nat0_240_chevZ
  1. or attach/weld an endling tab on the struts and go up!!!! same as before........ much like most other cars on the road, but they tend to use 200mm or longer link rods.... just another suggestion. or add the extra mm's outside of where the SB ling attaches to the LCA. either way still works, or as mentioned above, just re-drill and re-inforce this point...... nat0
  2. yup the ones from MSA are the tabco ones from rustrepair.com. the gave me 4 months leadtime also. part # is 16752 L-R 49.75 Rear Quarter Lower Rear Section 21Lx10H weblink here----> http://www.rustrepair.com/PANELS/240-260-280Z-70-PATCH-PANELS.HTM but price was only 49.75 USD ea. but put an order in before youre up to it where you can, and you wont get dicked around by long leadtimes. but hindsight is a beatch!! nat0
  3. Rustrepair.com has them, ex USA otherwise.... NATO
  4. change engine mounts to your upgraded option first. gearbox mount is ONLY there to support dead weight, not twist. First thtings first Buddy! nat0
  5. Id be up for a pair if they included the top 'steel section' too....included as part of the door card. moreso for the actual fit, rather than having a 2 piece door card, provided there is still plenty of flex in the card itself, to install properly. I think freddy needs a heads up......imo! nat0
  6. Updates June 2014 dont worry about the quick clamp, was there so I could mock it up and remove easily, as i didnt want to scratch up the galv paint which was fresh, overall pretty hapy with fit, will go the one piece design over the 3 piece for the box section, it will comout better than the one in the pics.. Note the M8 riv-nuts for horn mounting, already installed! Only thing I didnt check was the thread pitch on the bolt, but its M8 fine from memory. Hope you like, and PS the 260z front section is ALREADY developed, (as i had to make one for my own car, so can do the 260z lower one also) Keep in mind the front rails for the 240 & 260's are slightly different, the gap between the rails on the 260's is 10mm wider (5mm per side) at the front where the rails taper outward for the radiator, as they have a greater offset up front, (same however rearward of this!!!!) this effects the rad supports also, so if you have a butchered car, (ie had a 260z rail put on a 240z) the rad support WILL need slight mods to match the rails...unless you buy some new ones from me also!!! cheers Nat0
  7. more pics and points of interest. #1 Showing the back (engine bay side) of the main front panel, you can see some distortion (te be plenished upon install) this was what I was reffering to in above post, but im sure the likes of Ledge and few other guys about the place will have this sorted, real easy. #2 with some added press lines, although I am likely to change this up a little, but nothing too drastic, Will add larger radii bends and also make the offset deeper than what you can see. #3 another angle showing the relefs and also the distortion these extra pressed ribs add to the panel. Also note there is also a top flange to be added to this development (which will aid in stiffening this panel aswell as keeping it flatter along the top), but I had limited in time to finish drawing this, amongst having other constraints on the day. I also have a Video im yet to upload to youtube, about 2 vids both about 60Mb, of the actual cutting of these puppies on the laser itself, some of you which may be interested. Ill post a link when I get them up there. Also on a side note I am thinking of running 2 smaller intercoolers up front. one on each side and tucked as far, to each side, as practical to the main opening, thus allowing a bit more radiator thru flow, this is dependant on how many times I change my mind in the meantime, I will have to look at a custom pattern to allow the intercooloer piping to route through the rad support exactly where i need it to, so I dont have to elongate holes or enlarge existing cutouts. The Z rad support panel is already really generous in holes/openings for this, although I dont think they will suit very well, But we shall see. nat0
  8. Ok guys and girls. here is 4 pics of the next step of making the radiator support panel. this is only a 'first-off' blank which will be used as a mockup only, so it WILL get used and abused and then thrown in the scrap metal pile.... The pics below show #1 the blank, as cut, from the laser. it does have a series of end lines aswll as other detail which is used to mark/indentify where forms and other pressing marks are added. there are also very small pierce holes to position where the factory spotwelds were (on the donor pannel in hand, as they do differ from car to car, this is moreso a guide more than anything for re-spot-welding). #2 Is the 2nd version of the lower rad support box section, showing the infill pieces, (voids in the flat blanks, when folding but not when stamped by factory) these pieces will get trimmed up and very discretely welded and finished in place. #3 Is a pic of aquick rough out of where the formed side flange, where normally wiped over by production press, now roughed out by hammer/dolly and anvil edges. this could be done much better, by shrinking the external edge flange and stretching the internal edge flange this not distorting the main panel so much and giving a nicer overall finish. You will aslo see that in this pic I have paired up the lower box section and the main panel for visual mockup (to make sure I have done it the right way more than anything!) #4 Again just for visual reference, both parts almost standing up on their own accord. Note the lower section not quite sitting central, was a lil rushed taking pic before they fell over. More to come, next post will have some mold presslines added to mimick the "factory look" and to siffen it up, You will also notice that none of the factory holes/cutouts have had their formed lip added, im saving this for rev.2 this week, but will be busy knocking out all the floor rails I think!! nat0
