nat0_240_chevZ
  1. yea that sounds like my old 2+2 box, what is your diff ratio? is your speedo right?? or it reads lower than you are doing? with a CR box its just 1st and 2nd that differed (shorter) just loose thoughts at this stage. how you describe the gears ets would indicate that but if the diff ratio is a bit low ie a 3.54 then yes 3rd would be a beatch, cause when using a 3.7 or higher you are able to push past the slow bit of 3rd ie low torque revs. anyways, keep us posted and check out your diff ratio and your speedo reading. nato
  2. sounds more like the 1st and 2nd ear spacing, maybe close ratio? biggger gap between 2nd and 3rd??
  3. cheers for the info.
  4. that baby poo brown is one of the best original colours IMO, when paint is fresh it looks clean, when it ages it grows on ya. silveris a good choice, but sure it wasnt available on the early builds. there is a link somewhere to what colours were avail for what year (in another thread here). does your car not have interior? or some at least that is unmolested? should be a good sign of where to start. if you want to build a cincouser car then it onoy matters that the colour is right for that model/year etc, so take your pick, white,poo,blue orange etc. look into it more on hybridz or zhome.com, beware as US models had some discrepancies vs our aus/euro delivered models. nato
  5. me? what sound and who to?? nato
  6. is it a 260??? i know this is more than common, can be fixed in the small plastic bit that sits in the back of the barrel, contact breaks and is only sort or something i remember reading. although this extra turning on the barrel i thought engages the inhibitor switch/relay, havent done a great deal of checking in either the wiring diagram or whatever, abouth the broken contact is off the top of my head from what i read on another forum. it is actually a really good occurance, good for theft prevention etc just takes a bit of finess, keep your barrel for when you loose or break your ignition key, or bugger the barrel!!! i actually really like it, i suggest you get used to it and see how you like it, if you were a theif what would you do? turn all the way!! (or anyone else) nato
  7. meant to be there. meant to break off after installation. so your existing one may be already snapped clean off. use a small pnematic cutoff tool to put a slot in the head and just use a flathead to remove. nato
  8. i found another mount which leaves all the top strap etc, but has a small loop of folded steel with a slot to allo a lil bit of give but give it a bit and would limit out (only about <10mm). heres the pic: oops i see its a small rubber/poly pad, bbut id like/prefer this to the other but only because it looks so clean etc. and leaves the stock strap in place. need to make sure you have a good insulator on the cross member of course. nato
  9. the fellow here, i believe hes registered on this forum RBZ_260? believe it was slot and reinforce the engine stand/pedestal, and heat and bash some clearance on pass side, also i think he said a custom drivers side rack mount bush. Also rotating one half of the rack helps with lines location etc. hope he chimes in here, nato
  10. i may be in for one. however the subie rack could be an option from the pick apart or local wreck yards. also a very good swap. keep me posted with the details, as il probly need PS since i broke my back and neck!! :x was going to leave it manual steer, but i think the ps would be advisable. nato
  11. you can source the part no's off of hybridz, just do a search, has mounts. oil pickup and orings etc. if you are any good at doing rust repairs you could cut and reweld the sump body back tho the flange @ 180deg, like a fellow did here in adelaide. Also from my discussions with him i think he just had to slot one engine mount and also the gbox mount. nato
  12. yea good for those of us with v8's and big torque turbo engines nato
  13. try this one then http://www.kameariengineworks.co.jp/page47.htm look down the bottom. wow!!
  14. my good friend has just picked up an r32 with an rb25det but non vvt. all plates match on the cut, engine and body # etc. Also not the first one i have come accross. also this non vvt head is the prefered head for the rb30/rb25 hybrid. nato
  15. z31 turbo fronts, need spacers to run their rotors, otherwise chrysler voyager rotor with only slight machining to fit with stock or 4 pot toyota calipers. rears, well these ar a lil harder, i made some 5 stud rear hubs look for r33 cv lsd conversion in the tech are or classifieds i think. also ill be getting some z31 4 & 5 stud rears ready for swap over soon. could redrill rears like i have seen but 2 of the 5 studs are dangerously close to the edge of the wheel flanges. nato
  16. i had an old link that shows what ratio goes with what colour #of teeth goes whith what. nato ill try find it and post, unless someone beats me to it.
  17. early rb25's did not have vvt, in late r32 and early r33. neo has the new intake with variable inlet flow and a few othe rintake goodies.
  18. go the rb30 with the 25 head and the 30et turbo props if you can, ----that'd be sweet------- nato
  19. grae, you running r200? i found long nose gears setsin japan but are about $1000 aus ill post the link soon http://www.google.com/translate?u=http%3A%2F%2Fwww.kameariengineworks.co.jp%2Findex.htm&langpair=ja%7Cen&hl=en&ie=UTF8 check out the 3.154!!! sorry to thread jack nato
  20. thought the zx's with efi ran unleaded with the n42 anyways.... will cause bugger all damage anyways like i said above. aslong as ther is no stupid amounts of pinging, which is the real cause for premature wear on the softer seats, you will be ok. Really when you think about it the valve guides will need replacing before the seats, so when you rebuild, you put hardened valve seats in, cost a bit more than a basic reco but the money youll save on the additive, and if you run ultimate or 98 ron then dont even worry about it. id be more worried about the condition of the roads and what its doing to your shocks and other susp bits, aswell as the frame rails. nato
  21. not crazy, theres a powersteering rack on ebay atm.
  22. If the ratios differ, which they probly do, need to match the right colour speedo gear in the g/box, its this gear that is suited to the different diff ratis not the box itself, not too hard to chabge either.
  23. well yea i happen to have an f54 with a p90 sitting in a parts car!!! odd combo seing it was carbed. cant say for sure the condition of it, but i may do something with it. bought the car complete for cheap, the guys didnt realise what was in it!!!! and they wreck em!!! 280zx or any l-series turbos manifolds im afraid not nato
  24. look the us stats are always gonna guide you the wrong way, US had much tougher emissions even back then. in my experience (4 z cars), never had a problem using unleaded. even running 10.85:1 comp on an l24 n42 shaved 2.25mm. ran fine i was able to advance the timing slightly for better pickup and only pingged on load below 1.8k-2krpm in 3rd gear and above. dont worry yourself with the additives. cost youll pay couldnt be worth more than getting the head reconned with hardened valve seats......see my point. is the car on gas by any chance??? if so youll be fine if the have already been done. whats the casting # on the side of the head between 1 & 2 spark plug??? just out of curiosity. nato
  25. well you gotta start somewhere. yea go the rat rod, drop a chev in it, aka the rat. yep u should have funlearning how to weld, good experience to have with one of these cars. nato
