nat0_240_chevZ
  1. oh yea i forgot to mention I got a video of the cutting of the blanks for these rails, havent posted it up on youtube yet but Ill do it soon, link to be edited in below or in original post. PS internal re-inforcement plates drafted up today, 1st offs coming this week!!!! nat0
  2. funny you mention, I will be making one at some stage, depending how i go salvaging 1 out of 3 mediochre ones, but I have already begun development of the lower rad support as it is a pretty common flaw, ie frontal impact of any sorts....... It will be a 2 piece unit, similar to as the factory ones, currently working on ideas to replicate the basic tooling to give the pressed/rolled edges to the large slots on the 240z item. 260z lower rad sup't is significantly lower, in height offset, but it would not be too much extra work to get this extra offset. Watch this space...... Hi Munters, no not anticipating to have to make this from scratch, although it is a very important item on the Z front end, best sourced from a donor car I feel, If it is the RHS one your after, I may have a suitable 260z 2+2 item I coul un-pick, but seeing your location, it would be best to source one locally. I could make something similar, but it would not look the same as it would be quite square and boxy looking, but you never know whats around the corner. this piece you are after is also a relatively high strength material also, as its a bitch to panel beat, I do have some 0.9mm G450 sheet id doubt id be able to form these 3d shapes, cheers for the request none the less.... maybe if you bought a pair of rails, then postage of a secends fender might not be too bad??
  3. more pics of fitment, not something you want to install yourself, but by all means any competent panel beater or restorer can easilly install. Pricing not yet fixed although from estimating mat'l cost along with laser cutting, Pressing, Welding /finishing and fastener installations etc If I get 5 pairs (or 10 individuals) or so, bill in bulk for time spent on them, price per rail will be $ POA each, rails will include nuts and re-inforcing plates similar or same as the factory items. These rails are bloody strong even with out the other half attached, unlike my stock rails I am able to bend/flex them with muscle only. Under floor rails are also available Have 1 pair available now 5/11/2012, ex Adelaide. Postage cost wholly & solely at buyers expense, happy for group buy or similar. Any questions please contact me either PM or email, can offer mobile contact details after contact is made. get them now, as they may/will not always be available. these things take a while to make, appreciate any feedback or special requests. cheers Nat0
  4. first real set/pair knocked up from G450 med-high tensile sheet, they come up well pics coming soon..... nat0
  5. Hi all, I Have some high strength steel im making some of my own chassis rails in the engine bay, (finish where the floor rail covers it near the TC rod Bracket, bottom of firewall) from firewall to rad support, direct factory replacements from slightly heavier gauge steel, and still of high strength. these units have all the holes say a 240z and earlier 260z 2 seater have, including holes for the splash tray, sway bar, tow hooks and engine cross member. these will require the skills of a panelbeater or LURCH to install, but are made for the utmost purist, as they have been designed with originality in mind, not like some others available from USA. I only have pics of my preliminary rails thus far, more pics will be up in the next week or so, will keep posted, but for now, see attached, also note they include the tappered down area near the radiator as per stock rails, remember these are to try and be as close to std spec as possible, also includes original JIG/tooling holes for measurment and positioning. pricing is solely dependant on demand, if I make 5 lh and 5 rh then dont expect any more, unless tabco want to buy/distrubute them..... These rails DO require the re-use of? - existing TC/Castor rod brackets - Floor rails unless you need these too. - inner skirt & strut tower (inner wheel fender/guard) I am/will be using these on my car/s, for race / events etc, and since wittnessing the stock rails support, is mandatory as far as i see, these will be manufactured using CNC equipment and every rail WILL be the same. any Q's please ask, but dont bother me with a stack of questions if you do not intend to buy or are genuinley not interested. apologies for those whom are inquisitive by nature, only offering these, as I NEED them myself, only fair to see if I can help out others. Now please also consider that this Higher strength steel is expensive, so youre not buying cheap off the shelf folded section with no strength. Have material certs available if you are interested. nat0
  6. too many pies?? prev owner a real fattie? Springs do sag over time, amongst most body parts on oung-middleage women. Car has probably had a few bingles in its lifetime not repaired properly??? as im finding out with the car I have on a chasis jig ATM.....mmmmm Also it is the way the motor torques.......mmmmm yes I think that might be it.......... I have also noticed it may not be springs 'All the time' I suspect it also the chassis, as I can with very little force, twist one rail up and one down on the car I have on the Jig now, with no engine crossmember in it, lower rad support removed, about 10kg force moves the whole corner of the car..... I wonder how bad this will be with the new motor going in?? I thinks It will need a definate stiffen up, didnt think it would and was hoping it didnt either, but yup!!! I remember stalling up my 283 chev in the 240 and it would lift the Broken LH engine mount 6" clear off the mount, so you could change it with no hoist/jack..... think all that weight on the RH mount.......maybe twist the tin can a lil. Seriously the Iron block and heads on the chev, only sopported by the RH mount.......The chev weighs twice the motor going back in!!!!! check it out, measure under the rails to ground on flat surface, then measure stru tower height... nat0
  7. I wouldnt need CAD to make them, I already have the Z-car Drawn up and mounts measured up, How many sets do you want/need?? only thing being my downfall.....well..... is id move the motor back within 10mm of the firewall, then lower it til the sump is 10mm off the steering crossmember and rack mount clamps. the rotate the engine slightly (only slightly) more upright, now it would sit lower, gear shifter more @ the driver Then crossflow head, then...... oh yea did someone say they wanted new rubbers??? nat0
  8. kick it to meeeeee! I already got same brakes which im going to use, also have cad/cam/laser/waterjet available.......hint hint.....haha another hijack....... brakes still for sale??? nat0
  9. sump sold, buy my custom ones instead.......lol, when they are finished....... need this one to seal my motor whilst she awaits start time..... nat0
  10. mmm, i have them in place on one of my custom sump threads, I made sure they were still used, custom sump not finished yet either.... work too much...
