nat0_240_chevZ
  1. 'OVERLAP"??? uh-uh, big no no, only for dodgy panel repairs, where welding skills are next to none....... I have seen some dodgey shite and overlapping panels, with tekscrews and urethane........ small tack welds hold a butt join together, then fill in the gaps, grind, beat seal with epoxy etch primer and finish....
  2. lol, the last one is here in adelaide from a asian importer, i have bought go-jacks from there, looks a bit light on to do any heavier work, but if its just light gauge panel work then it would be fine, have though about getting one, but i got an old panel shop here with one that ill get when they pack up shop, yay. bloody good investment but, needs experience or lots of willing to learn. nat0
  3. have a look at moustach bar, it has it mounting curls facing rearward, when the diff is in the later spot, (provided it has the flat with no offset mous bar) the mounting curls are typ facing fords, ie towards the diff, early away from the diff..... hope this helps. early halfshafts also lean rearward somewhat from the diff to wheel, very obvious when on the hoist... nat0
  4. WIA, made here in Aus, get a lil portable mig 150ampere costs more but, will never let you down.... Gas, or gasless if you prefer. model CP121-0 weldmatic 150.
  5. i have the 03 sti rack sitting in my workshop, i was going to persue, but consider it a long winded way to achieve what the S series cars have already, ie rear mounted rack, power steer, as the s15's feel and response is very good, and adjustable also. also help with engine convos as most niss and other engines have a front bowl on the sump, so also help with fliping the cross member around and running the tc rods from the fron, in my case VH45 headers are too far in the way of where a 3m long steering shaft needs to get infront of the x-member to operate. good info im sure many will utilise.
  6. whats the 25 spl for??? not the r200 out of above vehicle???
  7. adjust pushrod outward furthar in MC? not releasing far enough to suck from resovoir maybe??? like brizzis brake problem?
  8. pics? more details ie kms, car removed from and have you driven on it? noisy? clunks? leaks? can you please check ratio, how many turns of input = 1 turn of output, approximately is ok. cheers nat0
  9. IM IN FOR ONE, WHO ELSE?? group buy? ideal for my monster.... nat0
  10. yup, and down and forward to stut tops also, use large endplate for bolting / mounting, unless you weld, but will need some reo behind where it mounts, thin wall'ed mild steel tube but usually the stock nissan ones are quite a high grade and have very good strength for what they are. good dash mount also and steering rack mount if you no longer use a stock one. nat0
  11. most 240's dont even run the rear swaybar, not really need, may help a bit of oversteer but, but the extended versions do come with. I can get these made with whats shown in the pic from peter above. with a notch for clearacne for the s/bar or a slimer profile to get in in-front of the S/bar. Not too many ppl would want to go a deeper section all the way. unless they already have the deeper rail from the 260, as these cars will happily turn into a snow mobile (to skis and rear drive) if you go over a steep hump or driveway Can also be made with a thicker gauge material ie 1.6 - 2.0mm but there is more chassis stiffness etc to be gained by beefing up the sills and ther attachments to the A pillar / door hinge area. Also another thing to consider is one of those big bastard dash cross poles many later nissans run, they tie up the front end of these cars heaps, and cosidering they are even though 10-30 years its junior are quiet similar in manufacture, something to consider. nat0
  12. SOLD, pending payment guys....... May have a 'full Length' pair available soon. Need to confirm their price however.
  13. Im pretty sure the only section of rail they sell is the very most rearward part, ie no front section which some people may need.
