nat0_240_chevZ
Members-
864 -
2
WA 10 peice Carpet templates for 240z 260z
nat0_240_chevZ replied to chartoo's topic in Parts and Tools for Sale
+2..... lol -
What year is this S1 240z? Also is it worth resurecting?
nat0_240_chevZ replied to RBZ 260's topic in General Discussions
guru, is this wayne? nat0 -
try mazda 2, 3, 6's etc, i have an 2007 2, and it has what looks like a starter motor bolted to the side of the rach where the stering columd shaft enter the rack. These are rear steer mounted though, ie behind the wheels. worth a look however. nat0
Just won a Subaru 3.9 LSD :)
nat0_240_chevZ replied to sexual_sushi's topic in Brakes / Drivetrain Components
Why??? plenty of overpowered rear wheel convverted STI's around....... i think 500+hp sti's and and wrx's are a decent comparo??? remember the cv is inherantly strong torque transfer mechanism than a uni joint no?? aswell as more efficint without any speed variations/pulsing???, you would be suprised.... -
BRIZZIE, i have found a guy @ edwards town I have had some dealings with, (accidently found out what he does) that can make HK monaro rear quater panels from flat sheet, I said ill keep his contact details for this purpose for us boys here on the forum, ie make 10 quarters complete, even the lip where it spotweld to the inner fender. Give me a buzz to discuss, this guys sounds promising, very proficient with an English wheel and other panel tools... obviously. nat0 -
280zx's also came with a full cv'd r180 rear end....
240 260z CV half conversion
nat0_240_chevZ replied to Zbitz's topic in Brakes / Drivetrain Components
what diff??? and frankly, what car??? -
SORRY 25 companion flange & stub axle, Not 24 as mentioned above, 29 spline refers to diff output. all this is from memory when i looked at this, there is an extensive thread in sco_aus's post about the diff side of things, not so much about the companion flanges and stub axles but, as to achieving the cv coversion. Peter if you still have an r180, you will have to swap out the centre as it is bolt in halfshafts where the 280zx r180 outputs are circlip pop in/out style, but there is a stock cv solution either way, also could use the z31 cv shafts as they have the same flange face for the cv shaft, 3 x 2 bolt pattern.
if using r200 diff & 24 spline (240z) companion flanges and stub shafts, grab 280zx r200 cv joints, and the 280zx r180 cv companion flanges only, direct bolt up with the ommision or changing of the dust seal ring on the comp flanges. nat0
runners too short, i think nat0
current pics please, as wheels appeared to have changed from link to post, cheers nat0
easiest to refer to wiring diagram to show the loop that is created when in the ON posn, grab a test light and probe (disconnect all wires to coil & ballast resistor) find the wire which only lights up when starting, this coes to coil, then find the ON posn light only this goes to resistor, then other side of resistor goes to coil (same terminal as the start wire) from memory the black white is the start only, and green white i think it is is ign ON.
galerdi, contact me re this, I have my vh45 sitting under the stock hood of my 240z, a few tricks you should know first. be carefull of ground clearance from sump and crossmember, as your probly not going to want to lower either of these, only in a pinch. PM me and we'll get an email chat or phone convo happening. cheers nat0
nope, its the ignition loop wire, the one that comes back from the start point on your ignition barrel, it supplies 12v to coil on startup only, then when its started & return the key to on ie not starter, it goes back to 8v through the ballast resistor which obviuously is not hooked up. This is what you do only when you have no points, ie electronic dizzy or other, as it burns out the points too quick with 12v running through all the time, also make sure the coil is a constant 12v ie "Use Without Ballast resistor" aslong as you check the 3 boxes above it will be fine. Nat0
I have extremely good repore with wattyl super etch in grey or black. this is a single pack products which has one of the best etche's around bar a couple of 2 pac products I NOW know of. Minus paint here in adelaide will chem bath to strip your car, not cheap bur, and will paint in the above product inside & out, for metal protection, this includes internal rails and sill panels with a spray ball. however like i said expensive, and around the 2400 mark for a Z shell (price from about 2 years ago) http://www.minuspaint.com.au/about_process.htm but there are surely other services around aus that will do this, check out the website...... nat0
You can prep the sections your going to weld in with most high zinc products (although I dont as they give way after a while), or rust proofers but what I do is use a copper based weld through primer for any metal on metal sections you may still need to spotweld together. Then once all said & done drill a 10-13mm hole in the rear wheel arch / inner guard so you can use a rust preventative like your oils as mentioned above or a product Like 'cavity wax', it seals out any way for moisture to get into these metal on metal sheet joins. You will need to borrow or buy a cavity / box section spraying atachment / gun for this, ie long thin rod with a 180degree hemisphere spray pattern, start at your deepest point and slowly pull towards the drilled hole you have made, can be don from both ends on the Z sill but will need to remove the front guards. oh and also plug up the drilled hole accordingly...... however many other ways of doing, but this is how all my cars are done or going to be done in future also.... nat0
yep i have 235-40-18's on a volk gtc racing wheel, very light, half the weight of stock mags, big difference in accelleration but more niticeable up hills and breaking traction ie how quick it hit the revlimiter, like a lightened flywheel but bigger & worse, one of the best upgrades i can recommend asits not just accelerating the dead weight/mass its the rotational inertia which is twice the problem, the dead weight of a wheels is not too bad but when you have to spin it up quick or stop it quick, makes the most amount of difference, ie doing ring work and getting wheels up to speed quickly for good response or lack of when i think about it......lol nat0
nissan plastic tanks with alloy core from a varity of newer model cars works extremely effectivly. cooled my chev better than a 3 row copper unit, much thinner and thermo's work more effectively on them as there is less restriction to get air through,m as soon as you go to thick by adding too many rows of tubes, air tends to go aroud the radiator than through it...ask any hot rodder, they swear black and purple that they need another row on their copper unit, but when you give them a slimm ally one, they almost refuse to use it. When they do, what do you know, thay end up painting them black and putting a lrage shroud which cover the puny miniuscule item. Doing this now to a 42 ford chop top for a friend, he nealy shit himself to see the temp gauge so low wihtout fans!!!!! nat)
NO JUST ON THE 34, will be running them on my Z when i get the thing back on the road, as i would like to track it with the VH in it as its alot lighter than the boat anchor chev iron block & heads it had, also means i can use lighter springrates yaaa, pressures i run are about 28-32 psi, depending on summer or winter, and likely feel of the rear end i expect, IE if i expect to slide it around alot easy ill run them a bit higher, if im after outright grip for grip sprint ill drop them as low as 26, bit mushy but the response from the coilovers makes up for the loss of directiveness i can feel. I never adjust the dampers either, I have the rebound on Min out of about 14 clicks and it just works well. I agree we are both only going on experience, and that has been mine, Ive never tried the dunlops so couldnt comment, but next time im chucking the yoki A508?? (i think they are) on the rear also as the fron has never been outgripped yet, i did have semis on back only for a lil bit with road bridgestones on the front and found the thing understeering a bit, hence why i got the semis on the front quick smart. cheerio nato Merry X-mas to all.
