nat0_240_chevZ
Members-
864 -
2
I may be able to supply you........ pm me.
WANTED TO BUY: 240z/260z running a GTR Motor.
nat0_240_chevZ replied to p_walkerden's topic in Wanted
i make the ounts to put the rb 20 & 25's in, 26 are a lil different, but can be made too, mines in and mounted, doing sump now, and then electrics. can do again much quicker now mounts are done and sump nearly done also. have the detail to re-produce quickly. CRS mounts sit the motor a bit too high and off centre i have heard, hence i made my own, and their cheaper.... i have access to an rb26 to measure up as its only on emount which differs.... nat0 -
Sleeves/collars for R200 crown wheel bolts
nat0_240_chevZ replied to KatoKid's topic in Brakes / Drivetrain Components
I made some up too, cost me $0... but as i used a GTR centre from tomei, they use M13 Bolts??? yes not a typy, so my spacers wer 13.1od x 10.1 ID x 11mm long from memory........ nat0 -
Rear CV's on a Zed advise wanted on beefing them up!
nat0_240_chevZ replied to 620Z's topic in Brakes / Drivetrain Components
thanks for the info re the wolf creek items, my cv convo may be up for sale shortly, a simple means of conversion which doesnt have to adpat the adaptor to the adaptor flange which adapts to the shafts if you get my drift......... plug in, mod'd shafts to existing hardware, 1 plate only, sounds so simple, does it not??? more to come. nat0 -
may have an rb-s30 sump, custom built also available soon, as the 200zr one from nissin is no longer available and stock aorund the world seems to have disappeared........ later style gearbox mount will also be up for grabs soon. Engine mounts are still available but have sloted holes via a die grinder. nat0
Chassis Strengthening - Sills. Opinions Please!
nat0_240_chevZ replied to KatoKid's topic in Body work
more torsional rigidity to be had from the sill panel guys, not the rails. by sleeving inside the sills with cage bars or by adding an inner skin as being done above, but again with ribs and pressings or dimples. have a look at any modern car and this is how they are done (factory anyhow), but aftermarket is done with round tube/pipe as in similar to that from a rollcage addition. As the sill panels are furthar apart than the seat/floor supports (which is all that they are) they can withstand greater torsion caused by the engine, lateral cornering and combined lateral and longitudinal forces as seen on the race track, ie braking and turn-in. Your approach for a mid layer is very good for increasing strength in a vertical bending plane for the sill panels but you will also need to add reo from the fron of the sill sections back up toward the strut towers and across to the other side of the car, ie through the dash or under the trans, or through a hoop around the dash under the windshield. Think of this its great to have 2 solid beams in parallel, but you can still twist them easily about each other, this is what you are trying to minimise is the twist not the bending, grab 2 rulers or pens and play with them, try bending when holding both ends, the try twisting.....think of these as chassis rails ie close together, then think of them as sill panels ie furthar apart, it is easier to restric when furthar apart but you need to brace in an upward or downward maner to be able to resist what I and others call eccentric loading, ie loading off to the sides of the members which cause twist. the further they are up or down the more resistance to the twist. can I say twist 1 more time? triangles ar what you need to try and make as it is the strongest means of reo', but this is quitete hard with the monocoque shell of the Z so it requires some heaver sections where this cannot be achieved with some form of gusseting req'd to achieve strong intersections. Roll cages are purely design for occupant safety ie a safe strong shell around the driver, so do not be confused when we talk about making a car more rigid, and roll cages, yes they do add stiffnes to a chassis but not and nearly almost never in the right areas to aid in what the s30's suffer from, yep, need i say it........ My recommendations are continue with your mid skin, and maybe think about a round 38mm tube from a box inside the front of the sill up through toward the base of the a pillar, and a through connection under the dash, ie bolt in bolt out with the dash. Ideally what are you trying to achieve and for what purpose. cheers Nat0 -
Guys, thanks for all your interest, please check weather or not the gearbox mount is the same as your car, 1. -ie the bolts that bolt it to the car go upwards, 'earlier type' about 'pre 1972' 2. -if the mounting bolts go through 2 ears with holes on each side ie 'large long bolt' goes front to back, - 'later type' from 73 onwards. If you need the later type let me know as my mate may have one available soon, also the engine mount on drivers side, has had the holes slotted downward to allow the motor to sit lower on this side, stops the brake booster fitting ontop of the r34 rb25 inlet rubbing bonnet, the r33 models have this fitting at back of manifold so not really the same problem any q's please pm me. nat0