  11. yep, basically not want to engineer anything, ie do the calcs and engineering checks required, its just their way of saying yay or nay,taking your cash whilst someone else has liability of the mods, ie 'x'sport or any other aftermarket manufacturers, whom just usually modify stock gear anyway. yes, some rotor manuf. do sell blank rotors. some do custom hole patterns on a std rotor too but pricey and lead time is a killer. Id suggest you put the hilux/landcruiser calipers on and let them try to tell you that they are not standard fitment for this car, provided you dont butcher the std splash shields when cutting new shapes for the 4 pots. make them nice and neat and re-paint etc Alot of the 'engineering' work performed by theses guys is a load of BS, there is way too much red tape and insured liability involved, for them to begin to even think about crunching numbers and getting involved, its not worth it to them, but your money is.... 'known and certified', (if any thing even does exist), means: yep, they have made money from these things and yep making claims which they can be hounded for said money if so required...... think about this, how many cars, even current ones have fatal design flaws which have sailed right past ADR compliances? and how many of these said parts have been used in modified conversions, upgrades etc etc. may i speak ford territory, holden commodore, hyundai excels, daewoo where do i stop. As for wheel bearings fitted on another car? maybe check out xf falcons? or other larger fords? im pretty sure they are not that different to the datto's also look at z31 300zx, r31 skylines etc etc, how about using that hub off another car? ie said falcons and other nissans?? and even making that comment about other cars which use those bearings. this comment does not conform do engineering design principles, pholisophies or even common sense, as the size of the bearings, although the same as another could fail dramatically due to other such factors, like the distace between the bearings, remarkably more detrimental for the bearings if closer together than spaced furthar apart, which would cause a bearing to fail, due to greater moments during dynamic loading, diameter of the wheels, weight of the car, grip of tyres, if you hit a gutter whilst turning, clip a granny crossing the road. for gods sake mr engineer pick up the bearing catalogue on your book shelf and have a damn look, read the numbers.... this guy needs to be reported, as these generalisations cause more troubles than they think they are preventing. OK on the flip side, yes I agree cut springs, welded suspension & braking components big NO NO, or wheel spacers 6" thick & wheel studs 2 feet long, wheels protruding from flared guards is stupid, please slap these kids in the head... rant complete. dont take your car to that idiot, please pm me his business/contact details, I would like to write him a helpful letter me
  12. id be in on a few bits, dont worry about the 1000$ limit for extra tax, not worth worrying about if your saving an arm and a leg on postage anyways, id be in for a pair or 2 of rocker (sills) panels, rear 1/4 wheelarch replacement panels, pair also, I think I paid about an extra 200$ aud on an 1800$ aud purchase from europe, i think you could save more on combined/bulk postage, ie maybe use a standard size stillage (size of a pallet but about 800mm-1m high) nat0
  13. early autos had r180 with cvs later autos had uni-j's with an r200. from MY experience scavenging parts from the Z wreckers, had both diffs, and had both types of half shafts. nat0 i have r180 companion flanges which plug onto 24 spine 240z stub axles!!!!! hint hint....
