2,236 -
137
Everything posted by KatoKid
Not much happening lately as pedal powered two wheel endeavors has taken over: https://www.strava.com/activities/896725050 https://www.strava.com/activities/913159438 Installed the tail shaft and other bits and pieces needed to make this thing move under its own power....if I had wheel nuts I could have driven it! Good news: Thermo fans work a treat, had it idling on the hoist for half an hour and fine tuned the cut in temp. Works brilliantly, one fan comes in then 10 seconds later the other fan, run for a couple of minutes until they pull the temp down 5 degrees and cut off....rinse and repeat numerous times. I was somewhat concerned that the eBay radiator and fans wouldn't cope but seems really solid. Ran through the gears and gearbox seems good and no drive-train vibes. Clutch feel and take up point is perfect. Speedo works! Binacle lights for Charge and Brake warning work. Bad news: Idle is crap for some reason NFI why! Grrrrr
Nice engine bay paint job.....not
Looking good!
Nothing photo worthy but another significant milestone.....my brother came around a gave me a hand to bleed the brakes. Was a very straight forward and painless task , all done in 5 minutes. Pedal feels excellent and no leaks so happy chappy. Also gave the clutch a proper bleed after just back purging with a syringe. It was a bit doughy before but feels great now and the take up point is halfway off the floor...perfect.
Loving this....keep at it!
- 104 replies
- 260z
- Restoration
(and 1 more)
Tagged with:
More little annoying stuff getting done.....booster hose. Went to Pick a Part and grabbed a few different bends that looked like they may work and really lucked out as one was perfect at the booster end (including valve) and looks like it was from the factory. A bit of straight hose from Enzed did the rest to the manifold. Little steps taking soooo long!
Much awesomeness Gav, so stoked for you! I was going to say when I started reading but you beat me to it in the end....outsourcing the bodywork is the way to go, financially it may be a struggle but to do justice to the car its nearly a must. Good luck, will be watching and along for the ride with you. David
NFI Gareth. More wiring....seems like it never ends. Speedhut gauges don't have provision for them so I need to provide additional warning lights for charge and brake warning. The engineer will expect the brake warning to be in direct line of sight so I made a binnacle to go on top of the honeypot. Came up OK but once through engineering I may move them....to this location which uses the driver side fresh air vent cable mount and ties in the underneath dash bracket. Knob is for dash light dimmer, On/Off for arming the fan controller and the last vacant two for the warning lights for charge and brake warning if I choose to move them. In keeping with my desire to not cut or drill holes the Davies Craig programmable fan controller is mounted to a plate that uses two holes that originally mounted the regulator. Fan power comes direct from the +ve terminal to an insulated stud and the controller power comes from the switch above under the dash. I've also read of plenty of incidences where aluminium radiators if not insulated from the body and if fans aren't separate earthed will result in the radiator being eaten by electrolysis in a very short time. Not sure how true this is but everyone swears by insulating so a quick trip to Pick a Part provide the insulators and crush sleeves. Something non electrical....yay! I made the hard lines for the front calipers. Ordered the stainless braided lines this morning and they were ready this afternoon. Fronts are an exact copy of the originals, the rears are R31 but 20mm longer and has the inverted flare on the body end rather than the R31 bubble flare. All bolted up easily....just gotta bleed them now. Getting closer!
Thanks everyone, looks like I need to do some bending! Cheers
You sure that's all that's been fiddled with
Hey all. I've got a Compe wheel for my car and tried it for the first time since I bought it 2 + years ago and the indicator stalk is way to close to the wheel, so much so that you couldn't drive it without the back of your knuckles hitting the stalk as you steer. Is this normal and the stalk needs to be bent to make room? David
I'm not too worried Mick, if it does affect the suspension geometry it wont be much and I doubt you would notice driving on the road. More baby steps.....reverse light switch and speedo sensor or wired in. There is a very handy rubber grommet on the top of the tunnel behind the fuse box that does nothing but is a great place to run wiring for the gearbox. Very neat and tidy. Also tidied up the connectors and wiring for the O2 sensors.
KatoKid replied to gav240z's topic in Cars For Sale
Looks like a decent shell and a good body shop could fix that as long as its not completely bent from front to back -
Hi Mick. I'm using the BMW tailshaft that has whats called a Guibo joint at the gearbox end. Its just like a big rubber doughnut but it doesn't tolerate any deflection meaning the output shaft of the gearbox must be pointing straight at the nose of the pinion shaft. I couldn't lower the nose of the pinion any more so the only way I could get the alignment right was to lower the front of the engine, hence the spacer....and it bought me just a fraction more room for the gearbox in the tunnel. David
Got a bit more done tonight. Rack ends and boots installed and set the Toe just roughly and confirmed that the RA65 Celica rack ends provide enough thread for adjustment. Did I say how much I love bolting stuff on for the last time (hopefully)!
Nope, bushes are genuine Nissan.
Yep,definitely 2 per side
Stronger Uj / Diff Flange For R200 Longnose?
KatoKid replied to Dan260Z's topic in Brakes / Drivetrain Components
Haha....small world, Jeff did my hybrid BMW/Datsun drive shaft! He has some pics of his blue 240/260 on the wall in his workshop -
Thanks for the suggestions guys, gives me some option if this doesn't work. Instructions look like its designed to work with many small teeth like an ABS sensor but they say that it will work with anything ferrous. http://www.speedhut.com/instructions/speedometer_sensor_instructions.pdf Anywhoooo....got the rear hubs, brakes and CV shafts final installed. I had to weld a small tab on the strut leg to clamp the handbrake cable as it was very close to my custom CV adapters. Its close but clamped rock solid so engineers should be fine with it.
I swapped flanges from what I was told was a later model viscous LSD R200 to an earlier one with no problems. Just my experience, but cant be 100% guaranteed because I'm only going off what I was told by the sellers. -
Yep, input shaft size and spline count are the same -
Later R200's have bigger flanges and bolts and you can swap them easy enough. http://forums.hybridz.org/topic/75675-r180-to-r200-pinion-flange-question/ -
Got all my bits back from plating that I had left out or forgotten to do with the first batch, plus my handbrake bell-crank which I had modified. Love bolting on shiny bits! The ZF gearbox doesn't have a speedo drive or output of any kind as the road speed signal originally comes from a chopper plate and sensor bolted to the BMW diff crown wheel so I need to provide a signal for the Speed Hut speedo. The speedo can read and be calibrated for just about any signal so I chose to use their optional Hall Effect sensor which I made a bracket for and mounted it to trigger off the triangular output flange of the gearbox. It needs a pretty small air gap of max 1.3mm so it had to be robust with no deflection. Fingers crossed this works OK.
