greggy2710 Posted December 14, 2017 Posted December 14, 2017 I’m rebuilding an L28 with triple 45 Webber’s and was after some advice on headers. It will go into my 260Z which will be a nice road car when it’s finished. Just wondering what people have used for headers? Thanks Quote
AndBir Posted December 14, 2017 Posted December 14, 2017 Whilst they do not show up on his web site I understand Stewart Wilkins still supplies them: https://www.swmotorsport.com.au/ Maybe give him a call to ask about availability. Quote
C.A.R. Posted December 14, 2017 Posted December 14, 2017 Whilst they do not show up on his web site I understand Stewart Wilkins still supplies them: https://www.swmotorsport.com.au/ Maybe give him a call to ask about availability. ^What he said^ Quote
600Z Posted December 16, 2017 Posted December 16, 2017 I’m sure there not SW extractors but I don’t mind the look of them for the price. HomeBuiltByJeff 1 Quote
HomeBuiltByJeff Posted December 16, 2017 Posted December 16, 2017 I’m sure there not SW extractors but I don’t mind the look of them for the price. They look pretty good for the price. 600Z 1 Quote
Retro Z Posted December 16, 2017 Posted December 16, 2017 I think those are similar to mine. I got mine from Motorsport auto 600Z 1 Quote
HomeBuiltByJeff Posted December 16, 2017 Posted December 16, 2017 I think those are similar to mine. I got mine from Motorsport auto Did you buy it with the ceramic coating, or did you get it done after? Quote
CBR Jeff Posted December 16, 2017 Posted December 16, 2017 I don’t think you would be disappointed if you went fo the SW option. They look powerful even when not attached. Jeff OdinZ, gav240z and theremm 3 Quote
Retro Z Posted December 17, 2017 Posted December 17, 2017 Did you buy it with the ceramic coating, or did you get it done after? I bought it already Ceramic coated. gav240z and HomeBuiltByJeff 2 Quote
600Z Posted December 17, 2017 Posted December 17, 2017 Hi Jeff, how much are they from SW? If you can remember Quote
HomeBuiltByJeff Posted December 17, 2017 Posted December 17, 2017 http://www.thezstore.com/page/TZS/PROD/classic19d/15-6013CH Although I am not sure what they would charge for postage. Quote
CBR Jeff Posted December 17, 2017 Posted December 17, 2017 Hi Jeff, how much are they from SW? If you can remember I honestly cannot remember exactly but Lurch may? Mainly because Les from LCR supplied them with the engine. I think they were about $1200 after they were coated? They are the small bore set 1.5" not the larger set. My motor is 3060 cc and made 305 HP so you wont need big bore ones for a. The design and flow of extractors makes a big difference to engine performance. While they may seem expensive in comparison to some other options its cheap HP. Jeff Quote
KatoKid Posted December 17, 2017 Posted December 17, 2017 Zorst matters....one of the most neglected and easiest ways to pick up HP...but it can be a black art. Quote
600Z Posted December 17, 2017 Posted December 17, 2017 They certainly look good Jeff and yes cheap HP. Be interesting to see or know what difference there would be in hp between different ones. Quote
OdinZ Posted December 18, 2017 Posted December 18, 2017 I spotted these yesterday, as I am also looking at options for my L26, eventually to have triple 40 dellortos. These dont look have half as good as the ones already posted, but they are in NSW. https://www.ebay.com.au/itm/Nissan-Datsun-240Z-260Z-6cyl-Petrol-Extractors-Headers/262781201454?hash=item3d2efaec2e:g:GYMAAOSwUKxYYxDB Quote
C.A.R. Posted December 18, 2017 Posted December 18, 2017 OK, to clear things up a bit, the headders Ned posted above are the generic Pacemaker / HM Headders style that have been around for decades. These are fine on mildly tuned L6 engines & will clear all manifolds - triples & twin Hitachi's. The ones Jeff posted that are on his engine are the SW Motorsport extractors. They are high performance headders that work best with built higher performance L6's. They are priced accordingly too as they are still hand made - around the $1500 mark (coated). Be advised - they do not fit with the twin Hitachi's. They also foul on certain triple carb manifolds, as the primary shape is longer as it exits the manifold face. GongZ, OdinZ and gav240z 3 Quote
GongZ Posted December 18, 2017 Posted December 18, 2017 http://www.thezstore.com/page/TZS/PROD/classic19d/15-6013CH Although I am not sure what they would charge for postage. Hi Jeff, The header in the link you posted is their 15-6013CH 'MOTORSPORT TBC Coated 6-1 Header' (for round port heads - US$319.95). I just received a shipping quote from the Z store for the 15-6001CH - 'MSA 3-2 TBC Coated Header' (for square port heads - US$299.95) of US$165.54 (via USPS International). So the total cost for the 15-6001CH would be about AU$610 and the 15-6013CH would be about AU$635. Quote
Agno Posted December 20, 2017 Posted December 20, 2017 I've got a set of these to suit square ports (N42 head). The flange thickness on these headers is quite thin, meaning I had to weld up washers to get everything to line up square with my Redline manifold. I'm not sure of the flange thicknesses of the other types of header but at this price point it's probably on the thin side. GongZ 1 Quote
AndBir Posted December 20, 2017 Posted December 20, 2017 .../.... I'm not sure of the flange thicknesses of the other types of header but at this price point it's probably on the thin side. Seems to be a common issue as the SW Motorsport extractors flange is thinner than the flange on the Kameari (Harada) inlet manifold. Quote
GongZ Posted December 20, 2017 Posted December 20, 2017 ...The flange thickness on these headers is quite thin, meaning I had to weld up washers to get everything to line up square with my Redline manifold. I'm not sure of the flange thicknesses of the other types of header but at this price point it's probably on the thin side. Good point Agno. These two topics are also worth looking at in relation to headers; http://www.viczcar.com/forum/topic/5610-240z-exhaust-hurricane-headers/ http://www.viczcar.com/forum/topic/13978-stainless-steel-exhaust-manifolds-exhaust-and-jdm-twin-pipe-rear-silencer/?do=findComment&comment=165973 Quote
MATTY Posted December 22, 2017 Posted December 22, 2017 Hi Jeff, The header in the link you posted is their 15-6013CH 'MOTORSPORT TBC Coated 6-1 Header' (for round port heads - US$319.95). I just received a shipping quote from the Z store for the 15-6001CH - 'MSA 3-2 TBC Coated Header' (for square port heads - US$299.95) of US$165.54 (via USPS International). So the total cost for the 15-6001CH would be about AU$610 and the 15-6013CH would be about AU$635. that sounds about right, i got a few other things from zed store as well as these at the time it was around $800 shipped to my door. they are pretty good quality but pays to have the exhaust flange check to see if its straight(square). i got mine skimmed flat and never had a drama with running them and they cleared my triple dellortos and webers also. Quote
AndBir Posted January 1, 2019 Posted January 1, 2019 On 12/22/2017 at 4:59 PM, MATTY said: 15-6001CH - 'MSA 3-2 TBC Coated Header' Looks to be an "equal length" type header which is best for exhaust scavenging. On 12/22/2017 at 4:59 PM, MATTY said: 15-6001CH - 'MSA 3-2 TBC Coated Header Does not appear to be an "equal length" type header. Equal length header exhaust scavenging is described here : https://www.youtube.com/watch?v=RWTARjxiqlo Quote
