nat0_240_chevZ
  1. mm from som additional research, make sure the coilovers have rebound limits, as some of the weld on kits when you jacke the car the springs become inseated. a good setup is that similar/same az the arizona z cars website. you can adjust height independantly of the spring rate/preload which makes a massive difference to ride, as you can specify a certain amount to overcome the preload without affecting height. also their big piston shocks look second to none (have seen a few that would compare but). most coilover setups i have seen either loose their spring seats when lifted or have to have chains to limit travel or the like both are shady. nato
  2. i meant about the price you got slogged, you would expect that much for ferarri wheel cyls but not a dastun/nissan. nah nearly there, got 8 cyls and LSD, fun to drive. no pun intended nato
  3. Its a bloody datsun not a Ferarri!!! :twisted: :twisted: :twisted: :twisted: - :arrow: sorry this was meant to be posted imm after my other post above, laptop went dead. i do the ring around and get prices always, i hate paying too much. i call, sprints, dealer, motor traders and depends on what im after other place nato
  4. $260? farkmedrunkbloodyleeches bloody ripped off, i got 2 @ 24$ each, id be looking elsewhere. just some advice. yea those horseshoe clips just use a screwdriver and small hammer, slide theop one off first then the one below the other way, have small indents to hold them together a lil better. nat0
  5. vic british is now blackdragonauto look it up, they have a lel bit more than vic british did (slightly). but no reply for your original question, sorry nato
  6. Yea may have one of these carbon fibre front brace for you with an asst of brackets aswell as the stock ones for the l-series probly after the 200$ mark, but in adelaide. also have the rear but have a chev installed and when i go efi i cant use the existing bar. but depending on the offer you could have a matching pair, although you have the cage back there. nato
  7. mmmmm, big mac. a really good way do reduce weight in a Z is reaplace the doors with FRP type full shells, as they weigh a fair amount, also ally radiator, & less rubber seals as the seal kits weigh a bit. and yes, loosing 10kg yoursel is like adding 5kw to the engine (more like 3 or so) but where were we?? Ahh yes off to Mc Donalds for the Pounder. aka double double quarter pounder. mmmmm nato (still about 80kg after 2 months in hospital & rehab, only lost 5kg)
  8. id say the early 240's were the quickes, the the laet models. and believe it or not the 280zx the slowest. hp figures for a stock 260 is 160hp at the fly, depending on condition and spec of the motor. although the 280 had 170hp and 240 only had 150. work it out, must be the weight of the earlier cars and i think the original 240 cams had better duration so it revved harder, mabe the higher comp ratio also as the early heads had a small cc'd chamber to that of the later. check the casting No.s of the engine and head to determine the uild you have ie P30 block with e88 head..... very nice looking car, am envious, but how much did it set you back?? nato
  9. for a COMPREHENSIVE discussion about this refer to hybridz.org. its is basically as craig said, geometry of the control asrm in respect to the steering arm changes and as the tyres/wheels 'bump' the steering angle changes fro that wheel or both (if a front end or porpoising)turn outward causing a wandering feeling. other ways are bump steer spacers which dont correct the problem only alleviate it or give stock values of bump steer which is ok to deal with. other mod is to relocate the inner bolt of the front LCA (lower control arm) up about 20-30mm depending on what the car is used for and the amount the car has been lowered. REMEBER bump steer is built into most cars from their design @ small to moderate amounts, lowering affects this amount as seen on the skylines with hicas aswell as the Z's to name a couple. as i said earlier have a look at hybridz as they have covered this topic very well. http://forums.hybridz.org/showthread.php?t=118302&highlight=bump+steer this is one of many have a read nato
  10. that would be brzi's or aka johnnys job. very nice and did very minimal butchering i think from mem it was put a slot int eh rh engine mount post and smake a dent into the crossmember but guys in the US just rotate the body of the rack to avoid the 2nd part. Will be my next project as now i had broken neck and back, power steering would be a nice touch. nato
