2,236 -
137
Everything posted by KatoKid
Did LOL when I opened the picture!
Brother dropped in and helped fit the 1/4 windows....definitely a 2 man job with new seals but pretty straight forward. The 1/4 windows define where the door frames need to sit to get good gaps where the back edge of the chrome door frame and the front edge of the 1/4 frame meet. And you need to fit the door seals so that you can check they are parallel in both planes. Whoever discovered the Kia Sportage seals are a good fit needs to be commended, they are absolutely perfect. After an hour of adjusting I got the gaps all parallel, doors closing nicely and sealing and the glass winding up and down and sealing properly. Bit of mucking around but not too bad. Also fitted the chrome trim to the tail light surrounds which was a bit stressful to ensure no paint was damaged and then fitted these and the painted number plate light to the car. Very happy with the colour and satin finish. It looks dark in the picture but is a lot lighter, it was matched to the Fairlady grille I have so I'm confident its close to original . Also painted the brackets and fitted the new hatch gas strut.
Both doors are now fully built up with new bailey channels. New regulator on the drivers side is awesome.......still need do some adjusting but waiting on my brother to come around to help fit the 1/4 windows as its a 2 man job with the new seals. New glove-box is fitted and I've hidden the BMW ignition barrel/key inside as this is required for the factory EWS II anti theft to work. When I park up, just reach over and remove the BMW key.....and no more starty!
http://www.thezstore.com/page/TZS/PROD/12-4420
Cheers guys, its really exciting to have most things I need to finish the car so quite motivated right now! Tackled the 1/4 windows today, not a job I've looked forward to. My frames are in excellent condition but it still took 6 hours of work to dismantle clean, paint and reassemble with new reproduction inner and outer seals. Cant believe I pretty well burnt a whole day on these! Precision seals were an excellent fit and really pliable so easy to fit....big thumbs up. Still need to install in the car but so far so good.
Yep, individually as I wanted to go genuine wherever possible. Hard to say what it cost as I bought some genuine seals a while ago so that the panel shop had them to ensure proper alignment for doors and rear hatch etc. and then I just picked the eyes out of what else I needed for the big order from MSA. Just check their website.
So some easy stuff first .....cos I wanted it to look more like a real car and lights go a long way to making it look a bit more complete! My front parker/indicators were pretty stuffed, reflectors damaged and some screws completely rusted in place or broken off, so much so that I deemed them to be not practically repairable. With a lot of time and effort they may come up OK but since I was ordering other stuff from MSA it just made sense to buy new ones. Fitted the headlight assemblies with new gaskets and also the reproduction tail lights that I bought a couple of years ago from a member but with new genuine gaskets. Once fitted it was a good feeling to check and confirm that all the lights worked, including reverse lights and my headlight relays. One step closer...lots of seals to fit now and I bought a tube of 3M weatherstrip adhesive from Blackwoods to get started. https://www.blackwoods.com.au/part/03392052/adhesive-weather-seal-strip-8011-150ml Not looking forward to this bit!
You can by new genuine from MSA or even try Nissan Aus
Just purchased a tube of the 3M stuff that Precision used in their video. $24 from Blackwoods. https://www.blackwoods.com.au/part/03392052/adhesive-weather-seal-strip-8011-150ml
Thanks Jeff. US trip is not such a silly idea! I'm the first to admit I've gone a bit overboard with some things but I don't want to cut corners and end up with something that I'm not 100% happy with. I probably could have spent half of what I did with MSA and it would have been OK......but OK isn't my thing!
My MSA order just arrived. I ordered genuine seals where available and all other seals supplied by MSA were Precision. Can anyone recommend a high quality weatherstrip adhesive available in Australia?
MSA order finally showed up today...yay. US $3,300 worth including $600 FedEx freight so AUD $4,500 plus another $600 duty and GST......farking!!!!! Not cheap but includes all the interior parts and seals etc to finish...in for a penny, in for a pound. I went for genuine parts where available and repro where there wasn't an option, so it added up quickly. Things should progress quickly now so expect lots of updates on a regular basis
I've had the same Gav....its just revenue raising
I've got a full set of the Diamond embossed Trans tunnel/Riser/ Wheel arch/ Shock Tower set from Dave. Wondering what people are using, if any for underlay on the tunnel section? I've got Dynamat on the floors and tunnel and thinking I should have some form of thin underlay that I can glue to the back of the embossed vinyl and then lightly glue the underlay in strategic locations to the Dynamat on the floor and tunnel to hold the vinyl in place. Cheers
My car is a 4/71 plated HS30 chassis # 00728. Twin levers and 71A originally.
Short block is just block, bearings, crank, rods, pistons. Long block is generally complete engine but without accessories to run it like distributor etc. may include sump and rocker cover.
I missed my headlight housings and some other small pieces when I sent of my original job lot of parts for plating so only just received these back yesterday. Headlights are full assembled with new wiring and plugs...just waiting on my gaskets from MSA....along with all the other parts that they said they have stock of but apparently don't!
Photobucket Want $400 Odd Dollars For 3Rd Party Hosting?
KatoKid replied to MATTY's topic in Off Topic Discussions
Agree with Gareth and others on this. Image upload alternative provides some reassurance if you want you build thread to be documented for prosperity. I would be shattered if I lost all the images in my thread -
Stock Looking Airbox for Triple Mikuni Carburetors
KatoKid replied to gav240z's topic in Fuel Systems
Haha....quote of the week Alan! Half of China probably thinks so too! -
What he said /\
Meant to ask.....how much R&D is involved or have you just looked at what others have done and integrated into the Z?
Not your average street car body kit! Well done, looks super aggressive.
http://www.thezstore.com/page/TZS/PROD/10-9008
As per my wanted thread http://www.viczcar.com/forum/topic/16185-wtb-240z-drivers-side-window-regulator/my drivers side regulator is stuffed. I could make it work sort of, but it will never by right...so.... http://www.new-datsun-parts.com/datsun-240Z-parts-doors.html which just arrived today. Shiny and happy people. Interesting to note his price has jumped by USD $20 since I placed my order....suspect he may not have many left.
