nat0_240_chevZ
  1. just park it, then re-adjust the position of the wiper ams on the spindles!!!! hopefully will alweays then park in that pos'n nat0
  2. i know a member here whom has spacers.......... contact him
  3. use sealant, clean all faces thoroughly, ensure sump faces is flat, ie not bent from removing or doing bolts up too tight. apply gasket sealer i use blue permatex on most stuff except exhaust. apply with your finger, smear it around and make sure its even. apply to sump first, lay gasket onto sticky sealer, then re-apply to now the clean face of gasket, (use a couple of sump bolts downward through gasket & sump to kep it aligned with holes so it doesnt flide off when applying) Again make sure its a nice even spread. let this sit for 5-10 mins to allow it to go a bit more goo-ey. apply to sump, only use say 4-5 bolts evenly spaced around the sump, only do them up finger tight, IF THAT. grab sump and wiggle it, this will spread the goo over the gasket and sump. install all bolts, all finger tight if that, ie use a screw driver with a 10mm socket, but not tight, not even firm. once all bolts are in, wiggle again. then leave for 20-30 mins for the goo to go even more tacky/solid. (this is so when you do them up, with your hands, the goo does not spew out of what you are trying to seal.) Only tension bolts to a light hand tight ie about firm on a screwdriver without haveing the driver jump out of a phillips head screw, or to advised manufacturers spec, but most torque wrenches dont go this low unless you have a 3/8 or 1/4 drive torque wrench, which most dont. hope this helps, most sups i install without any gasket, just sealer, in a similar fashion to above, main idea is to let it tack off well before doing up, or sealer just gets squished out and does nothing. nat0
  4. got any pics to show how far the guides stick out?
  5. rip bud, was looking forward to metting you and checking out your monster ride when finished, sad to hear, Im sure there will be a zed run in your memory. nat0
  6. i was recently in melbourne, what a hole.......well from broad medows down through old sydney rd to town, I will never let myself go this way again....... never seen a burqa wedding veil before........
  7. the shape of the sill cover panel is correct right back to the wheel arch where it curves out to the lip of the wheel arch and the dogleg style line. i could do a single section 2400mm long but try transport that. you can run the sill cover into the dogleg, as the stock ones just essentially slip under the dogleg, and run 2 panels lapped over each other for a fair amount, hence the reason they rust out with a lil bit of moisture..... any panel beater or someone good with their hands can do the repair, remember the goal is not to metal finish the car. just get it done as best you cen with what youve got and use a thin skim of bog to get the ideal shape (not oo much however, std practice is max 3mm, but ill always aim for less than 1mm max anywhere, try to keep less than half a mm if i can.) not on my z but....... nat0 yes i am in the wheelings dealings of profile cutting, sheet metal presswork and fabrication by day, car nut @ night.... but with these machines at my fingertips, is a bonus, especially my new laser cutter......mmmmooohhahahaha. nat0
  8. buy your inserts, shorter ones. install them and mark your shock shaft at the bottom where the gland nut is. pull shock up to top, bottoming out or topping out on the gland nut. mark again, measure the difference between marks. remove this much from your strut tube, easy. nat0
  9. how long are they????front to back?? i know its about 2-3m longer than the 2 seaters
  10. yes ther are inserts with more travel that almost go straight in....... HOWEVER its not the travel of the insert, its the top of the strut tube smacking your bumpstop out the top of your tower, and this is appearant even on stock ride height with stock suspension, ie chuck a u-turn through a spoon drain to proove. DONT SUGGEST you try but if you did accidently you will know what im talking about. nat0
  11. i could press up new sills..... been thinking about it for a while, but been really busy. probably do them in a section anywhere from 1200-1500mm long, unless someone tells me there a different length. I dont own a bus nor have one @ my disposal anymore, however i just got a bus frontcut so would have a sill section available to copy from...... nat0
  12. any rough ide for safe freight to SA??? 5013?? cheers
  13. do you still have import packaging to keep it safe for interstate transport??? cheers nat0
  14. measure them all up and x/ref against the nolathan raw bush listing. ie the catalogue has dims of all their bushes, i actually own one, ie motortraders just said 'here you know more about these than us.' even @ trade buy price, probly still up for about the 250-270$ mark for everything. nat0
  15. shan i like your metaphore "Like a doorstop in your house prevents you from damaging walls if you open a door too far. Same concept." very good that its dumbed down for easy refernce, but it would be so you dont damage the door handle ie the insert not the strut tube ie the wall, lol I hope you find your way soon, nothing sucks more in wasting time then ending up going the way you were or should have in the first place, my suggestions are only to assit making detrimental changes that are not easily reversed, hence my spacer suggestions and sale, which by all means feel free to re-sell to somone not interested in cutting & shutting the tubes. feel free to bounce ideas off me, and post some of the pics i sent previously. im flat knacker at work and getting my skyline back on the road at present to piss it off so i can be a 1 car minded man, for once. cheers nat0
