Sirpent Posted January 5, 2013 Posted January 5, 2013 Have you been drinking Sherry again? He forgot to wear his respirator again and obviously was checking the Porsche lamps found a HID ballast controller had failed and spent to long inhaling down in the bunker again Quote
C.A.R. Posted January 5, 2013 Author Posted January 5, 2013 Nice work lurch. Will that rear jacking point hold? Similarly if the front of the sill has had a section cut out will it hold? My fronts have been cut and my rears are rusty! Where can i support my zed so it doesn't fall apart? (Front and rear suspension need to come off) Impressive work. Fortunately no sign of the dreaded expander-foam! After I have repaired it Alex, of course it will hold. Why do you think it wont? Just support the Zed on the chassis rails - the sills aren't the only place to jack up a Zed... Quote
Brabham Posted January 6, 2013 Posted January 6, 2013 Cheers Lurch, was only worried that it might not hold while the section has been cut out, obviously once repaired it will hold it fine. I was just hesitant to support mine under a sill with a section that had been cut. Chassis rails sounds like a good idea, think I will support it there. Cheers. Quote
C.A.R. Posted January 6, 2013 Author Posted January 6, 2013 More completed today - slow going though... :-\ Tacked together & sitting in place. Underside. The finished article (media blasted). Quote
C.A.R. Posted January 14, 2013 Author Posted January 14, 2013 Chassis rails have arrived! Huge thanks to Nat0_Chev for pressing these up for us Quote
lightmaster240z Posted January 14, 2013 Posted January 14, 2013 It like Xmas all over again and again Quote
C.A.R. Posted January 30, 2013 Author Posted January 30, 2013 Progress! Inner guard/battery tray area is also finished - but I forgot to take a photo of it... Quote
Moderators Zedman240® Posted January 30, 2013 Moderators Posted January 30, 2013 Just need some shirts / stickers! woohoo Quote
Administrators gav240z Posted January 30, 2013 Administrators Posted January 30, 2013 Wow Lurch, you're getting really good at rust repair. Attention to detail is amazing mate. Quote
Agno Posted January 31, 2013 Posted January 31, 2013 Once I save my money I know where I'm bringing my car! Quote
Retro Z Posted January 31, 2013 Posted January 31, 2013 Once I save my money I know where I'm bringing my car! +1 Quote
C.A.R. Posted January 31, 2013 Author Posted January 31, 2013 Inner guard/battery tray area welded up (Wheel well view). Mocking up the chassis rail for correct fitment & alignment. Quote
Moderators Zedman240® Posted January 31, 2013 Moderators Posted January 31, 2013 Friggin awesome... Quote
luvemfast Posted January 31, 2013 Posted January 31, 2013 Looks like Brucey might be in for a trophy at the next Xmas BBQ with all this work! great stuff Quote
C.A.R. Posted February 13, 2013 Author Posted February 13, 2013 Progress! Chassis rail is welded in place & I have finished the seam sealing. I just have the Battery tray left to fit & a small rust repair on the guard - will get that sorted on Saturday. (Apologies about the crappy photo's) Quote
Moderators PB260Z Posted February 13, 2013 Moderators Posted February 13, 2013 Progress! Chassis rail is welded in place & I have finished the seam sealing. I just have the Battery tray left to fit & a small rust repair on the guard - will get that sorted on Saturday. That and much more will be sorted on Saturday Quote
lightmaster240z Posted September 4, 2013 Posted September 4, 2013 Time for a little update New shock Done floor fixed done Head light fixed done indicators not working :(fix two hour and 20c peace of wire ) done. short in reverse light done steering wheel done new seats done. test drive soon . Quote
benny Posted September 4, 2013 Posted September 4, 2013 Time for a little update New shock Done floor fixed done Head light fixed done indicators not working :(fix two hour and 20c peace of wire ) done. short in reverse light done steering wheel done new seats done. test drive soon . you wont know yourself brucey!! Quote
Riceburner Posted September 6, 2013 Posted September 6, 2013 Nice! Were you able to fit the rails with the drive line and running gear in place? Quote
lightmaster240z Posted September 6, 2013 Posted September 6, 2013 Yes, Lurch did all the work in Stu with no help from me. I'm not sure how much swearing was involved but the result are out standing. as well as the above work he also replaced the front brake rotor's, lining and back cylinder and lining at the same time. This was a Big job If I had any one else to do It would have probable sold the car as a non going project it was that bad. Bruce Quote
George Posted September 7, 2013 Posted September 7, 2013 Yes, Lurch did all the work in Stu with no help from me. I'm sure they couldn't have done it without your supervision. ;-) Quote
MaygZ Posted September 7, 2013 Posted September 7, 2013 I'm sure they couldn't have done it without your supervision. ;-) You mean beers and bad jokes? Quote