  11. look its usually not the rack. however id say check all other item like outer tie rod ends, inner tie rod joints (in behind the rubber boots), rack bushes, steering coupler bush, then should you look at the rack itself ill explain shortly. i find the rack bushes, steering coupler & inner tie rods pronounce this problem the most. get a mate to swing yor wheel left & right very harshly while you look at the rack mount bushes and coupler, whilst car is parked and you will see why. Also other bushes should be checked and replaced before you go any furthar as these can also give a wandering feeling. If you find there is still an inherant idle/play area of the wheel, you can adjust the lash also known as 'play' of the rack & pinion i wont go into detail but is done at the rack where steering shaft goes into the main body. you will see a large nut with a large flat head screw type centre to it, loosen off the lock nut and adjust the centre flat head whilst you check the feel of the wheel, your looking for a 'small amount of play not none'. this should really only be done with a fresh packing of grease through the rack which is not easy either. just incase you were interested, not a 'how to guide' but. also the zeds i have noticed develop a 'flat' spot on the rack where when you turn the wheels manualy when front is off the ground you will find a small notchy type spot near to straight ahead, not sure why but have some thought why, may be a wheel aligning thing ie centre!! nato
  12. buy yourself a pair of good headers (block huggers are working for me 283sbc) and get your generic type (cheap) exhaust shop to finish it off, with your supplied mufflers/resi's if you wish or get them to supply. if you do go stainless make sure you find a place that will have all the appropriate SS fitting, flanges etc. i can/have profile cutting ability @ work and id buy SS headers for only $299 pr, just not worth the effort. but still on my list to do. nato
  13. all of the above please :lol: yea you pretty much pushed all my buttons.... nato
  14. Yea id say the pressure plate is on its way out, as they die their stroke becomes longer. also a noisy throwout bearing would indicate the clutch has had a bit of life. just grab yourself a clutch kit stock if yo dont plan on killing it or a heavy duty one if you do plan on giving it a bit. was this your rb30/25? or an l-series?? if an l series depending on what flywheel you have ie a 240mm or a 225mm dia you can grab a 300zx turbo from z31 but worth taking yours off and checking before you hand over your hard earned dollars. nato. ps if you need more tilt from the engine to clear the tunnel(with the box), disconnect the exhaust after the headers lets the engine tilt back for you incase you didnt know.
  15. yea i need to write up a full in depth thing on a word doc and then just post the doc!!!!! would save alot of time and alot of my miss' going 'Hurry up and get ready' & "we have to go in 20 mins" HEHE 20 mins is all il ever need NAto :lol: :lol: :lol: Il be a dead man if she reads the z forums Lol!!!
  16. only early r33 has 29 spline i found out that s2 & s3 have 31 splines(as i suspected), but YES essentially the Differential unit (the pumpkin in the middle is the same, different features lets say, but ARE interchangeable) housings of course change ie long & short nose yes the centres not the whole housing etc is swapable, must be instaled with either the shims from the donor diff or like scoaus said get a diff specialist to install, to mantain the corect lash and alignment of the gears mesh. will need sleeves x 10 of (ie 10 bolt diff) cause the holes in the later centre are a lil big diff place will do them too if you cant get them yourself but you will PAY for them. from memory dimensions were 13.2 OD x 11mm long and ID = 10.4 *(10.2-10.6 my bolts measured odd huh! old richety lathe gave better results!!!) What you are looking for is an Aftermarket diff centre which is a Kaaz, cusco, OS giken, Nismo quaife etc etc, which are MECHANICAL, not Viscous (fluid coupling, less effective, lacks response) For an s13,14,15 or r32,33 300zx z31 & early z32 and NA (but be careful check before you buy as they went to bigger internals shortly after z32 introduced). I think i have nearly done a full write up in another post. If anyone knows the link please feel free to chip in here, "r33 LSD & CV shafts"? cheers nato.
