nat0_240_chevZ
Members-
864 -
2
might know where one of kias old boxes is living now....... ill ask about, i do remember one holing'r available recently, but had no reason to ask, as the price tag is beyond my requirement. nat0
EOI Group Buy on Techno Toy Tuning Parts
nat0_240_chevZ replied to d3c0y's topic in General Discussions
maybe make locally & save on shipping..... just a suggestion. -
yup should be there no Z no dyno, just need to make an appearance. knat flackers lately. nat0
Re-routing front brake lines?
nat0_240_chevZ replied to PeterAllen's topic in Brakes / Drivetrain Components
go for it pete, im doing much the same with my lines too, obviously commom sense needs to be applied, but for someone like yourself you sure seem to be devils advocate when it comes to making any changes. Yes grommet or even a fixed sleeve with rubber liner as Ive seen used to run brake lines and abs electrics through also would be quite suitable. Ill be sending my lines i dare say straight down through inner fende then up over in the tunneal area, with appropriate shield for protection from any lost drive train components along the way. Im sure heatshields and debris guards where req'd would not go astray. oh i forgot to add, my reasoning, is i have closed up non essential holes in the engine bay. going for the "clean" looksies. nat0 -
circled is the residual pressur device for the rear brakes. I have had this located in some of mine and my mates cars up in the engine bay, next to the pressure diferential switch, I feel it was moved to due to bleeding issues or otherwise pressure drop issues for the rear brakes, At this stage I am unable to work out if this was moved rearward or frontward and when. Some master cylinders had a rear resid pressure valve for the rears in them, some didnt, when some people have attempted mix n match with new masters they have found there rear brakes drag, due to having 2 residual presure valves in the system, and other have none, causing rear shoe knock back,so have a spongy pedal due to this. Like most things in manufacturing, its all little changes along the way, never assume the first car and the last car on/off the production line within a week or fortnight period are "exactly" the same. Nat0
RB sumps to suit 240z / 260z, mk-2 done check out pics
nat0_240_chevZ replied to nat0_240_chevZ's topic in Engine
Sump revival, request by jonny!!!!!! ok will get this done soon!!!! -
insurance was no problem for myself on a previous repair, as they are unable to discriminate or dodge a claim, based on this fact, especially if there are receipts for the repairs (which you also need for a tier 3 insp). Dealers wont touch ANY of my cars, ever again, unless they are repairing something like a recall. I just dont trust them, I have seen the guys out back and lets just say, good mechanics DONT come normally from dealers. I would say go for a repairable write off with caution, But having done it myself, and helped out mates also going through it, It IS a headache dealing with power hungry authorities, whom have no real understanding of the industry they represent (ala regency park), OK they are there for a reason and yes there are alot of dodgy things going on they need to filter out. But my inspection experience was hI had to do the tier 3 twice (well a re-inspection, quick re-visit) then 1 roadworthy. The paperwork means MORE than the actual repairs performed, IE for example. Took car to a wheel aligner, all aligned (car had 4WS/hicas) gave me a fancy alignment report (spec'd up almost spot on), Needed this in the tier 3 and roadworthy inspections. Got through both inspections, and whilst leaving, check mirrors on both sides to see the car felt like it was crabbing. (both side mirrors showed me the gutter) Yes it was, the rear end wheels pointed to approx 1 meter toe, both in the same direction, needless to say im glad this wasnt picked up on inspection, however after 2 more return visits, to the wheel aligner, whom assures it wasnt his fault, then the car is BENT? I took it elsewhere, and straight away the aligner broke down in laughter and fixed it back to where it should be, I left and alignment was awesome, but had to return the steeringwheel back to central as it was moved 1/4 turn to the right, by prev wheel aligner. all sweet there after. If the inspections were doing their jobs they should have found this, and also the inspector at the roadworthy had to ask where it was hit, as he was unable to find traces of repaired damage, thats why we call them good tradesman, they do their job.....properly. nat0 rant end!
