nat0_240_chevZ
  1. bad on old seals however, makes old systems leak almost straight away if the seals in the comp etc are not compatable, they break down rapidly and needs replacing throught the system, o-rings and other rubbers are worst hit!!! nato
  2. if they were just silver then probly not an aussie adr comp plate i would be sure of!!!! black and silver rigy dig style ones, most probably otherwise they are for US market only. (i would assume as US selling Aussie plates is unheard of) nato
  3. have a comp off a 2+2!, cant say its original but! especially not for the 240z! some late model a/c would be nice just need a good option that is small n compact, easy to wire in and integrate mechanically etc etc etc. nato
  4. nat0_240_chevZ
    l28
    look when i get time, alot of time, i will do up stencils to give to any reputable engine builder to allow them to easily weld up/grind etc to 'meld'the 2 together. problem is come time to replace one or the other!!! (work all over again) These stencils will be a meeting between the rb and l-series heads as the water ports on rb's are like a crescent and the l's just an oblong hole slightly rounded, so somewhere in the middle grond. However it is just as easy to pop a complet rb engine in anyways. Im pretty sure you can grab an rb25de non turbs and do a legal conversion!!, then just build it up to the turbo spec and mantain the DE engine #'s and hand over that to the piggas' only thing is this would be ok for SA but having roadworthys etc would probly kill it! nato
  5. yep, im interested, mostly in the rears, have not heard of the saab upgrade!!! which willoods you use?? superlite 4 pots or integra 4 pots??? or other? cheers nat0
  6. nat0_240_chevZ
    l28
    well, yes they do 'bolt up'and cyl spacing is ok, -however there are problems with the rear oil gallery lining up -water ports all over the head are troublesome ie rb=long, l=short little ones. -also the cam drive mechanisme needs to be changed/adapted/altered, ie belt/chain. -also the rb head would require water port/radiator/thermostat positioning issues. have looked into the twincam variants previosly but untill i have plenty of time on my hands not going to attempt it. easier way to do would be get an lseries headgasket ontp of the rb head and mark out all oil, water etc galleries and take to a head reconditioner, weld up and die grind to suit, (may have to run an external oil line back to sump/turbo etc etc). any more info just ask, getting a lil tired. nato
  7. yea i think i have one of these mirrors on a shell floating around in my workshop!!! not painted or anything but i reckon they look dull and lack the z thing about them, if it pops up ill take a pic, but cant be bothered otherwise to hunt for it!
  8. yes you were, have a look at this link!!!!http://viczcar.com/forums/viewtopic.php?t=1216 thats a wrx seat in there, still needs bracketry made, when i gat around to it by my mates in no rush!!!! nato
  9. get vented rears, also i asuume the honda rotors are vented, JUST RUN AIR DUCTING INTO THE BACK OF THE ROTORs!!!!! Golden rule is airflow, cant cool them when you dont have airflow!!!! Rears dont get alot of abuse, even in racing, 80% of the cars load is on the fromt in an aggressive racing stop.. AIR DUCTS!!!! try it first before any mods and post your results please this will be an interesting thread from then on!!!! nato
  10. tacho needs either a loop through it or an earth connection from the coil/dizzy. either run a wire from neg side of coil to the back of the tacho or loop the power of the coil through the tach, not familiar with the ZX setup so try option 1 first. Be warned about the power loop to the tacho if not wired this way may cause damage to your tacho!!! U HAVE BEEN WARNED!!!!
