine fan all over the engine bay. whatta mess. all i can say if its the timing cover replace, if its just gaskets also replace. its not an easy job and yes can be done without removing the head, see workshop manual, but can be very tedious. after doing mine the spray was gone and was able to keep a clean engine bay!!! hope this helps, please feel free to ask any Q's no problems, nato
  20. i swear him and his son were now running 6 tb's with both running motecs, but then i thought i was tripping, anyways guys, he runs no rear sway bar, and a whole bunch of old time exp, which is what makes him,quick!!! i remember the classic adelaide rally a few years back where he ran 2nd outright only to a porsche 959 4wd turbo, yes he lives in the very same hills that the rally is ran in but thats not the point, he would easily tripple my age and probly ayleast double my age in exp with Zeds, here and aus wide known as the Z king for work, but he will sure charge you to do any work on your car, and i mean bling blow!!!$$$ nato ps cant even entirely remember what i said in the edited post above, i do remember it being cheeky but certainly not facetios. NOWNOW boys easy!!!, no need to get facetious!!!
  21. /me opens up a can of worm's' Edited by Lurch - that's not nice Nato why the hell was that edited lurch, change it back, i was making reference to someone that drives a zed with a v8 in it like a Z with a v8 in it!!! and NO, the only thing dish has to do with anything is compression volume ie your displacement ends up compressed into your comb chamber , dish included, ie volume (displaced) div by combustion chamber volume = comp ratio, the dish is always in the same place regardless of bdc, tdc or half stroke. Think about it a lil bit more if i push a cup up and down in a cyl the only volume i displace is that i move the cup, not the cup volume. displacement is only that which you dis-place ie bore area x stroke x # of cyls = displacement. swept volume is yoou arctual displacement, your dish and combustion chamber is noted in tech papers as clearance volume. the intake strkoe (even @ 100% eff)never fils the dish as it never eptied it! so mainly takes part in mixture change, ie the intake charge has a slightly larger volume to mix with which therefor changes the intake mixture slightly, this is compensated for in the tuning and is why they used dished pistons in the design of the heat engine among other reasons too! Zeddophile, nothing personal taken, just a good topic for disc, sorry to thread jack guys, no lets get back onto petes quick "stock" class lap times!!! AND PUT MY POST BACK!!! i think my contribution to this thread has been more than useful, why is my opininon/jokes any less welcome than anyone else's, who is the softee here?
  22. You've gotta be joking Craig!? The ONLY driving style he'd be doing those times is, is with clean, fast lines while keeping up Maximum corner speed. Pushing hard yes. But 'Power Sliding'? Thats a sure fire way to loose time on the track. Come Go-Karting with me & I'll prove you my point /me opens up a can of worm's' Whats not nice? i also own a v8 Z and lets just say being lazy you can drive it slightly loose which feels very fast but the laptimes will beg to differ, but driving a high powered Z car on the knife edge is so thrilling, well more thrilling than grip racing. Why do you think those silly drifters took off in their own class! Even peter has mentioned that even though the drift racing is slow, its one hell of a fun ride aswell as good for the spectating crowds. something F1 would benefeit from im sure we would all aggree!!
  23. ill see what i can come up with. trust me when i say nothing is as it seems on his cars. its just really funny how people are flawed when thay have a quick look over his car. rear brakes, well how much do they really do when you are 11/10ths on the picks, good quality shoe and pad compouds do more than anything else in a braking system besides area!!!! adequete cooling & pad compound is the key on the fronts (as it is in any brake and clutch system). rules are made to be bent and maybe snapped into 20 pieces LOL. Pete is an old fart that knows almost every engine components combo there is within and outta the "rules" its like trying teach the creator hoe to make something he already created from scratch. old dog and old tricks. reminds me of the old "mothballs in your fuel to up the octane" trick, something you grandpa used to do when he was a kid!!! nato
  24. N42, bigger valves (than early e88) , hardened valve seats, have the perfect chamber shape for hp, just need to shave he pants off it if using dished pistons, or 1-1.5mm if using flat tops, oh and try som someder singh gooves (google it) to increase compression turbulance. ready for ULP (lead free petrol of any sort) newer, ie less overall wear/use (hopefully). better materials being newer. plentifull supply as the 280zx had em. should i keep going??? PS if using carbies, plug up the injector notch to reduce intake charge turbulating prior to getting past the valve seat, by either welding or epoxy resin. cheers nato
