nat0_240_chevZ
Members-
864 -
2
ups here too but in SA nat0
they are 240z only im sure, but doesnt mean you cant put em on, il have a look, i atleast reckon i should be able to come up with one pretty good set, all funds are for my late mates wife so dont sttoge them too much nat0
bugger, just the pics sussed too, wiped off the historic dust, so now not included!!! nat0
ill have a look tonight, got a pic of the type your after? so i know what im looking for?? cheers nat0
looks like thats had a lil taken of the face!!! it still looks huge compared to the N42 with a slight shave, like all the area around the saprk plug is non exeistant on the n42 again especially after a light shave the P90 is an open chamber type head and the n seris is a closed head, P90 was for tubo motors and NA but with flat tops not dished. if you took an N42/n42 head block combo and a f54/p90 combo ans swapped the heads you WILL end up with one high comp NA motor with f54 flat tops and tiny n42 head chamber ie 10:1 cr and one low comp 7.8:1 n42/p90 combo prime for turbo!!!! nat0
i have a set of Z g-type ones, fibreglass, unpainted in white gelcoat and comes with free historic dust!!! PM with an offer if your interested as my bro is over in tassie for 3 months he may be able to bring them back there for ya i think he's in launceston?? nat0
the the std nissan revs to nearly that and its still singing at this speed, glad i got one going in now!!! pics are on nico. yes troppo motors do have loose piston-bore clearance but this is also to reduce thermal expansion that causes excessive bore pressure as well as reducing cyl-bore drag. but tight in the sense that craig was mentioning was positional/concentric tolerances of the crank mainbearings, not piston to bore. maybe the new balancer that you have noticed a slight improvement from will do it, but in saying that wasnt it #5 where it broke??? try agtr clutch which is uprated ie an osgiken single or double, they fit the L easily too. dowelling mAaybe a suggestion... but if it feels smoother it probably is. also what is the all of the separate mainbearing clearances like after it breaks?? @ 0, 90 180 & 270* not just @ 1 pos'n? nato
Light weight, Japan-style 240Z
nat0_240_chevZ replied to BenZed's topic in Members Project(s) Journal
how much for the r200 diff gears landed??? aswell as the g/box gear. yea sux about the bushes being ex usa, i could have told you taht, is why i was suprised that you said they were from kameari!!! nat0 -
probably a bent rear control arm, very common to see an early Z crabbing down the road!!!! as for roll, dont bother with the rear sway bar, its all in the front anyways, the rear bar makes a tail'ee car when trying to go a lil harder, the irs is plentysome for the rear end. yes sounds like a combination of a few issues to me as well. nat0
replace mount and link bushes on the front swaybar. if you want more roll resistance, thicker bar or stiffer springs, also a wider track helps but may not be an option if trying to keep carr 100% legal.... raise the roll centre on the car? stop thrashhing around corners? nat0
yes tune for a 3rd heimholtz wave front approx 260mm total runner length IIRC.. for a 4800rpm torque surge, plenty of discussion on hyridz inclusing the formula to use and how to use it if interested.... nat0
Do you have a spiggot/pilot bush installed in the back of the crank??? Why has the main bearings bore, NOT been tunnel bored after the first crank, its surely worth less than multiple breakages. Is the entire rotating assy balanced? Are the bores all wearing evenly?? could be inconsistant drag due to out of round on cyl 5 or 6?? What does the break look like, can you post some pics? also very close up of the fracture area on the crank?? Is there any noted damage on the piston face/tops?? There is something obviously causing it as my old l24 would rev happily to 8500 rpm all day long for the 3-4 yeas i owned it, but its day was done when i melted a piston in #1 after the dissy clamp let the dissy free spin!!! answer some of the above and it should start to guide you to the root of the snappage, id say fatigue crack without even looking at it. but that is the obvious anyways. nat0
with some of the k and some of the z bits but....