  14. i have made a zx one previously for a young chap here in adelaide. dont have any templates etc as it was made to suit his car and as i had his car there i didnt need to. I think i have the drawings but for the strut tower tops. bonnet clearance is a bit of a pita to get right, they were solid and in mild steel, ie no pivots fully welded. nat0
  15. These items are custom made, not sure what they would be worth 'brand new' or from a retailer like rare spare?? please read add where it mentions about the pickup or courier to collect, willing to box up but may cost more to freight for the person organising it. If you find someone whom wants the other side make a deal with them, would prefer to sell as pair. If there are no takes here on the forum, had plenty of interest in them, they will be posted on ebay. cheers nat0
  16. yes, same as std. did you want longer ones??? nat0
  17. Hi Guys, here we have my spare made up under floor / chassis rails to suit 240z and early 260z 2 seaters (the shallow type rails), Perfect for those whom need them, just need someone that knows how to put them in to do so, they need a lil bit of work to match up to existing floor bump easy for those mentioned previously. This section goes from mid/rear floor up to firewall and attaches to the front rails in the engine bay, they have the 2 tooling / alignment holes in them for easy check / measure when replacing them (same as factory), Made from 1.6mm 'G450 Hi-Ten galvanised sheet quiet strong for what they are especially compared to the stock items, i installed my other set into my old car and noticed the floors felt alot more solid, cannot comment on rigidity as i dont think these items really take any load except the ass of it occupants. Located in adelaide, freight available World wide at your expense Asking price $POA ---> see other link here http://www.viczcar.com/forum/index.php/topic,11926.0.html feel free to ask questions, cheers nat0
  18. i wonder if the azc ally bar has helicoil inserts un the blocks where it is bolted, the threads of this would be a serious problem in my opinion. Aluminium is normally useless for any real situation, UNLESS...(before all naysayers get in) You Continuously do NDT (non-destructive testing like xray, dye penetrant or ultrasonic) inspections of all items and do not exceed, maximum loading in ANY instances. Its just not any good for where strength and longevity is required in a cyclic fashion ie vibration, gearshifts and the like. The stockie bars are made from a heat treated SPRING STEEL, look up strength values of this before attempting to make one yourself as for every multiple weaker your material is, is the same multiple thicker, wider, taller etc etc, am i ranting.......Bottom line if youre not SURE find out for certain and maybe leave the design and the like of fabrication to those that do know. Just a word of warning, last thing you need is the diff breaking loose and panel beating the underside of your car and possibly the road. nat0
  19. no probs, i like peters approach with the GM units just modded, but id do it with less adaptors and more replacement parts, ie a bolt up setup with replacement of the outer stubs and diff outputs if keeping the nissan units. I have/had the 280zx/300zx r200 CV's behind my chev but not making the torque the LS2 does, and found that the original unis held up just as good if not better than tat style of CV provided you keep the uni shafts relatively level/straight, same principal for the cv shafts too however, as we all know what happens when using a socket & ratched with an extension, if youre not holding the ratched head it will twist off and away due to the eccentricity of the load about its axis, ie no load bearing supp't. anytime, hit me up if you need more info. nat0
  20. dont bother messing around with already kit form cv solutions, go straight to the manufacturer and make one up yourself or get them to suggest one for you, remember dif multiplies torque, ie 3.9 time input or whatever, its torque and speed which is your only concern as powerekw or hp is a derivative of them both, rate your torque in the shaft req'd then selct using speed and actual weight etc etc. gkn driveline products are used world wide, they have a motorsports section on their website. australian dist is in melbourne.... ya for you. Or website cause im so nice http://www.gkndriveline.com/drivelinecms/opencms/en/products/ and not a problem happy to help, just need some technical knowledge or consult some pro's, ps wont be under 1k unfortunately, but will be indestructable, ie used in the gm's origin of which your ls2 yea??? cheers nat0 Q's pm me Unidrive 45-49 McNaughton Road, Clayton, South Victoria 3168, Australia Tel: +61 3 9542 4100 Fax: +61 3 9544 8117
  21. 20m x 10m and then some, bit full, too many skylines @ present, had 10 zeds now like 1 zed and 4 skylines, 1 s15, 1 van and 3 motorbikes..... and lots of storage space a hoist and massive electric engine hoist (moveable...), still not enough, I want to be able to do donughts in my wkshop.... enough said nat0
  22. sorry only maz 2 gas what im saying, 3 & 6 differ... nothing is bolt in. simple, just leave it, and go to the gym.....
  23. like i said above, get a newer mazda 2, 3 or 6 rack, has the motor mounted to the rack, 3 wires from memory, speed signal, +ve and -ve...... normal steering input shaft, but is rear rack mount, ie have to flip stad cross member around and so something with tc rods (will get in way) HAS Excellent steering feel as it is manual steer once at speed, only assists in lower speed ranges, still only nearly 2 turns a side to lock.....
  24. dont run drill too fast whatever you do........ keep it nice and steady, over revving cooks the metal and it goes harder aswell as softening the bit itself, same goes for all drilling
