nat0_240_chevZ
  1. Mmm yup, check where the front rail overlap finishes just behind the firewall, under the floor rails... This is where both of my cars and most others I've seen crack, ESP with only a mild dose of twist. You may need to up spec or reo the floor rails too! Unless your cage has this all covered. Nice Tq no.s too... Nato
  2. i just wouldnt chance it on a steel block, ally block arent so bad as the oil pump will much/crush an alloy shaving and spit it into the oil filter, (if small / thin enough) Swarf will ALWAYS be on the back of the hole, TRUST me, drill a hole as best you can in a 3mm Steel plate, there is no way of doingso without having a burr/swarf laying around which can either now or later end up in the oil pump. pump may score the housing and rotor/vanes but can easilly snap the pump drive shaft. The oil pickup mod, with a tube bender is the best option, Ive done it a few times and worked the best with the least amount of 'professional' involvement. have a closer look before you break through into the oil gallery. Nat0
  3. steve, I have done this mod, best thing to do is modify/extend the oil pick up rear ward. saves getting any metal shavings in the oil lines/gallerys and somewhere you dont want it to get to, ie oil pump moving the dipstick is the easy part, but you need to use the zed pan or cut'n'shut to modify to suit. Just be careful of the extension of the picup, as you have limited space to direct the new 'add-in' piece. you need to consider sump the block clearance, its not ridiculously tight but you need to be mindfull of angle/routing diametr etc etc. also the pic up end/screen needs to be off the bottom of the sump, to avoid starvation, especially if there is a dent put in the sump later on. nat0
  4. or in the wheel arch itself, the tyres turning at anything above 30kp develops quite the turbulence of dynamic air. Just need to deflect any rocks flicking up into the wheel arch away from the cooler. Nat0
  5. yup! giggle search with images, none handy
  6. Yup, common as. Ive done the same, beat up your own. few pics below, but cant find any once it was finished off, also had to do the inner. ended up metal finished, probly overboard for an area which will be covered and forgotten about. nat0
  7. No, as the mounts Ive made already drop motor down and back as far as I could get it. But depending on the gearbox combo, model/year of car etc it can & does differ a lil when talking g/box mounts. 25 or 26 the mounts are good for, but the sump flanges differ quite abit. but these can be done too. nat0
  8. GREAT, thanks Billy, your panel beater did a good job. glad to aid & assist you resurrect this area of your car. I look forward to many more pics and stories of your experiences, aswell as others, with the use of some of my gear. PS I absolutely love this colour.... esp on old girls like these. Nat0
  9. I can help with all the mounts....
  10. David, try AM Performance........? http://www.amperformance.com.au/ Andrew is his name, has had some great sounding, big numbers etc. I do believe also involved with Wilal racing too. lots of experience with RB powered cars amongst the SRs and VQ/VR to name a few.... I would suggest you have a look before committing to buy Nat0
  11. nah mate 2 seater, those crazy jappers sit in the rear hatch area!!!!
  12. rofl'ing. at least this pom's got a hell of a sense of humour. lol
  13. reserved for Shopping List and ID pics
  14. Mmmmm, Interest...lol can someone start/take a tally of who wants/needs what? nah I better do this....SEE NEXT POST You will also need to be 'very' model specific, possibly need to offer the pics to differentiate between the, at least 3 types I have come across thus far. Also the chassis rails on the 240z to 260z differ in where the narrow down, about 5mm per side, thus also effects the parts ive made.. other variances I have noticed (which effect the lower rad support):- 240z -shallow offset in center section -LH rail end has either 1 or 2 holes for a tow-hook bracket? -open type formed oblongs (on back panel) -some have slots, some holes for the locating of the horn brackets (from memory, been that long since Ive had an assembled car!!!!) 260z -Closed type, formed oblongs (not open like 240z) -Much lower offset/drop in center section -taller higher center grille mount (to compensate for the lower box-section) Things Id need to know:- -Model- 240z / 260z / 2+2? -Year - -Picture if possible, or please ID one of the pics supplied. -Pieces you'll need, ie back panel, front box section, (brackets not yet done, but could be?) -Measurement between the 2 rails, at the front where they narrow (mainly important if the car has had a rail change in its life or is seriously out of shape from an accident(s)
  15. mmm, yea i agree. I saw one mod which is the smallest, easiest and simplest bracket I have ever seen. it was a folded U-bracket with sheet of rubber, and pretty much 2 tek screws/bolts going into the front and back flange of the rubber isolator (diff half) it went under the front diff x-member and stopped the diff from lifting off, even usable on a broken diff isolator...... I personally think, that often, simple is best, sometimes and I would gladly throw the rt style ones i made in the bin, and then mass produce the above mentioned ones for others. Key benefeits:- -CHEAP did I say they would cost stuff all??? -Easy to fit, No removal of diffs, upper straps, brake/fuel lines etc. ie can fit , whilst car on ramps, or one side up on a gutter. -Quick to install & remove if req'd -longevity - rubber sheet will last forever...... Ooops, sorry ti Hijack. Ill start another Thread.....one day.... PS I wont take any props for the Idea, I just rmember seeing it and said to myself, god thats simple but effective.... So if anyone can ID the the bloke responsible, Ill def pass on any cred. Nat0
  16. yours rusted out too??? lol just the back section??? or the front box section too? Nat0
  17. Oh and a couple more...... come out alright, and with minimal fuss, Nat0
  18. an update, I have a 260z front rad supt, which needed the inner panel replaced, here an alternative for the above, including a quick snap of the install too. Thanks to Ledge, for the offset bead rolling. Cheers Nat0
  19. As Promised, I read this post ages ago and roughly drew these up, only since ive seen it get bumped a few times have i bothered. Changed the layout a bit, to make it EASY to cut and bend, then weld corners only, mayby whack a tack welded nut on?? hole size for bolt is only 11mm, so clearance for an M10 or tap to M12? Also the gap between the 2 flanges is an easy 50mm, so check with the rubber bumpers you may already have. These are strictly the 1st offs and are unwelded, can be if you want? Ill check fitup tonight when I get to my wk-shop, need to check brake and fuel line clearance.... Make an offer..... Nat0
  20. just made a couple, similar to above. any interest? pics next post......
  21. Ive got that diagram in metric for those that need...... I can also make you a folded one, without the welded in brace, just welded corners, unless potts wants to offer this? How do I copy paste an image into a post? mmmmm Nat0
  22. i know i have one, but not 100% if i still have the 2nd one too..... im currently in process of grouping all my zed stuff as I am moving workshops soon, so ill keep my eyes out. the 2nd one I had from memory is missing a mounting bracket on one lower side, but its an easy item to knock up. will keep you posted. nat0
  23. Thanks Billy, glad they worked well for you. been away this last week and missed the posts. your beater has done well, glad he found them of good fit too. Tell me, how solid do the floors now feel, say if you were to stomp your feet while seated etc. Appreciate you posting your pics, comments and feedback on this thread, cheers Nat0
  24. mmm, yes very interesting..... gearbox mount it well gone, and front brackets are weak as piss, with no gusseting. you can probably easily straighten the front L-brackets, replace the g/box mount and radiator, but im certain if this happened in an emergency stop, as advised by pete above get the whole thing checked over. another case in point woild be TC rod bushes, are there any left? nat0
  25. when i rang they gave me 110 each assy? got them to check, and they came back with a definate response.....?? nat0