  9. Hi all, as some of you may have seen of late severl posts/topics of everything to do with restoring/replacing or retrofitting. here is another one of them. Aimed at ones whom want a fresh start, with the usual 'looser of any front end battles'. here is the start, the very start, of all the hours I put in to a relatively complex development, hours upon hours of measuring, drawing/drafting, checking, cussing & re-drawing and re-drawing again anad again until they are perfect (or nearly there). This Development is not neccessarilly one I need myself but I do already have the need for the below pictured lower box section, The 3rd pic, is also a layout of the front panel from top to bottom, which I am currently working on, again I didnt NEED it but it would be nice to put a new one in and also to help out others. now the only thing left up front it the top cross piece which houses the bonnet latch & corner gussets amongst others. Ill try to keep this thread pretty clear, there will be a few extra bank posts below, for future updates. Cheers Nat0
  10. sure....... just answer pm i sent you so you know where to get them...... i cut some new ones, as i wasnt sure if i knew where they were. but you can deburr them, and bring your shocks along too to check fitup. and a strut tube if you have it out of the car.... whar about you do you reside? nat0
  11. this is a sad state of affairs....... talk about customer service....... they ashould just list their stock online, then at least you know what, where when and how much list at least.... then get your crash repair buddy with an account to order!!! lol. so much for doing their job for them, hard to get good workes these days...unfortunately. nat0
  12. ROFLMFAO I love this one, its what everyone would like to do no matter what others would say..... Mmmmmm I wonder if there really is SOMEONE that would...... Silence.... Silence..... Yep I thought there would be too.
  13. Cheers ledge'y, not bad yourself either, only just found your updates re: roor section and door corner. Here is V1.0 of the rad supt, I missed a couple of holes ontop I forgot about, but for the first one off the bat, i reckon you'd almost drill them in yourself........ The back section with the formed holes and also, (since popular demand and I think I may need to raplace one of my own....) the whole panel with holes for very exclusive RB intercooler piping ;) yes thats my eye twitching...... coming soon.... Nat0 PS to floor rail peep, not ignoring you, just want to finish developments, so my late night can be spent working on my car not revision after revision. very close to the lot being ready to rock!!!
  14. ive made them here, on another thread somewhere. might have some around still too.. nat0
  15. Lower radiator supports now under full development...... Floor rails and suits will be run all together now. Both available soon.....
  16. Look to be for early 240z only judging byt the trans mount..... just FYI, also look out/check for bracing on the engine brackets, unable to see any from pics shown. althought this style of captive mount is 'my preferance' for retrofits, but needs to be 'beefier' IMO. cool find, treat any aftermarket items with contempt, ie would your engineer pass them? before handing over cash'ish... nat0
  17. c'mon how factory do they actually look? Please Note!!!! all factory tooling and jigging holes as seen on your stock mangled/rusty rails, all come out in the exact spots / factory positions as original ones do. these replacement rails can be installed by any competent general panel shops with car jigs and aligners etc. or make a pro-restorers job a bit easier and save some time. No welding will be done on these obviously some-welding of the missing corner flanges, as the installer will need to hammer/clamp flat and close up gaps before welding, to suit your floor and whatever shape you're car is in, as they have been beaten and battered of many years. If you're changing or thinking about changing your floor pans, this is what you will also need, want the full length and extra strength of the rear connectors, running big torque engines. Now onto the lower radiator supports and then maybe long &/or short nose diff cradles to suit s30'Z
  18. ok, an update for those interested. Full length floor rails including rear connectors are NOW completely developed, first pair came up great. see pics below. but i will/ should probly start another new thread... ANY Questions probly best to PM me, as to try and keep this thread clean. (-er) have plenty of pics on and off the car and mocked up on the bench with my Front engine bay rails. for those that have asked about capping rails( although im not a supporter), these ones pictured are infact a slip over just so I could get confirmation of the shapes, profiles and agles, actual one that will be available will not be. Like Peter has said before the rear connector area is a pain to developan that it was, with the front of the floor rails coming in a close 2nd. Those of you, that want more pics shoot me your email. I know some of you have been patiently waiting. cheers for the supt til now. Nat0
  19. floor rail update..... lookingood, just 1 last change. PS dont worry bout the red circle, missed the bendline on this mockup item. nat0
  20. keep a 'sunroof' but make it a flip metal tin top lid type one, ie body colour and pics up and slides back, but has a very minimale gap/line, ie almost un-noticeable. but not sun/seethrough like it is now.....maybe just paint it, but the current one does not have the 240z curve in it.....hint hint :wink:
  21. ANY DAY NOW........ (mrgafrickenmrgaballbmrgabreakermrga)
