nat0_240_chevZ
Members-
864 -
2
a 280zx typ or later r180 not a s30z r180.......
FG, but nothing wrong with it, just PU is a bit more impact resiliant, but plastic is not.
i rember talking to some dill @ city dismantlers saying he had a complet l20a turbo!!, or 2 or 2 l20 & 1 l28t? cant recall but was a while ago now. No the 4cyl l20b rods are not the ones you are looking for or are after incase anyone chimes in with ye ol i gotta 200b you can HAVE!!! lol
Steve, Adelaide Z cars have same or similar if i remember correctly (i see why ppl use IIRC) for 280$ new i think their ph # is (08) 8384 8748 or look them up to check. Speak to nick (enjoys a haggle) and tell him nathan told you to ring (the one who makes his air deflectors!!! ). Ask about the one hanging up in his reception area. he also can courier it straight to you at what it costs him!!! pretty helpfull in that respect, im looking at getting one myself, although for an extra penny the CF one looks treat and with the 2 colour themes im probly going with, on my build the CF would slip right on in and look right @ home. nat0
first of all, bugger off the bj t marts, expensive 2nd rate tyres for just about anything. I use a place where the stocky and sell what ever you want not just a few particular brands and excludes the jap tyres. wheel aligntment i would say have a look at but it doesnt negate the fact, if they are driven hard without burnouts they will wear rapidly. simmple, if the wear is nice and even the id just say they have been used WELL ie pushing them but nothin toooo silly. I find michelins are quite soft & sticky when pushed therefore wear relatively quickly to the like of bridgies, yoki's etc. keep us posted wityh your findings...
good man dimitri, otherwise we buy from concept fasteners, look them up if you need, i think they are in melb too!!
only112mm back space on front, sorry did i not say the fronts are 7" yes its a 240z with 260z fr struts @ present!!! nat0
prob a 260z? ie heavier. but the COP is only a guide to what they will allow without toooo much drama's. you CAN legally still get almost anything engineered and roadworthy, provided you have heaps of coin and an engineer willing to sign his insurance policy over for it, they will not dis-allow a car because it wasnt in the easy category to comply with road safety regs. read them carefully. nat0
Hi! New young S30 owner
nat0_240_chevZ replied to S30Mike's topic in Introductions and Forum Etiquette
once you flick the swithc (ign) no longer any elec feed to coil and plugs etc, so ign timing has no effect on this in real sense, but valv timing, hotspots (to hotter spark plug) or as said above over comp'd engine with poor fuel. also too much fuel ie large fuel jets and not bigger needles allows too much fuel @ idle to bypass the needles. till then just hold brake and slowly let clutch out as it dies, also stops ther car going anywhere by leaving it in gear, will take a few tries, but will stop it over-running which also makes it harder to start again, especially when it back runs!!! nat0 -
heres a pic with my 9" wide 16's simmons 130mm backspace, just clears the stock spring perch after a small belt with the sledge to roll the perch lip up a lil, tyres fitted are 245/45/16's and 205/40's on the front. nat0
yes they are doing it WITH coilovers. i have 9's on stock struts, they ever so slightly rubbed the perch, smash the perch with a sledgie, gives me 2-3mm cl now, without touching the guard lips they stick out a tiny tiny bit, but when you load the rear it just sort of tucks in a bit with camber gain!! mind you i have 245/45/16's in simmons v4's, and have a huge dish outback nato
DO it, do it!!
mmmm NO, wheel to strut motion is approx 1.1 MAX to: 1 as struts are only on a slight angle, not like a wishbone where there can be up to 60* angle nat0
translates too.......390lb/" fr & 505 lb/" in you ol fart'e syndrome!!!!