  11. i have an R6 yammy motor for a dangerously fast kart!!!!! about 90kw@12,000rpm!!!! For Sale!!! make an offer around $1200 lol :lol: :lol:
  12. na nah, i got simmons on mine, 16x7fr and 16x9rr, thes are 18x9 work wheels, vx ss i think they are, from a GTR r34. they just protrude from the guards but have zg's for them but need another inch or so width to fill them (zg's) completely. nato
  13. havent decided yet, something pulsar, maxima pintara or the like or just go for either s13-s15 or r31-r33 or similar as they have similar layouts which will utilise the Z top mount but with the offset strut to allow wider wheels, camber adj from a factory item also, offsett will need to be checked along with hub stud qty etc, most nissan spindles are the same so leaves a huge range of useable items. nato
  14. hey have a look at another car i am working with. sofar am respnsible for the 5 stud conversion in the rear (the hard end, fronts are easy). next addition will be the 2nd pic. just waiting for a weekend to do it with all the stuffs i need. all bushes will be poly or solid. coilovers will be aslo dealt with in soon time, which will give lots more room for rim inner with offset fwd style struts. nato
  15. yuk, yes very mazda 3 with scoop!!! i like up to the my 05's not the 06's but, my older bro has the 04 or 05 cant remember with all the MY stuff, made then but sold as a.... The 04/05 sti isnt really that quick, as compared to other imports etc (or my now written off R6 yammy). Used to be great fun letting my bro grab a lead then winding the little yam out and sailing past him whilst on full throttle @ 200+kmh haha, needs more work to compete, but as i said before 'written off'. But yes the 07 looks like a pig in dress up!!
  16. another one on the XBOX, from forza motorsport, its called a 240ZX however and dont know why. you can either tune the stock motor up with turbo or NA, OR you can buy/swap either a nissan SR20T or wait for it an RB66DETT, and then spec that up. result is 560 odd kw and almos 1000Nm of torque, makes an interesting drive, even in 6th gear down low you pump the throttle for some wheelspinning action, takes off in 5th and when boost comes on Wahh waahh wheelspin. basically you have to detune the thing to keep it on the road, ill have to see if i can get some pics or trailers somehow, not sure how ill do it but. also this thing is a full Gnose style car, can do custom paintwork but mine is silver with the black zg's on. beautiful car!!! nato.
  17. what sort of motor really warrants a "full cage" for race days go the roll bar frame / or a 4 point or something small to protect your head. If your after side impact, front and rear also then go a 12 point or similar. Cannot get these 8 point etc and above road legal full stop here anyways and your eastern states RTA's whatever are far more strict than ours (SA). first of all stop all your wows about the best/biggest and whatever and decide exactly what your after, "your needs", your wants and what is legal etc and meet somewhere in the middle where you'll be happy with. sorry to burn but till we have an idea of this, we can really offer any info advise that you want to hear. also those cages from jegs seem nice, well priced but shipping would kill that. Any other links or whatever you have come across?? nato
  18. yea i got similar, canon 350d from an insurance claim, had to buy bag, 2gb card sling style bag etc, worst thing about these DSLR's is the bloody CF cards. crap old mechanical technology, carefull of the pins in the camera or in my case the reader slot on my printer!!!! bloody miss's got no reapect :lol: :roll: bent 2 pins and took my an hour to straighten them. lucky :roll: nato oh yea the 75-300 is great at the races clipsal 500 a couple of weeks back!!
