That definitely looks like the right colour. Does VicRoads change the colour on registration if a car gets resprayed? Because the rego on mine says Grey.
Posted (edited)
If you ask them to they will change the records, but hardly anyone ever bothers.
The colour isn't even on the rego papers so unless you ask, or the cops talk to you, it never comes up.
Edited by PB260Z
Oh I only meant that the rego check on the VicRoads website says it's Grey, but that doesn't mean much if the entry can be changed on respray or what have you.
Found this ........http://www.gumtree.com.au/s-ad/jericho/cars-vans-utes/1973-datsun-240z-5-speed-manual-coupe/1099323664
This original 1973 Datsun 240Z 5-speed manual Coupe is a rare restoration opportunity. Last run in 2015, this car has been a fabulous grand tourer for over 40 years and holds high sentimental value to the owner. Price is negotiable $15,000.
Purchased: 2nd hand, 1975 – only one owner since then.
Make: Datsun
Model: 240Z
Year: 1973
VIN: HS30101368
Engine number: L24160281
Body Style: 2-door coupe
Layout: Front engine
Drive Type: Rear wheel drive
Odometer: Odometer reads 88638miles, but estimated 300-400k miles total travelled. Used as a family car and grand tourer until 1990. Primarily garaged since then, last registered in 2009.
Engine: 2.4 L L24 (Inline 6 cylinder) petrol. Last major service >10 years ago. Gaskets replaced in 1985. Still fully operational with original parts. Rubber hoses will require replacement and engine will require a workover to be roadworthy.
Transmission type: 5-speed manual. 5th gear jumps out into neutral under power.
Clutch: Working – master cylinder was replaced 2015, slave cylinder is original.
Exhaust: Manifold and pipes replaced in 1985.
Body:
Panels have undergone minor damage previously and were re-beaten and painted in 1980s.
Rust damage holes under drivers side flooring.
Wing mirrors not original – new wing mirror panel has been riveted to both panels.
Minor rust under driver’s side door.
Small hole (<2cm diameter) in top of drivers side door.
2 small holes (<2cm diameter) in bonnet above front wheels.
Bonnet latch missing.
Front of bonnet damaged and indented slightly, rusted where damaged.
Brakes: Not working, appears to be a fault in the master cylinder.
Suspension: Rear strut cartridges replaced in 1985. Rear springs replaced in 1985.
Wheels: Front left tire has leak.
Alternator: replaced in 1985, no issues.
Lights/Electrics: All lights work. Front, drivers-side light cover broken. All other light covers intact.
Windows/Windscreen: Large crack (10-15cm) in windscreen. Door windows: no damage, open and close without issue. Boot window: no damage.
Paintwork: Original paintwork was dark rusty orange, painted over in white in 1980. Paintwork has minor damage and is flaking off the body all over, will require respraying.
Interior
Fuel Gauge: working.
Temperature Gauge: working
Battery Gauge: working
Oil pressure Gauge: not working
Rev counter: working
Speedometer: working
Odometer: working
Wipers: not working.
Lights: working.
Dashboard – no damage, original (car has been kept garaged so has minimum sun damage.
Steering wheel, gearstick, pedals all original.
Upholstery: Carpets and upholstery require replacement. Seats are original – drivers seat.
Air conditioning: No
Radio: Working.
Power steering: No
Owners: 2 previous, purchased in 1975
Garage: stored under cover in dry climate (central queensland)
Extra Equipment:
Spare tire
Original Datsun 240Z jack
Asking Price: $15,000 negotiable.
just found this on gumtree too des...........if you culd get it for 11 it would be a great deal! dry country car.........should mean the rust wont be too crazy
just found this on gumtree too des...........if you could get it for 11 it would be a great deal! dry country car.........should mean the rust wont be too crazy
Check out that radio, one for Gav.
Yep love it, those radio's are expensive now as I'm sure you've seen on eBay US. Just more confirmation that all 73's had the early hitachi radio, we never got the FM style radio in AU delivered 240z's it seems.
I installed my JDM radio the other day. I didn't wire it up, but just wanted to fill the void of empty radio with the OEM look. (nb: no antenna switch).
There was a good reason for that, we only had AM radio stations back then.
Yes in another thread I believe I discovered that 1974 was the first year of FM and hence the 260z got the FM radio.
Posted (edited)
From memory ABC FM kicked off in '74 but FM didn't become mainstream until about 1980. I am old enough to remember 2MMM starting in Sydney. My '82 KE70 had an AM/FM push button radio and it seemed so hi tech at the time.
