Riceburner
  1. Not going to separate and wont fit 45's. Try EFI HARDWARE in melb, thats where i got them from.
  2. Trumpets alone are worth $60ea. Am i over pricing them?
  3. Hey Heather, i'm in melb.. mentone. You can send an email
  4. Pauly, the linkages are stock on keihins. I disconnected the old throttle rod from gas peddle and put a small right angle bracket on the end near ball. Then used a vs commonwhore cable all the way to carbs, the grommet on cable is a perfect fit in fire wall.
  5. Pauly, made manifold myself from old su flanges. Then using 40mm aluminium pipe on spare head set up angles and tacked it in place. Pipe cost $40 for 2mtrs, mite get one custom made with all the smooth bends but this will do for now. Neuby, Each runner is 125mm long and go up on a 30deg upward angle to keep fuel bowls horizontal. Extractors are heat wrapped, but will definately make up a heat sheild soon. Zeddophile, wow nice! I was thinking of tbs also. Each carb is individual with the same linkages as yours from the sounds of it, but mine have 2 rods that run through each carb top and bottom, once i removed those they all separated then i just got longer rods.
  6. Havent dyno tuned yet, dont no if i will. Seems to go great as is, heaps of torque and they just want to keep revving, the trouble is finding road to test top end legally! Much better than the sidedrafts i think!
  7. Hey all, im putting my carbs up for sale. They are compete with manifold, linkages, 105mm trumpets, filters and shortened throttle rod from fire wall. Jetted for l28 240z that drives execellent on the road and track. NEW PRICE $950 If nobodys interested they'll go onto ebay soon, wanted to give auscar members first go.
  8. I have a set of 4 polished and painted 280zx rims for sale. Have not been used or cleaned for 2yrs come with centre caps and nuts $200
  9. Hey guys, just finished my latest mod. I've fitted six 42mm honda blackbird carbs to my l28, they are Keihins and are very well put together with strong linkages, the throttle shafts are even knife edged straight from the factory!!! Had to buy two sets as they are originally four coupled together, so with a bit of time and patience i managed to separate them and change the linkages to allow all six to bolt together. Had to make my own inlet manifold and re work fuel lines but after initial running they are great!
  10. Dimitri, should sound great with the ITB setup. I have about 2inch of clearance under tank, pipes are wrapped. I checked for heat transfer with laser thermometer and theres nothing, that was my only concern. Sushi, thanks think i'll go white contact and try to hide it with tow hook. Then when i get doors repaired get it patched up and painted.
  11. Hey Rev, if you're interested i may have my triple 40 dellortos off the car and if all goes to plan ready for sale in few weeks....... They would include manifold, 105mm trumpets, linkages and filters. Bolt em on and away you go! Btw there jetted for my l28.
  12. Hey Dimitri, nah havent raced for a while. Making a manifold for my new carbs, so funds have been diverted :'( Not sure of the brand of muffler, its 30-40cm long and offset, single 2.5inch inlet then a cone with two 2inch outlets. They stuck it up uner the prop shaft, really neat fit. Hope that helps? Btw they're on warrigal rd just near repco. Mite put some white contact over the hole
  13. Thanks. Yeah had the twin stacks but came across some stainless megaphone tips a while ago, i've been itching to get em on! Its no louder than the old system, just deeper. Do you think i should cover up original cutout?
  14. Riceburner
    Exhaust help
    Hi all, just got my new exhaust system done, megphones! Anyhoo was wondering if i should cover original exhaust cut out on rear panel? plz excuse pics
  15. Wow really nice, still remember this from the christmas bbq! When does the magazine come out? I definately want to see it.
  16. Are the screw on perspex headlight surrounds still for sale? how much?
  17. Thanks Zedevan, when you say loks are different what sort of mods are required to get them to fit? other than that i take there a straight swap..... by the way im in melb, mentone.
  18. Thanks lurch, was going to say 'rust free' thought it was a tad ambitious tho Gav, Mine are in very poor condition, frames are rusting through.
  19. Hi all, just after 2 spare doors in good condition?