Hi guys, see pics. drivers side engine mount has been slotted to allow the engine to tilt less and sit a bit lower on the drivers side. utilises the common r31/r32 type skyline mounts, made from 4.0mm Mild Steel HA350 Grade. Gearbox crossmember is to suit an rb20/30 gearbox with these mounts (manual of course) Engine mounts sit the engine back as far as reasonably possible ie the shifter pokes out through the auto tunnel in my car, if yours is a manual s30 then i think its even better. Back of head is approx 50mm from firewall gearbox crossmember sits mount back about 45-50mm to suit the engine sitting about 50mm back to the std position of the skyline mounts. Made from 3.0mm HA350 mild steel This x-member suits the early style gearbox mounts ie the bolt up type, not the bolts forward/back any q's please ask, happy to answer. asking $200 for the 3 mounts (no rubber isolators) cheap new ones on evilbay cheers nat0 pm or reply in this thread only please
240/260 Power Steering options - Subaru vs MX5
nat0_240_chevZ replied to KatoKid's topic in Suspension
probly be another getting done @ same time, from 03 sti nat0 -
yes i have found similar probs here in SA, took my r200 open and asked them to put in my LSD centre from the 32gtr, they made a bunch of excuses and whatnot and said they coould do, they would have to send it to their engineer to get things machined, after I told them it needs:- -13.2mm od x 10.3id x 10mm long sleeved machined for the bolt dia difference and new circlip groov machined on output shaft splines, then just needs to be setup to achieve correct gear mesh, ie this is what the diff guys are meant to be good at. Moral of the story was I had to pay the 40$ for me to cancel the job afte they began to tell me it would be a 800-1100 dollar bill, all they had done was send to some random engineer, had it disassembled and that was it, went and collected, gave them a piece of my mind and took off in a shit, and they are appearantly diff only guys that do drag cars and whatever else. I ended up machining the sleeves and getting the ol fart @ work to do my circlip grooves, and then i assembled the diff, with old shimms and spacers from the original centre, but was too sloppy for my liking, so i then removed and re-assembled with the shims and spacers that came with the centre i bought for the 32 gtr, i used these but i had opposite way so too sloppy still,then swapped left to right and viola whatta ya know spot on backlash, and thre was even bearing blue/yellow i could check the wear / contact mark on the crownwheel teeth, re assembled and it seems to drive fine, however I will be removing and swapping out for a quaife or a GKN torque biasing centre similar to that in the S15 and 34-GTR as these things are awesome, ie full 2 wheel drive but full slip if needed for u-turns, nat0
yes 3, you beat me to it, i found mine had 13mm bolt holes (to suit) was from an r32 GTR, I have a tomei centre. There is a large thread in one of SCO_AUS' theads re cv driveshafts and lsd, look for it. back to your initial post, what colour were the flakes? plenty of late model nissan options, kaaz fit straight in as with most a/m centres as the r200 is almost identical to all later models (as Scott said check spline counts AND FIT...) the s13 14 15 r31 32 33 34s etc all essentially run the r200 as well as many others, its just the crownwheel bolt size (dia) output spline count and most importantly the fit even if they have the same count ie not too loose. and also where the circlip grooves are located along the splined output shaft. have a search for the thread I'm talking about above, maybe some could be nice and link this thread to it, mods? cheers Nathan
maybe try and look at the holden gemini rear wheel drive model, I can buy tie inner rack ends and tie rod assy for $9 ea brand new, its an overstocked item, they are clearing out, thay have 144 of them......cheap if they work..... just a suggestion as they look alot like your one shown in pic above, with the vice marks on the flats... nat0 -
ioh i dont breath this gas, i use on my WIA cp118 175 amp single phase light workshop unit,capable of single pass 8mm fillet welds, but low end is very crisp also, i find the biggest variance is wirefeed speed control, as most units you do not use more than 10-20% of the adjustable range, ie like driving your car in 1 gear. I picked this unit up new cheap, but what you need to consider and deciseivly determine, how much are you willing to spend.....then determine what this will get you new, used or from auction, online or not. nat0
i rent a G size bottle @ 19$ per month + GST and refils of straight argon cost 44$+GST, where my gas mix for argoshield or mild steel whatever cost 48+ gst. Cheap huh!!!!! But yes I rent through my work, pure argon is cheaper cause we are on such a big discount as we have FL sizes here (equals about 4 G's per bottle) yay for me, hence I love welding so much, i frown on using wood, concrete fibreglass & Bog.....lol nat0
air hacksaw, small metal blade and 4-5' grinder with 1mm thick cutting wheels.