  16. lol, yes compromise or to not spare a cent or minute.......... why cnc a template in wood on a mill??? i could cnc punch a sheet/plate template to within +/- 0.1mm which would only, seriously take about 2-3 minutes if appropriate tools are already loaded into machine (ie piggyback off another job.) just doing out of wood, sounds like checking it with a rubber ruler....lol nat0
  17. yep i aggre with nzedder, yes why re-invent the wheel, the rb is the next gen l-series and most things like size, spacing, bolt positions are exactly the same in most cases.... easier to do with an existing cast item also. otherwise if you do go down the road of making them, just get the blank laser cut from some decent plate ie 350 grade MSteel, then machine the req'd grooves for gasket sealing etc. drill tap, c/bore/csk as req'd all in the one machining operation. If i actually still ownerd an L-series id grab an rb item first. otherwise if you really dont want to use struct grade alloy steels (mild / carbon) then yes you could use a cr-mo 4140/4340 or even a d2 tool steel, DO not even think about using ally however, as thermal expansion difference will cause sealing issues....eventually. We can laser cut 40mm plate @ a real stretch ie cut defination lacks after about 30mm. nat0
  18. IM in process of this also, i will be using the stock rb25 cable from an r34, installing the r34 or stock'ee bracket inside the firewall, doing a slight mod to the accel pedal assy, make cable operate of the original linkage pull, or ill use the skyline pedal assy complete, it alsobolts to the firwall. difference will be the Z linkage pulls from the pass side of the brake booster ans m/cyl, the skyline one will operate on the very side, where the pedal actually is. I will have pics soon, as im yet to decide and complete. Honestly id prefer the cable to come out near the washer bottle by the very side, to keep things tidy. nat0
  19. ahh yes, that is why this part of the design is flawed & subsequently phased out to the modular cradle type.... keeping the control arm mounts square to the car, is imperative, even utilising the slop in the bolt holes to chassis can cause above. so can backing into gutters mind you.... nat0
  20. used part, probly has a bad seal from valve to seat??? but again, no warranty is implied or offered.....
  21. oh and did i mention that the latest pics are not even tacked / welded together?? just incase anyone did not notice.....thats free form, makes welding it all up easier that is for sure. nat0
  22. yes stock stiffening brackets, from an R34 gtt. 26 sumps are cast and heavey,(even without the diff), and have very little volume due to the dif etc, and std have limited baffling, hence the 1st upgrade any owner should do if hitting any boost or corners fullstop. Im not really trying to make a market for these kato, im just doing my own, and if anyone else wants in on a batch run, then they can benifeit from this too, but after that, ill let my work sell them, but 1 offs will cost a bit..... However if later down the track there was a group buy, i could have organised for them but i wouldnt want to be involved as mine is all done and dont need any more than 2-3 for myself. thanks for the ups, this is only a mockup guys not the real thing, remember that. plenty of improvements and additions etc to come. Just wait till you see the final product, but i think its good to let everyone see the developments just so all are aware what needs to go into such fabrications etc, and let me tell you trying to have 30 odd holes line up and not leak aswell as perform its requiered function is not easy.... cheers nat0
  23. ok. finished with the mk-s version of the sump, much cleaner shape than previous. -Now actually clears the engine to gearbox bracing, -shape has been changed to remove sharp lower edge on rh side. also pos' for sump drain plug. -In its current state without the wing which are coming next it holds approx 5L of fluid/oil at about the 'H' mark on the dipstick, when re-located to the std rear position, (final checks and measures pending) so about the stock volume of the front pans in the skylines. -stiffening flanges added to straight edges of pan, all made from 1 piece except the front and back curves, as seen pinned in place for tacking up. overall pretty happy with the shape, position and fit with all the stock items, as getting the shape right on this and to be able to make it right is not easy by any means and have spent many hours on this. Currently working on the baffle, extra capacity wings, and inserts to divert/maintain oil around the pickup during cornering and braking etc. hopefully have these sorted in the next day or so. shall keep updates happening. also other improvements happening along the way. hope you can make out the pics, more available, any q's nat0
  24. YEP Same as katokids, is the one i have..... well had, as like i said i made my own ones. nat0
  25. mk-2 mockup sump nearly complete, looks good, will take pics once i get a minute tonight, only another mockup, however it could be used as it is pretty sweet. long side flanges look very stock with their return flange & will either have a ribbing included for sealant capture or an engraved groove all around on either side of bolt holes. this assists in sealing heaps, also getting a new laser cutting machine @ work so more to come on all fronts. ill tack up this unit tonight. Already test fitted and its sweet, withe the rb back 50mm anyways. without wings its only probably about 4-5L max but the wings i hope to open that up to 6-7L. baffles and vanes still not trialed yet as the main sump is my main hurdle. I doubt the us guys will be interested with our very high $$ @ present, but who cares. going by ease of production thus far (without all the extras) i dare say for about $500 for the sump only as a basic unit, with baffle. anyways, picture speak louder than words, as soon as i can ill post pics. nat0 PS jpav, havent forgot about you, also working on it. and xyzed, youre def using, my mounts & sump? nat0
