I thought N42 was the better block for big over bores as per this quote I found on Classiczcars
"Carl,
I think you have got this N42 and F54 block internals thing the wrong way round....
The N42 block casting ( the earlier of the two ) had more 'meat' between the bores than the F54 block casting that followed it.
The F54 block casting had 'siamesed' cooling passages between the bores - ie less 'meat' - which actually makes it less stiff than the N42 casting.
When going for maximum bore on an L28 block, the N42 has often been chosen because the extra material in the block casting leaves greater wall thickness, which helps to keep bores round in use.
In contrast, the F54 block has often been chosen because people misunderstand what 'siamesed cooling passages' means. They think that they are "stronger", when in fact they simply have better cooling properties. The F54 has less internal structure than the N42.
And amongst tuners in Japan, the earliest N42 block castings were always reputed to have 'better' metallurgy than the later F54s"
Seems to be a trend with the F54 blocks, mine too was ok on the sides of the cylinders but the wall thickness between 2-3 and 3-4 were too thin for my purpose.