paint stripper, then a 9' pad of the clean & strip discs to get any hard gritty PITA remainders. have to keep the pads moving as they too can easily build up heat, but i have found them to be one of the best physical methods, best used on a slower polisher not a grinder, as they are a bit too fast, even though the pads can be rated for them. these clean & strip discs look like black or purple honeycomb wheels, feel quite rough but dont grind the metal, just leaves swirls in it. nat0
3m what can i say, even their crap tapes are good.... go for the automotive tapes as they seem pimp to other types.....
have a look at VW beetle guards, in steel, they have a nice rolled lip inside them also, you can graft them on easily....ish if you have some form of exp, then just bog/f-glass to blend the joins.... but otherwise imsa's are a good flare, if you have to chop up the poor girl......
google henrob welders. its a low pressure oxy accetylene, stuff all heat due to much smaller flame size achieveable, used by many older type resto guys here, but only small minority to all out there.. never tried one, but i am eager to Nat0
yep, usually dark blue, has all screw on connectors, jst your last nitto/ryco etc fittings for your flexi lines. Z-rack, like a metal lip in the concrete used for pulling cars straight or back into square, usually a crash repair tool also, but whilst your at it, it makes sense, if you have to square a car up with 10 ton+ puller and a few chains & hooks. but just a suggestion.....not everyones cuppa..... nat0
hoist, z-rack in the concrete, for pulling cars few pots for chaining down to, again for pulling. secure tool storage. overhead and side air outlets as mentioned, power, on every beam etc lol yes an overhead beam that is rated to lift 500kg-1000kg for engine lifts, on a monorail roller even better. with an electric chain/rope hoist even better, saved the cahin from the block & tack scratching everything..... large fridge for.........more beer heater for winter. evap cooling for summer with doors open wide of course. sprinkler on the roof for summer to cool the roof down..... strippers on saturdays and motorbikes for sundays.... anything else you want?? nat0
will a fs5c71b gear box take the power from a ls1
nat0_240_chevZ replied to red76z's topic in Gearbox
it will take the power no troubles, but the torque it will not. you would be better to use the 71c out of latter models but torque will still snap them in a few spirited uses / applications. would suggest a tremec t56 or getrag or supra as the g/box's main case is smaller and easier to squeeze into the tunnel, also you will need to consider what type of g/box x-member mounting you have ie ears or bolt from under, the ear types make it even toghter than the earlier bolt upward type. just some things to consider....... nat0 -
joint sealer will help seeal the lapping piece, for a few years or so, as the seam seal in all cars eventualy crackes or lets moitsture in. not always the seam sealer, as the weld on your welded face can easily have a small crack through it and you wouldnt know, then it will let moistur in behind the sealer, and not readilly let it out, but if butt joined does have some hope of escaping, We quiet often see craks in welds that look perfect, it is not uncommon and without any garentee that youve sealed it from at least one side, well what am i saying, its steel and it will rust provided the conditions are right regardless, all we can do istry our best to not let those conditions occur. I have regular contact with guys in the trade and ones whom charge out 50k + for a metal only resto's they dont use a swaged lap anywhere except on 1 piece panels they cannot fit into standard sheet widths oe 1200 or 1500mm, ie some larger quarter or bonnet panels, in which after the lap they grind out ther re-inforcement swage anyhow. but each to their own, there is no 1 right way to do anything now is there??? all methods have their own merits and flaws..... nat0
i luv it......and he spek no inglish. youll have the same probs as 450z on hybridz, with the steering, but that was a vh not an RB. still quite achieveable however, just needs more work, dont let it put you off. nat0
