What? No more Jay Leno? you've covered his face with that steel sheet now..
How bad was the original metal? Have a pic?
Good work Lurch. Looks like a productive day.
Bruce you better get this car ready for the Bright trip. No more excuses. Remember we have these cars to enjoy the ride.  :D
Looking good Lurch,
But then again what would I know, my 2013 mission is learn to weld.
Have fun
PB
Nice work Locky,
So is the battery tray going back in ? is there anything left of it?
If not, I have a spare if youre loking for one Bruce
I think I am right for the battery tray but I need to check with the surgeon about the condition of the replacement tray. This will be his call.
But thank you you any way.
Bruce
Jay Leno ;)
A spare you say?
Yup.
If Bruce dosent want it as I offered it to him first, you have dibbs Scott.
I removed mine and its in mint condition, my battery's going in the rear of the car.
John
Dibbs on the battery tray if Scoota doesnt take it.
Yup.
John
You mean as in Scott no friends?  :( I will buy your tray for Oscar. His is in 2 bits.
Engine bay chassis rail repaired & welded up.
The power went out just as I was going to clean the welds up, so I've packed up for the day (going to be too hot anyway).
I have ordered from Nat0 a new pair of underfloor chassis rails, so they will go on in a few weeks.
I'm now waiting for the paint shop to reopen so I can buy some 'KBS RustSeal' urethane paint, so I can paint the insides of all the cavities.
Stay tuned ;)
Nice work Lurchos.
Dogleg looks pretty good compared to most!
Mark - Inner sill is in good nick. Just a bit of surface rust :D
No Dim - it's like a piece of FG matting that was jammed into the hole so that the bog had something to stick to... ::)
And this is what I was doing for the last couple of hours of today:
I've remade the edge of the inner guard/battery tray (by cold shrinking the edge to create the curve) where it is spot welded to the firewall,
as the orig. lip was cut off when it was removed from the donor vehicle...
...This will now get 'tweaked' further, & then welded to the replacement panel before being fitted to the car.
Thanks must also go to Matt "Bigfella" as this job would be so much harder without him donating that inner section!
Nice work lurch. Will that rear jacking point hold? ??? Similarly if the front of the sill has had a section cut out will it hold? My fronts have been cut and my rears are rusty! Where can i support my zed so it doesn't fall apart? (Front and rear suspension need to come off)
Impressive work. Fortunately no sign of the dreaded expander-foam! ;D
Now that am Idea that I haven't try yet to find inthis car it got one of every thing else
Have you been drinking Sherry again? ???