just buy one where owner had no insurance and fix youself, no insp req'd
After-market LCAs without rod end bearings?
nat0_240_chevZ replied to PeterAllen's topic in Suspension
the other big problem alot of the hybridz guys experienced, is the have a separate toe adj which seems to cause the binding. IE the chapman strut and its spindle pin, NEED to articulate parallel around the LCA mount point. Adjustin one inboard and on out board Does give you more camber, wider track and some toe in on the rear, but as the stut cycles up and down, one of thos links needs to gouge out its mounting hole just to bemp/rebound freely. the trick to get to independant of the spindle pin missalignment is to separate the spindle pin from the lower par of the chap strut assy, OR move inner points freely whilst keeping the spindle PIN and the mounting pivot axis parallel, but also square with the sturt top, as most forget the strut top is preventing the top of the assy moving forward and backwards. think of the strut as a big spanner/shifter, fixed to the lower stut housing, if you swing the LCA and this housing in anything but, directly towards the top of this fixed lever, it will generate a front/back pos'n change in the pins and bushes etc. This is why a models later and some more research into the rear end geometries, Nissan amongst other went to a single point connection on the rear ends (a ball joint) and then proceeded to adjust toe independantly of the arm length or position. There really no reason this cant be achieve with a simple yet effective AM LCA and bearing housing update, but if you want to keep things stock, then dont mess with thtem too much. Oh, Did I explain the 12 different cutting actions? ledge.....Cracker!!! -
Peter, Id say thats just a design flaw on these AM units. Most I see Are not able to design sufficiently for an auto application, Material selctions is just what they have been recommended with only basic fabrication Knowledge. Ie using of 4130CrMo, without pre-heating welds and also then allowing to fast cool, from memory this is not how to do it. And as for binding, this also has alot to do with support accessories, Ie driveshfts, swaybar links and bars clashing with control arms. Also another key point in alot of these designs I have seen , is they seem to use Threaded hardware to take shock loads, transversally...not sure what they are thinking as the threads are/will always be a stress raiser in their design. Just hold out for a while and I may have something of interest. Got heaps of ideas for this ' ultimate' control arm, but need it to be manufacturable. cheap, DID i just say a naughty word??? SAFE, over and above everything..... and easy to setup and adjust, when req'd. Have some give, in the design to cater for bumping the odd gutter or similar abuse. OEM styling!!!!!! sounds like a demtel add!!! HAHAHA nat0 -
Epoxy vs Etch primers for bare metal + process
nat0_240_chevZ replied to thriller's topic in Body work
wattyl is a phos based etch!!! the one to stay away from i mentioned above is standox 2pac etch. Wattyl is said to be the best, and i tend to aggree, sticks like shit to a blanket and its adhesion is f*&^n awesome. as i have done these 'wrie wheel' test on my bench grinder. tough as, even though i thought it would not do to well only being a single pack etch. but it is compatible with all 2k prods.....appearantly. Nat0 -
yes, i also forgot the 2 pac etch epoxies, also a very good option, PPG & sikkens one I DO have first hand exp with, (but must have forgotten, must of not worn a mask!@#$)worked and sanded really well as they have quite a bit of build for what they are. although stay away from one brand i came accros, its 2 pac etch was able to be slowely wiped off with thinners, (which 2 pach should not) cant remember brand But ill report back. nato -
i say Etch, most painters say Epoxy Prime. end of day metal needs to be cleaned, then sealed. consult painter involved, and then seek alternatives. Speak with some older guys then speak to some new younger guys. opinions differ alot, but the new chem on most products if used correctly do work out a better option. I use wattyl super etch, more hard wearing than poo15, confirmed independant test in my workshopp on the wire wheel. its a single pack enamel & compatible with all 2pack primers, I know of. My opinions based on my own experience. nat0 -
Read "REAR"-lower control arms... Peter, maybe later down the track....... Nat0 -
dimi & G, that link does have l28 'et' in the title, so id suggest it is setup for a turbo app considering the turbo block. but the N42 throws me a bit.
