nat0_240_chevZ
  1. so mike/.Nzedr, you want an overlay of the bottom one over the top on, (as per your pic). then you could get them laser/water cut, csk to suit, and taper the plate also to suit. was the pic a scan?
  2. ill explain later. email is buggered, and the forum just spat out my last post and lost it!!!!!!! or im losing it @ the pc!!!! attached is the dwg of the throttle body flanges, forgot what you wanted me to do with them? cheers nato 2658_.pdf
  3. BULK, it sounds just like a slykline!!! was at the lights the other week, hear this "skyline" sounding thing launch it hard, was in between a few trucks etc, turn my head and who do i see??? you!!!! So id say almost exactly like a skyline, maybe its the MASSIVE hot dog ON THE BACK OF YOUR CAR, SORRY AM I SHOUTING, WAS THAT YOUR EXHAUST I THINK I CAN HEAR??? hahaha yes your car is loud when right foot sung throught the floor!!! lol
  4. lol @ above on all points!!!! rofl!!
  5. trUdat
  6. got access to a scanner??? scan the flange with a steel ruler laying flat and email the pics..... or take square on photos with again a steel rule across the face for ref dimensions. could have something drawn up in a matter of an hour that you can print 1:1 and check on paper before you send the dxf/ dwg files to the cnc shop. email is a beautiful thing, as i am aware you are in NZ. make sure you have photos of each side, ie 1 pic of the mate & 1 pic of the matee' nato
  7. no no & no. well yes, it will make it "feel" quicker and more like a sports car, not a heavy luxury slug!!
  8. yea thats right........................ never the same, caus they just go that SO much netter with a pedal for the left foot to operate. and you can shift as you will not when the auto wants mind you my current vh45 swap will stay auto until im all clear with reg and/or get sick of no clutch pedal and the trans itself. nato
  9. buy this 240z and ill look after it at mine for you untill your 2+2 is finished in 5 years!!
  10. he makes the from flat sheet. and drills to suit!!!!
  11. check out rbz260's sump, just cut, Spin and re-weld!!! plus chopping and extending whilst re-routing the pickup. im sure you or someone you know could do it no worries!
  12. on simmons website they have the details for a guy that repairs simmons wheels, he has instack lots of inner and outer rims for mix and match with simmons wheels. he can make whatever you want but. i was quoted about 110 a shell outer only ea to give less dish on the rear as they are a lil big for std guards. all he needs is id, pcd od/rim dia and typeand he can make the inners and outer separate, ie make th 2 piece to a 3 piece. nato
  13. whos the chick?? send her on over to sell what i got lying around for all the zeds which i no longer require.
  14. bought my car with a 283 chev v8 already installed and dispensated by motor reg, have cert etc. was done in 85 when v8's in small cars wasnt frowned a\upon like it is now. yes i have the chev still, have quite a few people always wanting it at any one time. NO the rails were not reinforced but were in very good n sound condition. I am now looking at cutting the front frame rails out and replacing with a Rectangle hollow sect which is taller and slightly narrower and installing them to have some of the rect sect on the outer side of the inner fender for eng exh clearance issues with the vh45, with the chev the instal is extremely simple, it uses the std hk-hg monaro chev mounts wih the steel block on the stock engine perches. the engine does sit a lil high and forwared in the engine bay as to where id like it to sit, but was an absolute hoot to drive, even with the heavy boat anchor chev!!! the baddog rails is what i have as my plan B rails which is the same as stock but extend and bend around the floor contours to attache to the rear subframe. the nissan v8 install is very interesting, will be most likely dry sumping the motor and running customised exh and intake for preferance as well as space constraints as the twin cam hemi head on a v8 is very wide @ the top of the motor. check out a youtube vid of the vh45de going in. nato
  15. def a clutch type lsd, 2 way at a glance at the ramp angles shown in one of the pics too! looks alot like a unit from a z31 if that helps anyone but otherwise a direct Z boltin. what offers are you after for peoples reference would you take say 600$? nato
  16. i press up my own sections for rails, and have a template or cad dwg for making the under seat rails. i make them @ my work as that is what we do there, sheetmetal fab. i just developed the blanks to be cut and get my brake press operator to fold them up once punched/profiled out out the front rails are very straight forward, just re-inforce the swaybar mounting and cross member mounting positions with threaded tubes as the sway bar mount bolts can easily pull out of just a nut welded to the back of the rail. no need to go any thicker than 1.2mm steelas the fact rails are lucky to be 0.8-1.9mm thick. for my mates car we are looking at replacing front and under floor rails right through to the rear subframe and aswell as running tube throught the sill panels for side strength as this is really the only stuctual stifness of the car besides the roof! nato.
  17. Whattayamean "not that far"??? 'oh luv, just going for a quick drive down to see nato for that gearbox i told you about. be back in about oooooah................3 days!!!' haha nato
  18. nah sept 71 is def S2 240z/s30. cheers for the response lurch, saved my a fairbit of time.
  19. how bout one of those stupid big front bars too nick? haha
  20. may have one, will have to check with my mate, has 5spd also bolted to it, ill let you know, but its here in adelaide! nato
  21. yes rear toe is huge on Z's even just to correct the bad alignment from the factory, aswell as all the gutter knocks from it journey to now. bump steer is easy to correct in comparo to the toe issues in the rear. redrill or slot the crossmember for LCA pivot re-location, or those bulky spacers!!! nato
  22. yes i know that but i thought this was all about getting one up here!!!
  23. -skyline and other compatable later model nissan LSD diff carriers into longnose r200 Z housings and shaft mods, as prev documented by myself her on vicZ, (an sci_aus r200 r33 upgrade....... post, do a cut & paste) -front diff mount restraint , just link to hybridz or the zgarage, very useful. - gearbox conversion in detail with what does/doesnt swap over ie fj/sr/rb boxes and the l series front casing.
  24. also try L 4 cyl manuals, massive abundance. also the Z tailshafts plug directly into an SR or RB box too!! hear me when i say conversions!!!
