nat0_240_chevZ
  1. is suppose i could make one.....hundred or so...... do you need bracket & clip or just bracket? Nat0
  2. engine bay rails cut, bend fab and finish to follow over this next week or 2. Rear floor connectors and floor rails full length hopefully complete by end of this week. have a cool 7 min video of these engine bay rails being cut, although its 128mb:( "Jock" when you refer to frame rails, are you referring to the floor supports?? i think Veloce above queried the slip over the top option, look its up to you, ill make whatever you need/want, its just not my recommendation. You cant stop rust, only controll its spread/growth and caping does not aid this. PM me if you are genuinely interested. nat0
  3. can start orders now if you like, dont leave it too long or else they might be done..... im making changes as i type, just need to make a variant to suit the 260z 2 seater, although i may need one to measure from as they have a series of humps on the floor i might need to check out.... about to run some fronts for current orders now too. Nat0
  4. make of it what you will.... lurchos, i gotta love that popcorn slinger....cracks me up everytime... how do you think some of us more experienced guys started out?? just grit your teeth and clench your fists and have a good crack at it. I give him this much......looks like his car is already nearly completely stripped!! now that didnt take to long now did it?? Being in his trade, im sure this will help him along his way, I wouldnt be making too many assumptions yet boys n girls yes conversions normally cost shitloads, however they dont need to..... my rb25 neo conversion thus far has not cost me much at all....... when you get a motor for nothing but some work, engine mounts you make yourself, gearbox mounts you make yourself........yep upto about 60$ for new engine mount/isolators, nat0
  5. even beter napes, ive got a 34 neo installed into one of mine...... i can send the convo mounts along with your rails??? its an easy swap bud, just need the right parts and the right knowhow i guess. I may be straying from my existing install, with costom engine and gearbox mounts which I can make for you, to possibly instaling a whole 34 crossmember. Dont put anything toyota in, not saying they are not good engines, just keep it in the nissan stable of your going to keep it Jap powered. My old r34, with no real mods ba boost and full 3" went hard as all hell......I was able to slide it without much temptation up our south eastern freeway accross 3-4 lanes @ 100+, wont say how fast i go to....but it screamed, now imagine that in my lil Z...... nat0
  6. some teaser pics of the rear floor rail -> rear subframe connectors, still have 1 or 2 more tweaks, but what you see will ultimately be what they will finish up like. the area around the radius on the floor will be filled in and main joint/edge visible will be welded and finished to look like a bend. no holes will be added, i would suggest to mig stitchweld these on for ease of installation. This is ONLY the rear section shown, my floor rails will have this included on the rear part of the 'Full length' floor rails, from what you see->the back of the TC rod mount. any q's let me know. nat0
  7. ok, about australia day now and im pretty much done with development of the rear connector area of the floor support rails. Need to get the pics off my phone and i will post up the mocked install, not completely finished or anthing as these are only mock/trial fit sections, luckily to be 1 foot long at best, but adding the floor rail and firewall section onto them is straight forward. Need to tidy up this detail and then we are all go. Watch for pics in the next day or so. nat0
  8. sorry that read wrong.......was meant to be praising all you boys for offering, but no thanks or response from the OP, my bad, just re read it and wondered what I meant.....
  9. Hi bud, currently they are to suit total replacement(remove and replace) however I can widen the rail to facilitate a 'CAP' type install, although you are just creating a safe haveven for rust to tear through the new ones, OK yes you will probably get another 5-15 or so years out of these ones, possibly more depending on moisture and exposure, My recommendation is replace completely, old rails are usually squashed an bashed about a bit anyway so fitment would not be an IDEAL slip on/over the old ones. A BFH will be req'd Youd be suprised what lurks inside your existing rails or box sections, thats if there is anything left. 260z rails are different and alot taller / deeper, although ultimately would be another Type/model ill have to finish developing for sale, not a massive problem but valuble time none the less. As I dont have a 260z, im not (wasn't planning on) venturing down this track, but hey i could be swayed.... All of these items are or going to be available because I NEED them myself, OK i may end up with quite of developed replacement/upgrade and or performane products they may not always be available. but i do have/own and will always have access to the IP for this stuff. But wait till brakes, control arms, fuel tank, and other suspension goodies are my main area of concern. more bits to come.... Nat0
  10. almost there, working on them now, had a lil hicup with some older ones, almost there....... the mockup rear connectors fit both my 240's well, I just had a change of heart due to ease of installation and effectivenes, on some areas which were a PITA to actually manufacture. hope to have pics and trial fit pics up by about australia day... nat0
  11. mmm, nice of you boys...... but no thanks geez!!!
