nat0_240_chevZ
  1. yes but it is possible to remove the only 3-4 mm of struc integ that the wheels have. always consult someone with an idea of what they know and do!! ie a wheel repairer or maker!!! i personally think these wheels look sickening, even on a newer s13-s15 or what ever. crikey ill sell you some decent gear so you can run new 5 stud skyline wheels, should open up your choices of what you can bolt on. from the states you can get 16" konig rewinds that loooks so much nicer on our beloved s30's, and they are cheaper too!!! look them up nato
  2. id say thats an unfair comment!! id say the aero problems are very miniscule compared to most cars. the 240z and the rx7 in their time had the most advanced aero package int their time, i do believe the had about a 0.71 Cd aero efficiency, what lets the zed down is the blunt shape of the rear end, as its not the leading edge its the trailing edge which affects the wake, in which a vehichle leaves going through the air!!!! just look at most cars now, all have a nice sharp rear end just look at th caymen above!! And what they talk about hybridz is their tendancy to swallow up exhaust gas whilst driving as we all know!!! all the car needs to aid this is a small wing with a sharp lip, and/or a rear under diffuser, like most other modern cars. nato
  3. loosen off the hinges but where it bolts to the door and re-align. best to do with the guard off!! but then you dont have much to line it up against. dont loosen the bolts to the body as that allows allignment like rotation when looking at the car from the side!!!! nato
  4. font in pic above isnt to my liking but. close but cigar. nato
  5. im in for the stock ones at the top!!!! how much and how long??? comes with backlighting i take it? cheers nato
  6. i suppose i could get one made..... copper or such, but not cheap! if you went the path of a full metal gasket could also do Ally, stainless. will need an old gasket to stencil, unless you can source a dxf/dwg or dwg similar. also the exact dia of your bores as generic gaskets are generally oversize slightly which hurts comp and leavs small hotspots on that sharp edge. check out hks, a fellow at work tells me 4 weeks and you can have what you want!!!! if all else fails give us a holler. nato
  7. ripoff!!! the fellow that did my head said dont wory bout it. $40 for the shave and face was all i got done!!!!! oh well. nato
  8. just buy suitable valves from head reco place, generic a/m items . they the n turn and grind the valve seat angles into the valve head, only thing you need is the right dia, and length. will cost just them same as buy an l-series specific item!!! speak to a head place first of course, when i bent a valve in an old n42, i saw the fellow there just grab one out of a small pile and grind/shave it up to suit in a matter of 10 mins, was pretty amazed but this is what he does every day. small workshop but building 750hp rb30 turbos all day, with only the stocker 2 valve heads!!!
  9. yea 98 with add, will be ok. but if the head has ever been recoed or had a replacement head could have hardened or SSteel valve seats so you may be ok with just reg or 98. nato
  10. actually im ready to take it out now!. swapping the r200 2way in, will be pretty aggressive, but with an auto shouldnt be too bad. yea its nice but not 100% predictable, need to have confidence it will step out if i say so. nato
  11. ah just next to where i work on my car, workshop. 5 mins from home here in adelaide yes th350 for now will either go a t56 if i can find one cheap for a gen 1 or similar. NO, these were done with the open wheel r180, suprised??? goes LSD if you feed the power on nicely. and still operates as an open as it should when powering doing a U turn. would be interesting when the 2 way is in and when the efi is running properly. nato
  12. YEP IM SURE, have an earlt 240z at worksho, ( not mine) has an r200 but still has the straight rear bar behind the diff, but the diff still sits forwared with a slightly shortened tailshaft. So yea it can be done on the early models. late model 240's are also a definate easy swap. no real mods req'd, just front crossmember needs to be used or drilled if you dont have one.!!! yes the long nose mech LSD's are the good ones, but a quaif or helical types are excellent and even slightly better, but justify their cost, and their slightly different handling charachteristics. nato
  13. jap racing http://youtube.com/watch?v=mo0WeyGFSDA
  14. another interesting one. not mine but a us reveiw. http://youtube.com/watch?v=ejYcrhXi2w4
  15. some cool vids me and my mate made one day we got bored mind you whilst performing these acts of stupidity, my fuel pump was farked and kept stalling which meant the car did also. hope you like them. have a few more but havent posted them as they incrimate myself and where i did them !! :wink: nato
  16. yea and 240z, regardless of build date, Fact. nato