EOI: KAAZ 2 way Clutch LSD suit R200
nat0_240_chevZ replied to Vindicare's topic in Parts and Tools for Sale
adjust the pre-load on the centre, may make it behave a lil more to ur liking. the 2-way vs the 1.5 way in accel should be the same as the xx-way is how the diff locks up under accel as compared to decell 1 way is accel only 1.5 is full under accel but only about 30-60% of lockup under decell (ie down change/engine brake'n) 2 way is same lockup under decell and accell the pre-load of the centre is what it sounds like your not happy with, ie the initial amount of lsd action, under easy going driving. the 1.5 will be the same as what you are experiencing, but less lockup when you drop down a gear and try to comp lock-slideinto a corner, ie like a small handbrakee' more so with te 2 way, les with the 1.5 and none with the 1 way.(not none but up to the amount of initial preload anyways). this is all based on the ramp angle which adds more LSD the more torque/resistance to input and output. i have a temei 2 way in my Z, i went for the 2 way A because it was a bargain and B im running an auto so decell is not really a problem as comp locking is not really good for the autos to say the least. Stay with the 2 way for a while, you WILL notice it settle down once it wears a bit more, the bed in procedure is only to make sure the friction surfaces wear in evenly like brake pads. not to wear it in to where it will stay. see barry's install review below http://www.nissandatsuncarclubsa.com/KaazReport/KAAZ_report.htm nat0 -
just playing with ya, only just saw your interest and the saw your Q.
yes, but i think they sold on ozdat already!!!! not bad 250, a steal..... hope the strut tops is all i have to swap over. nato
2 marks on the pulley?? when using a timing lite are you looking @ small indent in the pulley or a painted line??? The dissy could also be 1 tooth out on the oilpump drive, have to remove oil pump and redo if this is the case, but another way is if your dissy has 2 sets of bolts, one set going up and one set going down, the upper & lower body can be twisted on some dissy's allowing upto another 1/4 turn on the timing. answer above q's, hate to sound patronising but was all the bolts on the dissy tight? nat0
not really so dimitri, its the cooling of the weld that shrink, and in your case all weld along a plane shrinking will cause the bannana, so yes a zzzz8 has mentioned get them faced by even a head shop, 30-45$ should be, then you should be right, sometimes doesnt matter how much weld distortion you try to minimise it will always be there, this is golden especially when dealing with welding fabrication everyday @ work..... just make sure you get it faced or it will crak in due time, not IF but when is the case!!! just thought we had better make it clear, for your own sakes anyways!!! cheers nat0
top it up and leave the rad cap off..... stop the water pressure build up, keep an eye on the oil level, if it takes on too much water then stop driving, but if it lowers then you should be ok to keep it going, the water in the oil 'should' evaporate out if no more goes in, but it may just get you by for a couple of weeks. dont worry bout the shortage of l6's as there are plenty around as more than the z's came with them anyways, and if they beome extinct then its RB or other time!!! nat0
i could get you copper ones for about the 150 aud mark!!!
ben looks like il be moving my stering rack down not to decrease/eliminate bump steer but to get the vh45 down about 10-15mm lowere, as x-member sits about 30-40mm+ lower than the rack mounting brackets!!!, a worthy mod indeed in this case you'll see what i mean and it really isnt that hard at all, i will document (with pics ) the process to do it simply and mantain the stock mounting rubbers & steering shaft (just new clamp brackets) see pic nat0 -
Just spoke with Stewart Wilkins about this. Changing the control-arm pick-ups does help the bump-steer, but you wind up with different roll-center heights front to rear. His solution is specially designed steering arms which also improve toe-out when steering close to full lock. Unfortunately like all clever bits of engineering, they don't come cheap. I just dropped the car off at SWR to have the DR30 R200 LSD fitted, using modified Z31 driveshafts. Having proper drive a the rear should reveal what the rest of the suspension needs. Basically suspension and brake upgrades are all I have left to do on the car now. Performance-wise I am quite satisfied. Ben, that suggestion was the easy route for fixing bump steer. to not alter the roll centre the other option is to modify the crossmember to lower the rack mounting position, im just not sure as to what fab work you lend yourself open for ....... you could go and spend big bucks on things you dont even realy need but is just easy caus your lazy, depends on how dirty you want to get your hands. You could modify another crossmember as to keep your car on the road (or off as lil as possible). SW steering arms i would be interested to see.... as using the CA spacer below the strut also affects your front end roll centre. having different height RC's affect the way your car loads the front before the rear kinda skewing the car into the corner, promotes understeer if excessive, but using the roll centre change can be advantageous depending on track conditions and attitude of the car req'd for quick transitions. Some bump steer is desireable as a zero condition is not as ideal when hitting full bump on the outside/loaded wheel as it lets the tyre give a lil and has that last bit of grip before letting go. it would be good to see you car in action, this is one of the cars that the owner has the right intentions for outrighht performing charachteristics in mind... am watching this thread............ nato
