benny Posted August 19, 2013 Posted August 19, 2013 Well... I hadn't thought of that. This may have to be a project for another budget. what alt did you end up getting?? may already be internally regd Quote
Administrators gav240z Posted August 19, 2013 Administrators Posted August 19, 2013 So are you employed again mate? Is that a totally new loom you constructed or did you just patch up and restore the original loom? I would love to build a brand new wiring loom for the 240z so you can run modern fuse box and headlights / alternator etc.. But I'm a total wiring dunce at this stage and don't know where to start learning really, other than buying a decent multi-meter and pulling my hair out. Quote
Stivva Posted August 19, 2013 Author Posted August 19, 2013 Still on the original alternator. Parts of the loom are brand new, parts are refabbed, and the plugs to the cabin are original. Still with out a job, but looking actively. I spent very little on the loom, some cash on sand paper, had paint from the car left over, and my painter is supplying the rest. He is a good mate, so hopefully it wont cost me much lol. Quote
Riceburner Posted August 19, 2013 Posted August 19, 2013 Isn't there a 'plug in' mod available to delete the voltage reg without cutting wiring in favour of an internally regulated? I'm sure I've seen it for the 240 Quote
benny Posted August 19, 2013 Posted August 19, 2013 Isn't there a 'plug in' mod available to delete the voltage reg without cutting wiring in favour of an internally regulated? I'm sure I've seen it for the 240 correct... you just make up a plug with a resistor wired in or you can mod the loom to run the resistor inline Quote
d3c0y Posted August 19, 2013 Posted August 19, 2013 You should be able to pick up a second hand alternator for what $30 - $40? By the time you have had your engine bay painted and what not you will probably have another job and just just buy the alternator! Just mod it while it's apart now. Quote
Stivva Posted September 16, 2013 Author Posted September 16, 2013 Finally had my engine bay painted. I have put a bit more of it back together now and started polishing up my engine cover, but I have a bit more to do. But for now the old girl is in the shop getting a new sump gasket and diff gasket, need to cut out those pesky leaks on my driveway. Video of the driveway paint job. http://www.youtube.com/watch?v=bHmwtbIi3Ug&feature=c4-overview&list=UUoTdw6UPXdky_mW6HFbFJEQ Quote
Stivva Posted September 22, 2013 Author Posted September 22, 2013 Lol, subtlety is a trait of a true gentleman. Video to match the above photo. Quote
Stivva Posted October 13, 2013 Author Posted October 13, 2013 Yes, it does leave the driveway occasionally. Quote
Stivva Posted October 28, 2013 Author Posted October 28, 2013 I have been busy of late. I moved the battery back into its rightful place in the engine bay. Dug up all the original wires in the centre of the dash and now have a working cigarette lighter and radio. Yep, my original hitachi radio works, but I have bypassed it and have a pioneer radio in my glove box. So it lights up at night when the headlights are on and the green reception light comes on when I have a signal, but my noise comes from the pioneer unit. I redid my roof lining, and I promise it will never ever sag. I cut a piece of 1ply to shape and builders glued the vinyl to it. So now the timber base can be removed but the vinyl trim wont sag from it. Looks better than new! I also started building the speaker spaces. 7x10s in the tool boxes, tweeters in the roof lining above the sun visors and 6 inchs in the factory locals. The only visible speakers are the 7x10s and even they are not intrusive. Also got my new diamond patterned vinyl for the transmission tunnel and that has really finished of the look of the interior bar one thing. Time to replace the carpet for OEM black. one bad thing though. I never realised how thin the Jtin really was. So easy to pin dent the roof... now I need to go to the panel shop for a roof repair. Pictures to come. Quote
Riceburner Posted November 4, 2013 Posted November 4, 2013 Looking good How did the diamond pattern trans tunnel end up, also the head lining? Quote
Stivva Posted November 4, 2013 Author Posted November 4, 2013 I just need the black carpet up front now, and also time for a new steering wheel. Quote
Brabham Posted November 5, 2013 Posted November 5, 2013 Now that's how a modern deck install should be done on a zed! Looks very neat in the glovebox and the console looks factory with original radio. Very neat work Quote
Moderators PB260Z Posted November 5, 2013 Moderators Posted November 5, 2013 Now that's how a modern deck install should be done on a zed! Looks very neat in the glovebox and the console looks factory with original radio. Very neat work + 1 Quote
Riceburner Posted November 5, 2013 Posted November 5, 2013 Nice, Like the diamond pattern much more now it's in the car. Quote
Stivva Posted November 5, 2013 Author Posted November 5, 2013 Is that a speaker in the roof lining? Correct, tweeters for the splits are flush mounted in the roof. I just need the factory speaker brackets to mount the other half of that combo. So, the only real visible speakers I have are the 7x10s and once i have grills for those, they will be less visible. Quote
Stivva Posted November 5, 2013 Author Posted November 5, 2013 Now that's how a modern deck install should be done on a zed! Looks very neat in the glovebox and the console looks factory with original radio. Very neat work Best part is, the original radio is wired up and works, (sans speakers), but if tuned in the tune in light will come on, and the lights will come on with the headlights. And then, the Pioneer draws all its wiring loom from the correct wires in the factory radio loom. Quote
Stivva Posted November 6, 2013 Author Posted November 6, 2013 Nice, Like the diamond pattern much more now it's in the car. It is softer, cleaner and a much better fit, there is absolutely no gap between in and the plastics, I trimmed the middle section inside of the car for a super flush fit. Quote
Stivva Posted November 22, 2013 Author Posted November 22, 2013 Anybody got a set of stock springs locally I can grab? i need to raise this thing to stop scrubbing... Quote
MATTY Posted November 22, 2013 Posted November 22, 2013 Im not gonna lie every time see your car it excites me....haha i wish mine was half as good as yours And those wheels are they Meister S1's or S1R's!? the spoke looks pretty aggressively curved, but that could just be the angle in the pic or my consumption of ice cold beverages lol Quote