  17. craig, whats thiss fellows name??? where in SA is he? maybe pm would be best. nato
  18. a way of cross referencing shock absorber/struts theres quiet afew to choose from, some no mods, some lotsa mods!!! enjoy!!! http://www.monroe.com/catalog/documents/08_MountingLengthSheet.pdf nato LINK UPDATED, AS I SEE LOTS OF PPL STILL TRYING TO TRACK DOWN PART #'S
  19. no real easy way around it im afraid. just install the motor gearbox etc. seam/stitchweld the whole front end, add strut braces dont worry bout the cage, as far as making mounts dont worry as it seems the rb's drop straight onto stock s30's but the motor is forwared by 2-3 inches, aslo the treans mount hole need to elongated, otherwise to drop in with the motor against the fiirewall will need too look at mounts, Oh and sump regardless but you ca still buy these from nissan, z31 200zr sump. then once its in try your luck with an engineer, motor reg, explain that displacement is only 100-200cc bigger but with a stock turbo. Then under their instruction fix/upgrade what they want you to then u should be ok, as far as approval goes in my state only thing the engineers are worried about is 'torsional rigidity', 'stopping power', and suspension condition and stability. Most emphasis is on the first item then the 2nd. But here if they break your chassis whilst performing the torsional rigidty test then they will write it off on the spot. Nothing a square section slid up the front rails wont fix how ever, as for a letter, id say try forging one, as thats all youll really be able to obtain i believe. nato
  20. better to use a universal type like a facet, better new also and allows you to use any size fittings on the in and out, and costs about 70$ new from memory + fitting i think were 4$ ea. dont bother with used pumps as the last thing you want is to be stuck somewhere with no fuel pressure. I also recomend running the line through the stock mech pump, as u use the elec pump to prime the mech and also acts as a failsafe if the electronic pump shits itself, still have a mech pump able to suck through the facet style universal pumps as they are 1-way ie can suck through them, like a check valve!!!! works well for carby, as you have pressure before you turn the key!. nato
  21. YEA SPACERS JUST mask the problem, redrilling up and out is the go always, cant help but say, i told u so, just like anna nicoles babys father!!! but i would use next time up 17-20mm and about 3-5 out!!! didnt have to remove the cross member but!!! nato
  22. 3-8psi @ approx 4l/min from memory. put the pump @ the back with pipe coming out of tank straight into the pump then back into the line. make sure wiring is isolated/fused as these chew some amps, also for safety. also make sure its wired only when ign key is ON not acc as it will piss u off. dont use anything over 8psi on su's id even recommend no more than 6psi for the su's as they cant hold fuel back very well. nato
  23. Sorry checking DBA catalogues shows that the R31 your local or imported models be they GTS or not have the 260mm by 10.5mm with 47mm total hat = small not much improvement over the drums with good pads/shoes. R32's run a bigger rear at 297 x 18 vented with 63mm hat these have an internal drum for the handbrake that is 172mm in size. The problem is keeping the internal handbrake drum with this setup as with the 63mm hat you run out of room for the internal drum backing plate mounting - well with some engineering it could work and in fact I believe Stewart Wilkins Motorsport is working on a solution for this setup on the rear of a zed. Can you tell I have been looking into this stuff too - I have a plan and once I complete the test fitting etc I will post a write up on the setup I will be moving to. But lets say this - so far it has been a simple process and the plan is to the following size rear brakes. 302mm x 22mm vented with an internal drum in hat handbrake setup that has the cable in the factory location (still working on the leaver setup not sure if I will change the leaver of the donor brake parts or have my hand brake cable ends remade or make a conversion plate thing) also the chosen rotor is from a new model car so I am still waiting for the aftermarket rotor manufacture to release the product....June is what I have been told.... NZEDDER, i do believe i have seen a young fellow in japan using an r34 rear brake setup, he just welded in some stiffer tabs to bolt up to and it sit perfectly behind the 240z/260z stubs etc, it was a while ago but ill see if my mate has the link or pics he copys from everywhere, unless someone else wants to chime in This r34 setup is the single most attractive rear brake swap i have ever seen!! uses factory handbrake cable etc etc, drum park brake and bigass rear rotors and calipers, i do believe they are also brembo's, (Brembo = AWF, AWF = added w*nk factor!!! lol) nato
