2,236 -
137
Everything posted by KatoKid
You can retain the valve (its a pressure differential, not proportioning valve) and still use the original brake warning light wiring. Or you can ditch the valve and just use the float level switch in the master cylinder reservoir. I wanted to use an adjustable proportion valve in my set up and the engineer was fine with ditching the old valve and using the MC float switch in its place. The float switch just needs one earth and the other goes straight to the original single wire for the warning light.
KatoKid replied to CroS13's topic in Members Project(s) Journal
Love it! Well done. -
I bought my Landcruiser OEM headlights a couple of weeks ago so thought I shouldn't put off the inevitable and install relays. My headlight switch shows signs of overheating but still works fine so figure this is a must do. I had already run a big fat power wire direct from the battery to the back side of the RH radiator support panel (through an 80 amp fusible link) to provide power for my fans and controller so it was simply a matter of taping into this power source and wiring just like any other headlight relay....right......no! Didn't take long to realize that Mr. Datsun had decided to wire his headlights different to most others. I've learnt that you are better off to consult Mr. Google sooner than later and avoid bashing ones head against the proverbial wall and one of the first hits was this thread http://www.viczcar.com/forum/topic/8756-headlight-wires-mystery-relay-upgrade/. Good old Viczcar comes to the rescue again! Anyway, followed Benny's diagram and had no issues at all. Lights are much brighter than the pale yellow they put out before. Tick another task off the list.
S30Z Vehicle Identification Tags, Plates, Locations And Tips
KatoKid replied to gav240z's topic in General Maintenance
Always the sleuth Gav! Good stuff as always. -
Yep, but email Freddy and he will do one for you. He stopped them for a while to make some alterations. I haven't tried fitting mine as yet but it will require making some brackets which is no big deal as they are quite different to the standard 240Z console, more of a 240/260 mash up.
Yep, deliberated over consoles for a while as repaired or standard reproductions just weren't doing it for me. Very happy with the decision.
I think you're referring to the big assist spring. My problem is with the little spring that is wound around the drum of the winder that acts as a friction brake to help control the assist spring
Wheel studs are all done and hubs reassembled, perfect fit and length for what I want. A couple of weeks ago I came out to the shed and there was a puddle of fluid under the front of the car. Investigation revealed it was brake fluid leaking from a port between the front and rear outlets on the side of the brake MC. Google searches confirmed this leak is common for this type of MC when they have an internal leak. Checking confirmed that a new MC from Nissan was >$700. With no non genuine alternatives available I went the local brake shop who said that re-sleeving for $220 was the best alternative. They've always done good work so I was happy to leave it with them. And picked up a few days later. Once the wheel studs and hubs were back together it was time to refit the MC and bleed the brakes again, first time I did this it was a breeze, as easy as any bleed I've ever done but this time I couldn't get any fluid to pump to the rear brakes. After much mucking around and brake fluid usage I relented and pulled the MC from the car and tried to bleed it on the bench...still no luck. The front bled fine but each type I stroked the rear reservoir would result in bubbles and an increase in the level of fluid.........definitely something not right here. Being a Sunday I wasn't prepared to wait until Monday to return it to the brake shop so I pulled it apart and it was pretty apparent what was wrong, they had reassembled the piston for the rear system incorrectly and had put the spring on the wrong side of the return/check valve: How it should be: Not happy Jan! Anyway, put it all back together and it bled fine. Went an fronted the brake shop yesterday and showed them pictures.....they sort of apologized but not with much conviction. On to some good news.....I've allowed myself one piece of bling on this car and picked it up from Freddy yesterday:
Bit pricey for second hand but I found this mob selling new right hand regulators out of the US http://www.new-datsun-parts.com/datsun-240Z-parts-doors.htmljust waiting on a shipping quote. The teeth on mine are fine its the spring mechanism that acts as a brake inside the winder housing that is broken. I've mucked around trying to fix it but its never going to be good. I reckon the same spring/winder mechanism off the 260Z will be the same looking at pics. Has anyone got a good RH 260 regulator they want to part with?
I cant believe what I just read.....our taxes at work and bureaucracy gone mad.
Lost Dog / Whippet, Eastern Suburbs Melbourne
KatoKid replied to ilbert's topic in Off Topic Discussions
I feel your pain. May help to post more details of your location as people close by are more likely to keep an eye out....Melbournes a big town! -
Bump for this one guys...Lurch thought he had one but turns out its no good.
Not possible for me Brad due to the rear brake caliper brackets, not enough space to get the old studs out let alone trying to get new longer studs in place
Been away for work and busy with other things. I have place a substantial order for interior parts from MSA but a few items are on back order so waiting for them to come in before they ship. Had to find longer wheels studs as I need studs 8mm longer front and rear to get sufficient thread engagement. Standard studs are: Knurl diam - 12.8 mm Thread - M12-1.25 Length (front) - 32mm and shoulder 10mm (rear) - 39mm and shoulder 14mm Its hard to find exactly what I need in M12-1.25 so as I'm changing both front and rear you get more options if you go to the more common M12-1.5 For the rear: https://niceproducts...s350a-stud-nut/ Front: https://niceproducts...ns354-stud-nut/ I needed nuts so I've ordered studs and nuts but you can order studs separately and they arrived today. Just need to press them in which unfortunately meant disassembly of front and rear hubs..... not difficult but just a PITA grrrrrrr!
I've just ordered from Nice as I need studs 8mm longer front and rear to get sufficient thread engagement. Standard studs are: Knurl diam - 12.8 mm Thread - M12-1.25 Length (front) - 32mm and shoulder 10mm (rear) - 39mm and shoulder 14mm It hard to find exactly what I need in M12-1.25 so as I'm changing both front and rear you get more options if you go to the more common M12-1.5 For the rear: https://niceproducts.com.au/product/ns350a-stud-nut/ Front: https://niceproducts.com.au/product/ns354-stud-nut/ I needed nuts so I've ordered studs and nuts but you can order studs separately. David
Gearbox roll over noise is pretty common. You can replace bearings chasing this and still be the same.
Hi Craig. Pm on its way with mates phone number. Thanks.
Thanks Gav!
Off topic so apologies. I loaned my air cleaner to my mate just to confirm that it would work and noted that my air cleaner only had a trumpet on the rear inlet not the front. It didn't look modified so assume this was standard for my 8/71 build car?
Thanks Craig. Will check with my mate and get back to you
Cos factory look!
240Z 260Z 2 Seater Complete Exhaust System
KatoKid replied to zed74's topic in Parts and Tools for Sale
You are like a Hurricane......good deal -
I have a mate who wants a damaged one to adapt to his twin weber set up on his 1600, so still interested in selling?
How did you go with this....I'm in the same place?