  19. i think zdt means the badges, what have you taken off?? correct me if im wrong!! :oops: nato
  20. too much torque??? ha ha never, more the better i find with my sbc 283, when stalling it up (when it had a knackered enginemount) would lift the left side of the motor easily up like a motor jack and only at about 1200rpm when then stally would start to grab. i only have one of thos carbon endlink front braces but i dont thing it would do anything for chassis rigidity for a twisting force. A traiangle brace from firewall to the crossmember mounts will do it but the tri brace from towers to firewall (as seen on hybridz) from my point of view does little unless tid to the lower rail near the crossmember, ie where the enging is conected to. Baddog stylr rails do help a lil, by conecting to the rear, but its like having 2 pencils side by side and twisting them at one end, doesnt do much if you follow me. The front cross member needs to be triangulated in a vertical plane across the strut towers, and then also tri'ed from that front tri to side tri's, this is exactly however what a roll/safety cage is. seam welding is the easiest thing to do for yourself at this stage, but my car before i bought it had a 260z front clip put on after extensive damage to the rad support, and both rails, not only is the steel a grade thicker with lest rust due to the later model, but the guys (chassis blokes not sure who here in adelaide) sleeved a rect/square section inside the font rails and i find my car doesnt "feel" like it twists but how can you realy tell. Yes i agree that any excess tourqe the car and tyres can handle ends up in copius amounts of heart pounding wheelspin. even bigger fatter wheels wont help much stopping this as its tyre grip that will reduce this, ie softer stickyer, not bigger, (but if bigger and stickyer then yes that will = more grip) Traction is measures like so "(grip/traction) = (co eff. of friction) X (weight acting on other surface)" so its this coefficient that makes all the diff as youweight does not change, and this is irrespective on contact area, (well only slightly but almost and nearly neglectable, only testing shows small error). Anyways, go for the seam welded front, the rails under the seats AKA as "SEAT SUPPORTS" wont give you much, although YES i will be connecting to the rear and have slip on over existing SEAT RAILS from 2-2.5mm folded section when i do. My reason is however for a overall chassis rigidness without the roll/safety cage. hope i helped, Also 24Oz, your car looks remarkebly like mine, even the wheels look same/similar, provided it the pic as your avatar, ill post a pic soon. nato
  21. ash would an order for 3 sets interest you?? nato
  22. for drag car launches, yes bushes and front diff mount is a must and not necessarily the half shafts. A 600hp v8 zed in the states succesfully runs at the drags with a 10.8s quarter and has only had on shft let go!! How he manages this is the drive shaft angles, less=better. this is all set at an aproximate of when the car squats so they become basically dead straight. Yes quality ujoints are a must, but a solid front diff mount and good unis all round are a must, then rear mounts must be good with nothing less than tight poly bushes or ally bushes to stabalise the rotation resistance. If your racing and not draging you should be fine with a chain and poly bushes. dragging is a different story as u normally have bigger stickyer tyres as compared to racing. Dropping the clutch harshly is not effectiv in any launch unless u WANT to spin the wheels. Some clutch slipping is best practice no doubt about it aswell as the autos do the same thing with their stall converters etc, a gradual full load aplication is a must. My r180 open has had no rear end problems except the PO snaped a mous bar stud dur to worn mous bar bushes, and a slightly loose strap setup, (this will be fixed shortly when r200 is employed) Also the half shafts cop a beating and had no probs with them yet, which i doubt yours will in comparison as huge amounts of torque, as compared to an rb25det wich only realy creats torque when on boost. Shock loading breaks things (fact) careless driving, in racing there is NO reason to do this whatso ever. It is purely bad driving, and is expensive trying to blow things up. nato
  23. yep, tep and yep. i would have chimed in earlier but coulnt be bothered writing a novel. Just leave the motor u have in, provided its a good runner. otherwise there is no real cheap rebuild unless you know what you are doing and what you need to be checking, by the souns of it you dont, so i would recommend getting it done be someone who does, no pun intended. Learning about what needs to be done is most certtainly useful and a practic here or there would be worth its weight in gold but you dont necessarily have 3 motors now do you? Good/decent measuring equipment is almost a must, more importantly is How To Measure correctly moreso than the guages. Im able to do wonders with cheap digi verniers. Objective measurement is a must and must be carried out in the same objective manner. Ovality/ roundness and taper are all things to be aware of and know what sort of limit can be tolerated, you should really read the engine rebuild section over and over and take a keen eye to diagrams and pics of the rebuilder/engineer and what he / She (Ha i doubt it) is doing, aswell as how they are doing it. a cylinder ideally should be perfectly round and not taper. during use/wear it wears out of shape, and losses its surface finish etc hence an old engine will not seal like a newly built one. (Think of an oldie trying to keep their but hole plugged and not fart lol :lol: :lol: ). I would say again get your nose inta a rebuild manual, a chev v8 one is best as they tend to go over building theory also, and trick of the trade as these motors have been heavily built and modded since the 50's there is a couple on ebay now,would recommend the building and blueprinting one with the light blue cover and red motor on the cover, a great read. nato, sorry bout the long boring post.
  24. ash needs to charge more!!!