ok all, here we have some updates. Floor rails batch #1, only able to yield 2.5 pairs per sheet, less than hoped for, was hoping for atlest 3 pairs, so ill get more HiTen sheet ordered in asap. Both pairs are pretty much already sold, Thanks Katokid for your patience, first one on the bandwagon with funds which kept up my obligation to see them through. Batch #2 on their way to sort out all the other enquiries made. These things are all go, pleas pm or email per first posts. then we will be on to the deeper 260z & 2+2 rails for those in the hunt still, (apologies on ignoring you guys and leaving you till last.) See pics for the following you will see. - 1 pair of Full length floor rails nestled inside 1 pair of engine bay rails, strapped together with cable ties, ready cardboard wrapping for postage interstate - 1 pair of loose Full length floor rails, in all their glory, awaiting new body & floor to stengthen / revive. - 1 pair of rear subframe to existing STD length floor rails. Material used IS a Galvanised material, sand, blast or strip if you see fit, leave internal rails asis for long rust protection, but it IS a PITA to weld nicely, a little bit of spatter will be had. Material is a Grade 450 (Min 450Mpa, actually specs out to near 520-580Mpa min Tensile Yield, with UTS upto around the 610 MPA), link Here http://www.bluescopesteel.com.au/files/ZINC_HI_TEN_G450_G450S.PDF which is about 1.5-2.5 times the strength of the off the shelf sheet steels, this stuff is used for guard rail uprights, Long span beams, and other med to high strength requirements. Please be advised the floor rail are nearly completely UN-welded. I only Tack in the corner rad's as can be seen in the pics, this is so they can be manipulated furing install. Hope you like them, let me know if there is interest. Will advise those whom have expressed prev interest via email, of ETA of their items. cheers Again. Nat0
Hi Guys, Yes good day out in the sun, pregnant mrs. doesnt help to stay out an chat with the boys. Was good to catch up with the few I caught up with. There were some excellent examples of pure modified jap cars, some local some imported. My highlights were.... 2 x green rx4's 1 x ra23 celica, black metalic pearl, nice well presented car this, (near the boys zeds too made it easy to see!) Orange 180b 4 door and orange gem tc/td coupe next to it. the lexo sc6 thing in the middle. the blue corona wagon 2jz powered, (very nicely built retrofit, extremely well fitted and positioned in the engine bay, el grandma spec, quite liked it) the black 1600 and the black rx3/4 nearby..... Some bad examples, but im sure the owners think they are pimp!!!!. s14 with stitch welded eyebrows over the tyres, (great example of how not to weld too!!) just some bog stock barely mod'd adm s114/15's cmon lift your game. Looooved the Red GTR (replica if it is or not, dont care) this was an absolute stunna, loved the presence of this thing. anywho, no more BS. i need to get my wheels out there, no more fn around...... nat0
rare spares replacement floor panels in a 2+2
nat0_240_chevZ replied to zrevival's topic in Body work
Hi, see pics as promised. looks like they are longer than i had thought, cut behind the rear seat mount. probably pretty good for what your after. note the LH floor rail is cut at the front, where the engine rail meets down on the floor rail. i have a dodgy underside pic, below but its about 200-300mm behind the firewall the floors are not to bad, except the gearbox mount brace has also been cut out. let me know what you think. sorry i wasnt in my workshop clothes, so i didnt get inspired too flip it over for you nat0 -
yea......correct. but keep watching!!!! -
mmm, http://www.viczcar.com/forum/index.php/topic,11926.msg121627.html#msg121627 -
ill get some pics when i get down to my workshop this weekend hopefully. will give you an idea of where the cuts are too. will try to get pics of rails too. nat0 -
how much floor do you need? got a ppic or a good description? I have a late 76 2+2 but its been cut in half, so dependin on what and where? might suit what you need as a minimum??? nat0
