nat0_240_chevZ
  1. WELL i didnt know that one, bloody marvellous, opens up heaps of options, wohoo...... nat0
  2. there are 2 variants of both calipers & one of the smaller+8 (su suit solid rotor) one to suit a much narrower rotor ie only approx 20mm thick & one to suit a 24-26mm rotor fom memory. all are available but some are less common, hyridz has the full score but i still think 1 variant is missing from their data, Nat0
  3. MMM Peter that one is different again to the stock vert bolt up i have ie a 3/71, exact tunnel as pictured, but the oem item is very different, ill try get a pic & share any how. Its info like this that needs a sticky, ie the difference of said items along the years, ie 'check out my ......' model year liklyhood of being altered along the way scale. Your mount looks like a transition mount from the tunnel as pictured to the later style long bolts from front to back ie the later 'ear' type mounts, My oem item is only a '1-piece'. nat0
  4. lol, I think everyone missed the ROFL sarcasm......good one rev.
  5. leave the struts @ full length as i have, just shim up above the insert, which keeps your strut length in droop and bump the same, and no-one can pic it, except the fact the adjusters up the top on my koni yellows from a z31....... snug as a bug in rug. highly recommended as it removes the need for sectioning, as sectioning without appropriate sized bump stops allows wheels to hit under the wheel well where the bump height is not altered if you do as above...... just a thought & yes I have extensive photos to show........ just a thought. Nat0
  6. or 2 vert bolts as i thoguht it was early 72 it changed from bolts up to bolts farward.... i make the early type, but has an offset backwards for the rb, but can make thgem straight..... nat0
  7. sold? if not can i place dibs on it now? nat0
  8. hope so, and considering our dollar @ present they wouldnt want to buy from here anyway. but that said to by one over wouldnt be as bad as previous. Although I dont think that sump utilises the gearbox to engine braces unless im missing something. Look once i have a pan complete, it will look alot nicer and well finished, the thin sheet mockup is purely that. there are still several changes im yet to add, just to the shape of the thing, the pics were just to wet youre apetite, that yes they are coming.... nat0
  9. yes very much a bummer, as i was intending on purchasing a new one ex nissan, and all custom modded ones (all OEM chop up's) are $900-1400.... just because they have a nice sticker on them, and usually have a core charge additional to that.... Feel free to link to hybridZ and direct them through here, as i thought ill get the aussies sorted first. I would have to confirm a deposit before counting your hand up as a +1 on the list, as i really dont want to be messed about and then have to off load them on ebay over the next 5 years...... cheers Nat0
  10. Ill most likely look at supplying new ones to suit with the sump, as its a sure way to confirm it all fits, although to modify the pickup is quiet simple and straight forward. Ill be doing the sumps, and I anticipate the basic unit to be baffled & caged around the pickup, only, not full directional vanes which i will be using along with the wings for extra capacity, basic capacity at present is approx 5.8L but i may shrink it down slightly to make it more versatile to those that are dropping into toranas and other conversions, unless of course i can pick up extra volume in mk-2 mockup. Nat0
  11. hi guys, im making my own RB into s30-Z sump, I have my first successful mock up in thin steel. when i have finalised the design, wondering what sort of interest there would be for more, as when i make mine its easier to make more at the same time, but as i have limited time available i thought id get the interest first up, as im only thinking of running one batch. Open to actual the actual config they are finished in, as mine will have baffle, side wings aswell as other performance features as used in race/track type items. these are not only restricted to the s30, but any mid-rear sump bowl requirement. so if your after just a basic sump then let me know. no pricing has been considered yet nor confirmed, as the details are still vague. Should be around the cost of a new nissan one (if they were/are still available) for a basic unit (inc horiz. baffle) about the 600-650 mark. but like i said above, details to be confimed. as shown in pics, this is the first mockup only, wings, baffles and diversion blades are to be finalised now that i have a sump which fits. Sump retains the stock std engine-to-gearbox braces, as these are important. can include external oil fittings for pumps/coolers/turbos & returns etc. utilises the rear dipstick position on the rb, to suit 20/25/30 and possibly 26 depending on request. Any sales will contribute a donation to the forum they sell from, as its not about profiteering, just supplying what people need and not really for sale any more. reply here or pm through forum. cheers nat0
  12. equal halfshaft length that can preferably maintain the same angularity through bump to droop. ie 1 short & one long the angularity diferentiation is greater for the shorter shaft. but with and around the limitations of its enclosure, ie the body shell. less angle is better, no angle is best. soft mount anything that vibrates if possible, also if noisy in operation, sound deaden or shield it with a softer panel/material than body can answer the q's above but lunch is up....... nat0
  13. will happen to all alloy mags if you hit the gutter hard enogh, or regularly bump the kerb whilst parking, always the fact, they are cast.....then machined........ but yes, CNC'd rims are a lil crap (Cheaper 'N 'China) lol nat0
  14. mmm just make up what works and massage the truth to what they are from, its just your engineer being lazy, using an already approved solution, calcs are realy not that hard and can be confirmed by him/her, in a matter of 2-3 hours. as for booster etc, rbz_260 had used essentially stock r32 gtst items all round (excepth the callipers on the front were RX& items, but almost identical to the nissan ones as they are all made by sumitomo exc brembo....) give it a whirl, or else try Z31/32 items, but not 4 pot, and as N zedder said, try commy, as even the V8s came out 2 pot calipers right up now pretty much. nat0
  15. only the front robert??? or rear also?? nat0
  16. dimi, does it start , go and stop, ie with a trade plate will it drive without dying before getting out of the neigbourhood?? nat0 or is is best to car trailer it?
  17. for which end??? the front??? any pics? nat0
  18. i could make you a head from billet ally........big penny's bit. bottom end $$$ to get a 'stable' 9k spinner titanium rodbolts titanium rods with mating endcaps(machined sawtooth face to hold together) Need i describe the price of this stub suitable for the above apps, then there is cold cutting, machining, boring, finish boring etc etc, not exactly stuff a mate could do at work if you get my drift. Crank, is not just a nitride, linish & balance either trust me on this one pistons arent too expensive, i agree. Sorry my bad, thought you said a 9k spinner, not 'able to support' ie bolt ons. only L series ive had to 9k was an l24 and it loved it.....sort of, untill a rod bolt let go, after too many bounces off the top of the tacho. luckilly no leg outa'bed, but was a fair few years ago. yes RPM is the key to good power, not so much torque, but if youre only in that rev range for a second, or two, then money is best spent getting you up there ie torque below, the rod stok ratio only changes if youre changeing rod length which ill doubt you will be changing it much at all, if you want the key to big stable revs, open up any jap motorbike engine, you will see immediately what I am talking about, skinny rods and big ends, small crank and biggish pistons fwiw. nat0
  19. dimitri, ill send ben to collect for me lol, nat0
  20. still available??? does it start? nat0
  21. plus the rod/stroke ratio will hinder anything over 7k, as stroke is too large to maketorque that high witht that much reciprocating weight..... try an l24 crank......ie destroke it, will rev higher easier, and the volumes you are after will be better supported with your intake and exhaust area limitations, amongst others...... a bottom end to hold together for long at that speed is 10-15k just in parts and yes i mean parts..... nat0
  22. i luv it, bet it goes like stink too........ look at how slammed the ass is... just repaint and it would be a show'eee
  23. works.......well i never said that..... cyl spacing, headbolts line up but...... cam drive external, not inside timing cover. oil galleries way out water balleries are massive in comparo to the L. nat0
  24. looks like an rb head. yes they bolt on.....
  25. may have one , but rusty near the f/wall, but only due to lack of paint due to brake fluid.....
