Showing content with the highest reputation on 07/01/2022 in all areas
  1. I have heard before "opinions are like arseholes, everyone has one" - and especially for the sake of values.. it's easier to simply ignore everyone unless you know for a fact that they are a buyer and going to contribute to the hard stats that one craves when assessing values. It's equally silly to isolate one sale of a car that you (perhaps) haven't seen in person and don't know the true condition of. Was it solid? Or quite the opposite? Did the owner understand market value or did they under-sell it? Data should be looked at collectively, otherwise it can tell you anything you want it to.
    4 points
  2. C.A.R.
    Micheal's Bent Bus
    RH footwell: Then the rails were removed: Also the RS30 LH sill (which we'll be modifying), floor rails and bonnet hinge gussets arrived from @kfvintagejdm:
    4 points
  3. Sorry for the lack of updates, been away with work and generally busy. some nice little updates/new parts: had a really strong fuel smell in the garage. Turns out the fuel sender unit had finally given way and was allowing for a slight fuel weep through the terminals, so bought a new genuine one from NZ Datsun parts. Plus a locking ring and a new seal. Also, I noticed that there was a fair smell coming from the fuel door area. The fuel cap looked alright but I had no idea it had a pressure release valve on the underside. The rubber seal on this spring loaded valve had rotted (see photos). So ordered a new genuine fuel cap…you can see the difference. Mounted the mic for my new retrosound stereo. It’s not hidden but I think it works well and gives clear comms and eliminates the fuse box cover rattle/jiggle we all experience on rough roads. Finally, had issues with the park brake light actuation switch. So bought a new genuine one from the states. Fitted and works a treat!
    2 points
  4. The area around fuel door was rusted through, so I fabricated a new section to replace it: Yuck...:
    2 points
  5. C.A.R.
    Micheal's Bent Bus
    Repeat on the LH side with some shrinking required for good measure:
    2 points
  6. Haha funny you say that mate, I spoke to him and he told me about his Datsuns and after about 10 mins I had to say I got to go. Lovely guy though! Long story short Nissan are no longer making fuel sender units for the 240z. If anyone hasn’t replaced theirs I would strongly recommend buying one as they are a part that constantly touches fuel and after a while is prone to weep. I couldn’t find any in Australia and had to go to NZ Datsun parts. when this rain stops and I’m not so busy we might have to go for a drive mate.
    1 point
  7. I suspect the price reflected the "rust modifications" that you can never see in online photos.
    1 point
  8. And a non sealed garage, so in winter it's too cold to be out there working on them.
    1 point
  9. You really need to see these cars in person to evaluate the body on them. Someone is always selling a sandblasted shell in epoxy after discovering the car was more far gone than anticipated. IMHO it's better the devil you know. Once you've started, if you keep looking for a better starting point. You end up finding a car without your current cars issues, just another set of issues your current car doesn't have. Given they are 50 years of age now, it's a given they need everything.
    1 point
  10. C.A.R.
    Micheal's Bent Bus
    Onto the LH floor - I worked out the cost for new KFVintageJDM floor pans + freight + installation, and the figures said it was going to be cheaper to fabricate & install patch repair panels: I'm not taking credit for this - it's Graeme's handywork.
    1 point
  11. RE: D Cap prices, a few completed listings. Single early cap (less fingers/tabs on back) for $536 USD https://www.ebay.com/itm/225039901444 Another single early cap for $500 USD. https://www.ebay.com/itm/295026991311 And this set of D caps (NOS) was listed at $6,000 USD + no idea if they sold. (eBay says so) https://www.ebay.com/itm/325140039226
    1 point
  12. C.A.R.
    Micheal's Bent Bus
    The RH rear lower quarter was a mess, and the inner panel was rusted though as well. No choice but to replace both, so Graeme (my employee) tackled this while I repaired the panels...
    1 point