  12. mmm that is a bit old, but a good power source none the less, I dare say your after high freq and foot control??? or high freq and button operation? nat0
  13. Hi Paul, does it matter if its an older unit??? have some floating around @ work but as you could imagine quite large in physical size..... otherwise ill keep my ear out as I always have units pop past my nose. on an of topic note, ive got a 3 phase WIA weldmatic 355 DC mig with remote wire feeder used, for sale? nat0 ps oh yes ex adelaide
  14. mmm. i would not be misled so easily, do not tie up 'wilwood kits' as being a genuine item, most are wilwood calipers with custom adaptors or hats. just be careful, as I have played with some JSK units, they are very ""slim"" in weight, but unsure how they would perform under tough conditions, ie not on a light car. not knocking them........but they are extremely light and let just say "dainty" just advising you to tread with caution, nothing more.... nat0
  15. lol'ing.....
  16. mmmm, i see oportunity here........ might need to chat to my buddies...... nat0
  17. i can do engine bay chassis rails, and possibly some rad supt bits, for ya..... postage no problems..... nat0
  18. ok 4 pairs of rails completed, 2 pairs still available. Under floor rail supports either std or full length will also be available for the 240z shortly. amongst other bits to come along. get in contact if you require, not just now but maybe down the track. nat0
  19. my first thoughts was also a dodgy flare job, but more common than not is a bent strut shaft and or strut tube, would need to checl camber of each side to ascertain if it is this and or remove shockers and spin them to see if there is a sufficient amount of runout. nat0
  20. Dimitri, cause you will be effectively pack above the shock, the gland nut is effectively a mech stop to limit any way of bottoming out the shocker, this is why I wentdown this route, as the shocker is working in its ideal range, and now way possible of bottoming out the shocker, I did not use any urethane or stop whatsoever, although i am thinking about putting a rubber/urethane disc just 5-10mm thick. but id prefer to bottom out the gland nut to the upper perch than the shock itself. Nat0
  21. leave them full height, and dont worry about that loss in bump height, as if you are running much stiffer springs i doubt youll need the bump stob at all. use thos shock spacer rings ive shown in another thread, these pack up the cland nuts and also centr the strut cartride at the bottom if using 260z struts. Only reason sectioning has come about is because not many people can have the gland nut thread machined easilly into the top of the strut housing/tube, so cutting and welding appears to be the easiest option? apearantly.... I did not section, cut or weld a thing, and im using the same inserts, gland nuts & strut tubes/housings, only some carefully measured packers/spacers which make this whole assy so, so easy. You WILL get a few die hard peeps that say you need every once or inch of suspension travel, but this is crap, what your allowing your car to do is actually bottom out the tyre on something it was not designed to touch, ie inner guard, outer guard or other, the small (Very small) loss in travel does not effect handling, and unless your hitting spoon drains and speed humps at a million miles an hour, or plan to drive your Z off of platforms and gutters 1 foot high, DO NOT WORRY ABOUT IT. My expert opinion, others feel happy to flame, but lets just say, I think my designs and mods through completely before watching/following the americans, redneck version... not meaning to be sinicle, but its the only way sometimes. What you dont want to do is pack the insert/shock up, just pack above it so the gland nut holds it down, as you are trying to retain the same amount of 'drop/droop/max extension' without compromising where the stoke of the shock is attained, ie not at the bottom or top of the shockes range. any q's please search for an old thread of mine....... nat0
  22. first pair is Complete. others are cut and inline for pressing this weekend. All go, if you will need these in future, or want to stash them away for a rainy day, then I suggest you do so as, I will not guarantee their availabilty going forward. cheers again guys, Nat0
  23. now also available, matching engine bay frame chassis rails. click link here http://www.viczcar.com/forum/index.php/topic,11926.0.html Nat0 nat0zparts'at"adam,com.au
  24. Hi Guys, looking to run these and have completed by end of this week, Please, please please, let me know and ill send you the details if you are serious, Finding parts like this will be few and far between, I do hope this gets out for all to read, MODS, please re-post in FOR SALE section if at all possible?? Re-inforcement parts are done with all high tensile nuts etc, Anyone have any last request or any interest, as I can not guarantee these will come up again, unless a bulk/group buy order is brought together by you guys yourselves or otherwise hybridz or classicZcar Get the word out or curse me forever, cheers Nathan
