nat0_240_chevZ
  1. worst case, to do it on the cheap, i mean..... swap carrier from subi (LSD) into a 280zx r180, use 280zx housing, shafts and companion flanges. only for 240z stub axles with 24 spline however, if you have the 260z splines then diff story.... 280zx are good for the fact they cam in 2 different difs r180 and r200 and both of these diffs had both uni joints and cv drive shafts, so 4 different combos nat0
  2. use 280zx r180 cvs......
  3. where abouts you puttingg the drain plug? nat0
  4. i got a FC rx7 complete rear subframe you can have for 2 ctns of beer...... has diff, shfts arms and brakes, the lot.......is fact LSD too nat0
  5. yea but ive been in a cooner vb commy with 400bhp from a revier than usual 253 red, rebuilt only with slight mods ala flat tops, carby and headers. would have no troubles stickin it the ass of a gen3 commy...... but again, my 66cc pushbike would pull harder...... back on topic guys. dude go for it, if you have one and it will cost you nothing but time, do it and stick it up all the nay-sayers, nat0 PS i got a 283 chev sitting on a pallet which came out of my 240z, a bit too heavy with iron block, heads and th350...
  6. chevs arent any better........ wheres that michael jackson anim eating popcorn......when you need it?
  7. yes rightly so. thats moreso bending of the chassis not so much twist, but yes i aggree that if you reinforce anything it 'should' be stronger/stiffer. but listen to this one........ the 2nd shell i bought has had some serious accident damage on lh side. where the rail meets the firewall and heads under the floor, it has been plated with 5 & 6mm thick plates, 1 up each side of the rail transition, and 1 under the floor rail, although its big bad and stif right there, there is evidence of flexing on either side of this repair, ie cracking and seam separation of tunnel to firewall skins and also rail to reapair, so what im saying is, do it right youll be greatfull do it 'yea, just plate here up mate' may find you righteous, think of your chassis as added suspension give...... back OT, this rail doover can easilly be lengthened, shortened, thickned etc should get some pics of the dodge repair up too......all to be removed and replaced with much more normal looking retrofits, rail, bit of the floor, tc rod mount, floor supports etc.... nat0
  8. stock original ones are only 1mm, i can make them from 3mm if i had to, or 0.55mm if you prefer....lol remember these are really only stopping your ass falling through the floor. not there to stop the car twisting...... thats what the sills are doing.... nat0
  9. Yep still alive mate, http://www.viczcar.com/forum/index.php/topic,7897.0.html was my original build, lifes getting the better of me at the moment, have it all ready to make, just busy with a rotisserie strip down to bare metal and renos .....etc but need to get it back under way soon, not interested in proceeding if i dont have a car to put it in....lo nat0
  10. i 'could' make them...
  11. check old post http://www.viczcar.com/forum/index.php/topic,6911.msg63285.html#msg63285 these are the 240z early 260z 2 seaters, later model have the deeper/higher sections under the floorpan, but i have them blanks to adjust if necessary..... ie full length or deerp, wider. think you get the drift nat0
  12. I think I've got a pair made still lying around..... Made the m at work a while back, did sell but then didnt come through. Had 150 on the pair from memory? Worst case could make some more...... These were for the under floor rail, from tc rods to mid floor. Nato
  13. mmm i got 2 240z , both underway sandblasting, and got an 'onhold vh45 convo sitting there begging me to complete.......lol just bought the second one a month or 2 ago but.... lol @ peter, i was thinking the same re: whats your name before noon, haha nat0
  14. sorry bud test not conclusive, firstly there is no connection to the other side of the cell. google electrochemical cell. ie you have the grey connected but there should be another polarity connected. into the water / electrolyte. Impressed current corrosion protection DOES require there to be a scrificial Anode in-line in the circuit. ie -ve ground is used in the ICP cell as the cathode (non rusting part) then your block of magnesium in the case should be the anode (the rusting part) impressed current corrosion protection does work, used on bridges, structures etc. basically the cell is not complete. nat0
  15. JUST CHANGE STRUT TOPS FOR THE LOWer front or 240z items, gives about 1.25" drop for nothing...... just time. might have a set of old pedders around soewhere. nat0
  16. use r32 viscous shafts, and mod the ends.... unless you can get a hold of a viscous from a z31??? or or just use the inner stubs, and custom the adaptor to existing shafts??? nat0
  17. go the vh....... i got 3/4 the way there and stopped, went for the 34 neo 25, still had alot of fab to do but didnt want to butcher the car too much, now i have a 2nd 240, which will be butchered as its not fantastic to begin with..... still goth the vh45 too, just sitting there teasing me also.....
  18. careful what you wish for.........
  19. i think you should point out the nose work req'd, ive seen this car and it does need a slight pull and straighten. from a slow speed bump in the front, nothing major. i was looking at buying this untill i found a complete one dis assembled, but i can confirm that this car not too bad in most areas, it has some rust in areas where i have never seen before but things like doglegs ans bottoms of guards, and doors are pretty good. nat0
  20. nice work, interesting seeing others ideas and work, i found with engine positioning from factory to be offset slightly to one side, as engine torques it centralises a bit. i had measurements of about 12mm or soo off centre, but diff is off centre also, my mounts did centralise the engine at the front and the point the trans directly at the tailshaft flange, howeve the angle where it meets at the diff would be about 2-3 degrees, but i also lowered the engine by 15-20mm and also shifted it back toward the firewall, so only about 20-30mm from back of head to firwall, enough for heater hoses and certain tools. over all good to see, like your work, ps what are you doing for the trans mount, and which gearbox you using? also wha year is your car an what type of g/box mount dous your car use? ie ear type or hump type? nat0
  21. im making 2 now, one for my zeds and the other for my mates panel van, in materials alone, about 400 for mine and 500 or so for the panel van one. this is at a heftilly dicounted price on new steel of course, has full adjustability up down and rotation locks of 5 degrees, but i laser cut the fidly bits and other profiles req'd i got 2 zeds to to in hopefully quick sucession, then pack it up and store. however i have had some catalogue put on my desk yesterday with a full blown off the shel one for 1800$ inc hyd rams for lifting, although the Z is very light and 1 person can easily lift each end. i should scan this add, and post aswell as some pics of mine thus far. nat0
  22. neutral switch from memory, but older cars had the cruise gear switch, ie when in 4th & 5th gear would be closed.
  23. which i did, 4 sets but sold a couple already
  24. yea but engine sits too high and too far forward, speak dimitri..... & they dont look very nice and they cost more than mine......$150 engine mount brackets only and the money goes to a shop that already looks after aussie built cars. ie v8's.... buy buy buy..... http://www.viczcar.com/forum/index.php/topic,7573.msg71475.html#msg71475