i have seen the needles replaced with a lexus or later modern needle and have it illuminated like the new cars we all see those nice gauge clusters with bright needles.... im sure rbz could hook it up.... nat0
yea congrats to the seller and the purchasee' im sure this will only appreciate in value in time to come, a true classic jap coupe. as per my above posts, it wasnt meant to be an attack on having an opinion, but moreso to the banter and sledging which i often see here by 'some'. sure if someone is dreaming i too will have stab, but in the case of a tru fullfilled auction, the buyers determine the cars worth. not the seller. i just have too often seen an underhanded sledgeor two here which begins to make some of the attitudes here much like some of these rotor, commy boys and other forums, i thought we were all open minded and respected each others views, no ONE view is right but nor should anyone force theirs upon others, concourse is gavs view but not mine, makes it sound like a car is only worth anything of value if its a show winner. this is untrue and should not deter, effect or sway buyers(or anyone else for that matter). I do apologise for my quick to bite response, but maybe it was also on gavs part alack of understanding or knowledge of what he was refering to, but this is the case of the black spider. (ie all spiders are black because thats the one you have seen.....untill you see a green or an orange spider.) as said above re: the savanah gt, this was the shislick of models back then, much like the phase 3 foulcoons of our history, i dont aggre with their prices etc, but you have no choice but to accept them, buyer demand!! nat0
CONCOURSE this!!!!!, worth it all day long, shut your pie hole, if my z was in this gooda original condition i would ask for more!!! you and your derogative remarks about others cars really gets on the nerves of some. give your opinion fine, but dont be treading over a car you know little about, i would pay 60k for that car, if i had the cash!!! and if i was more a mazda man. there is more than life than just caring about if a badge or wheel is not as it came from the factory. you find me a better original car!!!!! cmon i dare ya to. nat0 (sick of hearing about ones views on what is and isnt a concourse winner, which doesent help for prices of our cars either, having the 'main mod' always downing them.)
should be 51-52mm od. but not to say that they are this....
yes lets talk torque (punintended), hte area under the curve on a dyno sheet!!! the more area, the better and more efficient motor. power is a function of torque and roational speed, a cummins making 984 bhp @1800rpm is far more usable than a honda making 680hp @ 12,000rpm, and gues which one has a guarenteed operating life of over 10,000 hours? yep not the honda!!! work that out in days... over 14 months straight!!!! hond would be lucky to see 6 hours before it goes or needs to be stript down and overhauled.
rofl, thats here in adelaide on corkscrew rd, awesome bit of road in your car but not on your 2 wheeler. this road is in the classic adelaide rally too!!!
tru dat ^^^^^ the only one which is the same as the rb25 late r32 model!!!, yes they do exist, before anyone thinks otherwise, i have pics of a frontcut with tags showing all this ie eng # and chassis # !!! old film foto but. also essentially the int's of a na and tt 300zx box from the z32 are too, tt has bigger flywheel and clutch but, and slightly diff starter!!!, but also a vg bellhousing, these things are very big and a struggle without some mounting mods in the s30 with later style dog ears for the x-member. nato
untill it hits the end of the hatch, then large amounts of turbulence, also causes you nast exhaust smell!!! ie suck the ex gas straight back towards the back of the car. the trailing edge/shape of a body through a liquid is the most important, not the leading edge. if you look at solar cars for example, note the large slightly changing radius on their leading edge, and the very sharp trailing edges @ the rear, promoting laminer flow after the air/liquid has been re-directed around the shape of the moving object, the solar car our tafe ran in the race to darwin had a fair few hours in a wind tunnel to prove its aero design in which it did very! well. nat0
not really commenting on your price there buddy, just that it IS available. I get to see some pretty trick stuff in my line of work and some of the things i have seen would be ideal for a customised car of any sort. The pearl i speak of above is the same (cost to me) as any of our std ! off or 2 off jobs, but compared to our regular items we get p/coated its twice the price!!! because your not selling from an online store or shopfront pples wil always ask if you can do more, not that im interested in these wheels or anything, but im just pointing out items of fact!!! if you were offering it ppl would be sure to ask how much or expect a std price, honestly id quote with the pearls and if they only want a base metalic or flat colour, have the same price, that way youre never short & less hf!!! nat0
me too! a bloke here at my work does do carbon but mainly f/glass, he used to do boat hulls/mast's in both fg and cf, for racing yachts etc etc. he quoted me to do customised inner door skins with integrated handle and speaker mould (for a 6" in the door) also with a smallish 240Z logo embosed into the pattern for approx 480$ each side. not bad really but the carbon weave is pretty $$$'ey and so is the epoxy, i asked about f/glass with a CF finishing cover, and still around 400$ mark each. cheers nat0
NO, suitably lube threads with wither straight grease or never seize, (on the threaded pulling shaft, not the Z sppindle). and make the puller with heavier tube to ensure youre right for many pulls to come. only diff by a metric etween whiworth and UNF is 1 degree on the thread angle. as above with the lube, id highly recommend the never seize option. nat0