  14. new pics added in first post, suits: rb** with a *71c gearbox into an early s30 combo the ones pictured are destined to help power bobsyouruncle..... nat0
  15. try rustrepair.com, they have them for about 90 odd US. http://www.rustrepair.com/PANELS/240-260-280Z-70-DATSUN-NISSAN-PATCH-PANELS.HTM im thinking about getting a pair and some rear wheel arch section including doglegs, should do a group buy to save on shipping.... nat0
  16. just a basic U-bracket/saddle with a bolt, then the mount bolt goes through:- -side/cheek plate of U-brkt -though engine mount in pic link above -other side/cheek plate just think of the latter s30 gearbox cross member, much the same...... the one on my VH45 uses datsun 240/260z aftermarket Moustache bar bushes as engine mounts!!!!! WOW...rare haha at least its from the same car.....lol nat0
  17. mmmmm, i could make something very similar but yet, even more captive to suit L's RB's, SR's or anything. either like pictured, or more like a std mount, just more captive, bit still relatively cushioned. <a href="http://s303.photobucket.com/albums/nn157/nat0vhZ/?action=view&current=Image472.jpg" target="_blank"><img src="http://i303.photobucket.com/albums/nn157/nat0vhZ/Image472.jpg" border="0" alt="Photobucket"></a> <a href="http://s303.photobucket.com/albums/nn157/nat0vhZ/?action=view&current=Image477.jpg" target="_blank"><img src="http://i303.photobucket.com/albums/nn157/nat0vhZ/Image477.jpg" border="0" alt="Photobucket"></a> nat0
  18. we have a few places here in adelaide, you could try fitch the rubber man... foam & rubber, bit pricey too, but more reasonable, MOST times we also have Roache foam on churchill road whom do a fair bit of everything if you follow me, we buy filter foams from theres which are petro chemical base resistan, ie for our machinery where oil based products like hyd oil are involved, Not a hydraulic oil filter however. but it appears like a foam you could use for top coating a firmer structure before wrapping it in vinyl.... check it out. nat0
  19. yup what he said, search my posts and ive got pics somewhere showing whats required to do the above, No Cutting or welding required, even to increase travel as its not required unless your jumping your car in a rally or similar.....or slamming it on its floor rails. Nat0 PS i think I had 2 sets of shimms and spacers to suit the 300zx koni adjustables into 240z strut tubes/housings......will have to look as i think i sold/swapped a set way back when, can this person chime in here with their experience??? or was that you wildy? cant remember, too many birthdays!!!!
  20. hi roger, your signal is a ground/earth pulse, earth the other side of the sensor. is your speedo calibat'able to use either a 2, 4 or 8 pole sender, ie you can scale your speedo to any input frequency? as i believe the S series sender is a 4 or 8 pole and the rb types are only 2 so ther are twice as many pulses per rev. this is digging info out of the dead brain cell area of my brain, so may not be 100% correct but at least 98% for the flamers..... What speedo are you using? what type of input is it looking for? Earth pulse or voltage pulsed? depending on you unit, but some of the after market or upper quality units can use either. let me know if this helps, cheers Nathan
  21. download the monroe catalogues and strut sizing charts, you will quickly find one with similar specs to your 240 or 260z units, with a small packer or larger washer you will be fine.'but feel free to swing any thoughts or ideas past us all, as we have either done it, seen it or tried it.... cheers Nat0
  22. Vipec, with launch control, and sequential think its the upper level unit but from 1800 has functionality of the motec m800. need abs sensors or similar pulses coming from both front and rear wheels so diff and front brakes would both need an update to utilise such features. do some research, some say its a newer link, but others including tuners say irs way ahead of the link, even though the same guy/guys behind it. its the quiet achiever in rally now too..... nat0 just a suggestion as its something i would consider myself.
  23. read: could manufacture, esp for the rb---> s30 zed, using mostouch bar bushed and crush tubes. very similar to the later 240z and 260s gearbox, just alot bigger. nat0
  24. nah, i aggree, but from times of old this is what i hear the glasurit painters sledge ppg about, but i have ppg on 2 of my cars and its great.... nat0
  25. how about a COB, jet black base coat with 2pac clear with matting compound/agent in it, finishe is still pretty smooth, just not glossy. PPG is renown for PissPoorGlos, from previous years gone by..... but most paint manufacturers have a matting additive, which the more you add the more matt' it looks, A mate whom has painted a few cars for me, has shown me GTR front lips, flares and other panels he's done, it makes an awesome plastic look for the lips and is pretty good on the clean up and car washes to, it looks like a factory plastic but better, I really dont know how to desribe it better. On metal body panels, looks NUTS. I would do a track car in this without hesitation, , but for a week-ender, most likely not, just opinions and suggestions, nat0