Semis on my car do stick well even when wet, when warm like shiver to a fluffy blanket, when cold they outgrip pirelli's and bridgy g grid 3's etc. yes they can follow a rut in the road abit but our roads here in SA are outright shiver..... On the SE freeway here, in 5th gear in the wet with any road tyre i have tried, i can accel to keep my 100-110kph up a slight incline, and the car will slam on trac control, turn off the tc and it just about hits limiter once boost becomes +, speedo cracks 240kph plus before hitting the reset button whilst not acc any more than 115kph. With the semis on the back this only happens in the wet in 4th if a slippery bit of road or only in 3rd if the bitumen is alright. allround the semis kill any street tyre i have ever used, tried. Noisy??? only when they are sliding or having fin, otherwise if not quieter than my road tyres except that they pick up any rocks / dirt and fling them around the inner guard liners cause they are a bit stickyer. althought the semi's yokis i have on the fron don squeel or howl at all, just the cheaper brand on the back. my r34 at any speed (ANY speed) if you rip the steering wheel hard, it WILL NOT understeer, it will oversteer if you have any poew on the right foot but will always track exactly as i command, weather it be 10-20 kph, 60 or 100kph & beyond, (bit hairy trying @ 100+) I wouldnot recommend them if i didnt have these experiences. cheers nat0
yes will fit, as will most other sr, rbs and of the like through 1970-94 clutch plates, some with small mods. rb & sr bolt PCD is 2mm different, but can easilly be used anyhow. ie currently useing an rb30 turbo clutch on an sr20de+t, torquey motor 10 psi on an na ening, bloody steam train down low.....
would have expected some maturity from a mod....... delete this topic, please, also another z enthusiest a bit disapointed by it all nat0
i buy semi used semi slicks, yoki a508's??? and some other cheaper version of a semi from some brand like your federals??? on my r34 gtt, the rear no namers are very sticky when they get warm, can slide the car with huge angle and still get it back, corniring can not be compared to road tyres as they are in different leagues, dry or wet, 2nd and 3rd used to boost wheelspin in the dry now only 2nd will, only 3rd if you pop the clutch or swerve with the wheel, the yokis on the front are silent in slip and provide excellent turnin, cannot get this car to understerr even tried with oil on the road, the yokis wil just turn the rear end will oversteer after the hicas is maxed out the steering angle in the rear. I pay about 70$ per used semi (fitted), usually about 65-95 % tread left on them but i have to pick & choose. for road tyres however, yokis have been my beest by far even their cheapest range is exceptionally good, sometime noisy when slipping but. nato
how much more would you spend on machining custom wheels tha off the shelf'os?? no pun intended, im just curious as to why go to such extent when they are available via AZC, yes not cheap but by the time youve destroyed 2 or 3 in product testing, and damage a few other part along the way, namely half shafts or underbody, you probly wasted that cash already. FEA simulation is good, but only as good as the persons/operators understanding of the applied loads and forces, aswell as things like fatigue, eccentric loading and twist of the member once loaded. ie sometimes the fea package doesnot account, either lack of operator inputs or just the transient nature of beam loading, (ie never the same twice...) you may have a bar which is capable of resisting the torque applied, but what if the bar twist slightly, then forces become furthar eccentric to the vertical axis of the bar, the furthar they are the more likely hood of destruction, especially under those 'high load' clutch drops and down changes nearly causing comp lock. just my exp speaking here, if you are to proceed, try making the moustache bar more like a contoured 'I' beam (universal beam), ie have a top and or bottom 'T' flange either billet or stitch welded on, itwill allow far far more bending stress resistance, the wider(higher) the 2 flanges are appart, the greater the bending resistance, try it on the fea package, but as a weldment.... ask me Q's if you are still after ideas. I too have waterjet, plasma & oxy profile cutting and other facilities at my disposal and also have a high demand of torque resistance, hopefully 700-800+Nm however as busy as i am........ cheers nat0
whats wrong with the std ones? have you had one fail? stock one only weighs approx 4 or so kg's does it no??? remember the stad one is hardened, IE Q & T, so near mech properties of spring steel. you just try & drill it without speciales drilling bits...... R180 & r200 are also different if not already known, holes centres are different. Also mounted the other way, if its had its holes sloted then probly an r180 filed out to suit an r200. just some info for you. nat0