Edited by PB260Z
  • 2 weeks later...
http://www.carsales.com.au/private/details/Datsun-260Z-1976/SSE-AD-3713797/?Cr=2
260z coupe asking $17k
cp5087871983889559203.jpg?height=700&aspcp4727581941134879486.jpg?height=700&aspcp5648178556725708153.jpg?height=700&aspcp5377398874402785606.jpg?height=700&aspcp5417507462818912577.jpg?height=700&aspcp5753760184036111273.jpg?height=700&aspcp5505048933554667951.jpg?height=700&asp
Datsun 260Z 1976 2 seater with Chev 350 reconditioned engine and Chev Camaro 5 speed manual gearbox. Car is in is in original condition inside and out. Body is rust free and straight. Total weight increase is only about 70kG and because engine is set back against the firewall the centre of gravity of the car is now further back and lower than the standard Datsun. This results in a more stable and better handling car. The standard Datsun solid front discs have been replaced with vented discs (see photo), with late model vacuum booster which gives excellent braking. The engine was rebuilt several years ago (see photos) but the car has been in storage since 2003. The engine has been bored .030” but is otherwise standard with 76cc heads and 4 bolt main bearings. It has had only a few hours running since the rebuild and is not yet run in. The horsepower and torque figures speak for themselves to indicate the performance of the car, when compared to the standard Datsun specs. Carburettor is Quadrajet mounted on Edelbrock manifold. Extractors are custom built to suit. I need the space in my garage and it is time to find a new home for the car. Price is offered as is, which is currently unregistered, but it has an engineers certificate and could be purchased at additional cost with 12 months registration and roadworthy, as an option.
Posted (edited)
Could it be registered in NSW ?   With Engineers Cert.
Can the Red 260z with the RB30 in Vic be registered in NSW ?  No Engineers Cert.
Edited by ScottyD
Posted (edited)
260Z 2+2 in Tasmania
http://www.gumtree.com.au/s-ad/turners-beach/cars-vans-utes/datsun-260z/1100001623?ea=5938455&utm_source=trigger&utm_medium=email&utm_campaign=saved_search
Negotiable on price
Kilometres: 97000
Transmission: Automatic
Year: 1975
This is my rare 1975 datsun 260z project.
The vehicle has been in storage for around 7 years, it was last registed in 2008.
the vehicle has
-new dizzy,points and condenser. -cleaned and rebuilt carbs. -Genie extractors -bigger cam -underbody has been sprayed with stone chip. -97000km!! -previous owner receipts and 2008 registration papers. -240z twin su carbs, which were the better carbs.
-no rust in floors, frame or underbody. -timing and engine tuned and sounds great!
vehicle needs body work (paint) and a little work inside.
I have some spare and original parts as well.
I recently bought rims for the vehicle which i paid a lot for these can be included or discluded (sic) when making an offer. 17x7.5 +5
Edited by GongZ
Make: Datsun
Model: 240Z
Year: 1973
VIN: HS30101368
Body:
Interior
Odometer: working
Lights: working.
Radio: Working.
Power steering: No
Extra Equipment:
Spare tire
The madness continues.....  I bought this car  ::)
The plan is to have it delivered here to Canberra where I will assess it and make a comprehensive parts list.  I aim to order the parts from the USA and have them delivered here.  The car and parts will go into a container to my guys in South Africa for a nut and bolt back to original orange colour, to be returned to me in Canberra, for resale.  I'll start a separate build thread on it when it arrives.
It looks like a relatively honest car, so should make a great restoration candidate. My first 73 240z was also 918 orange I just found the engine number the other day L24 175807, so it looks like my 73 was later than this car. If you find out what the Australian compliance date was, please let me know?
Edit looking at the S30z register details.
http://www.wazregister.com/index.php?title=View_ANZIS30_Register
Warren's old 240z. (Sadly Warren is now deceased).
HS30-102195 had L24-165894
(Jake's car, is that you D3C0y?)
HS30-102599 had L24-178126
So it's likely my old 73 240z was complied in June/July 1973.
Re the V8 car - if the engineering cert is issued by RTA (or whatever they call themselves this week) approved engineer then assuming the rest of the car is roadworthy NSW rego shouldn't be a worry.
Re the RB30 in Vic with no engineering cert - that car would need to presented to a NSW approved engineer for certification. I would advise talking to an engineer before getting to serious about an interstate modified car.
PB
Compliance was 5/73.  VIN 101368.  Engine # 160281
PB
Thanks PB.
I will have to wait for a Retromod, NSW registered 2 Seater to come along.
It would almost be a shame to remove it from it's long slumber in that grass.
Posted (edited)
This one is still for sale
gav240z, on 09 Jan 2016 - 5:51 PM, said:
If it's as good as it looks body wise then it would be a good buy at $15k, would not cost much to put a L back in it if that's really necessary. Personally I'd keep it as is.
Edited by 260DET