  17. lambs sorry buddy your wrong, i also had an early 260z 2+2 that had an r180. very uncommon but correct halfshafts for the diff also, not a swap in as moust bar had to be changed also when i popped an r200 in ages ago sold the car with the noisy r180 in the back hatch so new owner had both incase they needed it for some unknown reason. also listed in the microfische i was advised on another forum!!!! nato. ****yea prety much a staright swap will need the r200 moustache bar though as the hole centres and dia differ.(or slot and open up the r180 bar and flip it around, but r200 mous bar is easy enough to get for $5)
  18. grae, my mate has a modde bonet for a v8, it was the cherry red one on ebay in the last year or so. has a small scoop towards the rear of the lid, im sure he'd consider selling it. nato
  19. yea they are basically the mothballs i was talking about earlier in this thread. just a lil more potent in it ingredient. probly cheaper from the supermarket, its the methylx(dadidadada) thats pumps the octane (apearntly) nato
  20. jump on thezgarage brzi260 has done a suby rack i think from any imprezza or liberty, seemed an easy install, has pics etc too, easy to follow. nato
  21. im sure i could get that motor going in less than 2 hours!!! im probly going to go have a look at it during the week if i can make it down there. nato
  22. id say NO, push the bolts in threads facing back of the car as the hex on the bolt head locks in against one of its flats against a raised section on the tailshafts. I use a slightly smaller spanner and use it on the nut only, put the trans in neutral and use a large screwdriver in the uni to rotate. works a treat. Also i find that you dont need to do the bolts up ridiculously tight either, just enough to fully compress the spring washer then say another 60 deg's no more..... Ive never had one come undone!!!! nato
  23. My comp ratio was calc'd @ (roughly) 10.58:1 if i remember rightly, was able to run regular if i wanted needed etc. but did run better on premo by far. still ate up the 5.0L commys on 91!!!! You would be able to safely run about 10.8:1 with premo, although you must have a good base ign timing set along with a good advance curve. I would recommend an electronic dizzy a MUST, get a dyno run done to check what curve you have and if req'd get a new or diff module to suit your req's. I have a guy here that uses early holden ign modules and changes them depending on application and gets them to work in the 280zx dizzy, or other off the shelf bosch modules, all do the same thing just have diff curves, wiring configs. i hear they tend to use the camira modules for the L engines 4 or 6 cyl.... nato
  24. well same goes for all motors...... up the compression, increase the rev range and = more power. As fo starting with an l26 or l28 then yes go for the ground or new cam, then up the compression. either flat top pistons or shave the head or both within readon. if you already have say a zx motor then your laughing, STD unleaded head with hardened valve seats etc, bigger valves (both in & out). all depends on what your starting with, i wouldnt recommend spinning a stock bottom end to 8k+ without any balancing & lightening etc, as your asking for trouble. new rod bolts would be a must, high tensile. depending on which head you have and also pitson combination you can achieve almost any compression ratio you like, all comes down to application. I "had" (note the "") an l24 with dished pistons and a head shaved within a shave of its life giveing excellent comp ratio, was able to spin it freely to 8500+ rpm as it had a lightened & balanced bottom end from front pulley to the gearbok output shaft. the cam picked up from about 2900rpm and pulled its hardest @ 5800 through to 7200 and would keep on going till 8k+ not sure how much but sounded like another 1000rpm as gauge stopped the needle @ 8k. i used to have drag races with all the v8 commodore boys here and the 304's upto say the vs clubsport i used to be able to edge in front and stay there, gen3s used to beat me but remember we are talking a 240k L24 worked in a 2+2!!! ill stop rambling now. but yes i did melt a piston #1 having it out with another gen3 (distributor moved/loosened while dragging and added another 8deg's of ign timing and bang, still ran well on 5 believe it or not.) nato
  25. from another race guru.... "Use the l26 crank rods & pistons (overbore req'd if you use the 280zx pistons) you get a 2.6 or 2.8l with the stock engine number, (good for restorers) Grab an early model 240z head (high comp, small cc's in combustion chamber), or gram an N42 from a zx shave 2mm from the botm face, shim the cam towers 2mm to compensate timingchain length. Also get unleaded valves which are larger (bet check cylinder clearance may need to notch bores depending on final size) Get a reground cam, 30/70 or higher. Get new bearings, big ends and main crank. New seals all round, new freeze/welsch plugs, new gaskets and use a good quality high temp, solvent safe sealers. Use a copper spray on head gaskets or similar (permatex!!) run stock 240z carbs with new needles and mainjet (or raise the needles not that easy but). Good headers and exhaust. Should be on track for about 180-200hp from bugger all junk yard stuff. Now lightening and balancing of crank rods and pistons is a must for free revving engines 7k +, also use good quality conrod bolts ARP or TensiStud i think..... a quick vauge run through but very potent runner, good compression, revvy cam, and away you go. nato
