504 -
17
Everything posted by Enzo
Hi Guys, I have a 1976 260z coupe with a faulty vacuum advance cannister. Any ideas on where I could get one in Australia. The Zstore in the USA has them but with a wait of 2-3 weeks and us$103.00 delivered. :'( Thanks David.
Hi Chris, Try This. Establishing the correct idle jet for a given engine is not easy but usually an approximation will make the car acceptably driveable. If the progression is weak then the engine will nosedive when moving the accelerator from smaller to larger throttle openings. A certain amount of change (richer/weaker) to progression can be achieved by varying the air jet size on the idle jet; this alters the amount of air that is emulsified with the fuel drawn through the idle jet. If this does not richen the progression sufficiently then the next jet size up, with the same air bleed should be tried. Below is a small chart showing the most commonly used air size designations, running from weak to rich. Generally speaking start your selection with an F9 air bleed. Weaker Normal Rich F3 , F1 , F7 , F5 ,F2-F4 ,F13 ,F8-F11-F14,F9 , F12 , F6 The ones in normal use are F2,F8,F9 and F6. Regards David.
I like a joke as much as the next person, but I think that in these times racist humor would be the last thing that needs to be posted on an Automotive website that is viewed worldwide. I am disappointed that it is endorsed by a moderator. David.
Valve Clearance (hot) Inlet........0.010 in (0.25mm) Exhaust....0.012 in (0.30mm) Valve Clearance (cold) Inlet.......0.008 in (0.20mm) Exhaust...0.010 in (0.25mm) The 0.002 in difference between the hot and cold settings is for the expansion of the hot metal. David.
I agree with Lurch. I think he's on the money. David
What sort of distributor is this? How do i hook it up?
Enzo replied to d3c0y's topic in Electrical systems
Hi Jake, Looks like you have a Crane XR700 electronic ignition trigger. It would have been attached to the ignition module. I have one on my 260z. A good simple system which has been on my Zed for about 4 years. Regards David. -
Hi Guys, I have been looking for a set of strut inserts to replace the shot Monroes in my 1976 260z. I have just ordered a set of Tokico Illumina 5-way adjustable inserts from the USA for AU$622.00 delivered to my door. They also have cheaper inserts, Tokico HP (blue) and KYB. The seller is (JDMWERKS13) and I found them by typing (260z shocks) into the ebay search and scrolling down to the international sellers. I tried to buy local but the prices quoted and the variety available made it better to buy overseas. Hope that this helps anyone after inserts at a good price. David.
Hi, It's unfortunate that you have a problem of this sort, but you have to bare in mind that we all drive 35 year old cars and any parts that have not been replaced with new can be prone to metal fatigue or wear. Luckily it didn't come apart when you had your foot to the floor in fifth gear. David.
Merry Christmas to all ( including the Grinch ) and a Happy New Year. May the wind always be at your back and your Zed live a rust free life. Regards David.
A few years ago I bought a 280zx Fairlady that had a L6 2000cc efi engine for various parts. Gearbox, diff etc for $100 . The body was stuffed, But I found $13 in coins behind the seats making it an $87 car. It made my day. David.
i think its been droped as ive noticed lowering blocks and the rear leaf springs have been positioned on the highest position= car lower. Hi Mate, Can't see lowering blocks in your last picture but the lift kit fitted to the end of the rear springs will lift the car. These are attatched to the original anchor points for the springs to raise the car. Only good if you want to fit fat tyres or give the car a raked look. It raises the centre of gravity as well. Not good for high speed. All in all, it looks like a nice project. David.
I really enjoyed the video. It brought back a lot of memories of when I lived near Bathurst and raced back in the 80's. It looks as if the car handles very predictable. What suspension setup do you have. Once again,well done. I'm envious. David.
Good photos Peter. I only had the photos of when everything was back on the car. I didn't have to move the hole as far as yours because I had the bump steer spacers on the bottom of the struts. David.
Hi Guys, I can't post the photos because it tells me the files are too big (over 256mb), but if you look in my gallery the photos are there. By the way Rev, you and the boys are a bad infuence. I gave my 260z a christmas present and put the triple Dellortos back on after reading about everyone else playing with theirs. ( Dellortos that is ). David.
Hi Rev and Pauly, I already had fitted alloy bumpsteer correctors to the bottom of the struts, but these were not doing the trick. After a bit of research I removed the cross member and used a cold chisel to remove the washers on the inside of the holes for the control arm. I then used a centre punch to mark the location of the new holes. I welded up the original holes and drilled the new locations on the centre punch marks. I then fitted the control arm bolts with the new washers on the inside of the crossmember and held them in place with clamps, and spot welded them with the electric welder. Prior to removing the washers I had measured the gap between the holes. After welding the gap was a couple of mm closed up so I just fitted a bolt with 2x nuts and used this to spread the sides. I only had to drill the holes 13mm higher and out 4mm to make the control arms and steering arms parallel on my car. Then a tidy up with a file to get rid of any sharp edges and dags, and hit it with a can of paint. Off to the wheel aligner for a toe-in adjustment and hit the road. Hope that this helps. Photos to follow. Tried once but it didn't work. Regards David.
Hi Craig, If you go to the link section and click on the Western Australia 240z & 260z Club/register you will see listed (ANZIS30 ). This is the Australian and New Zealand Internet S30 Register.This is similar to what you are talking about. Hope this helps. Regards David.
Hi, I had a similar problem in another car recently. The regulator in the alternator was burnt out allowing the battery to discharge even when the key was turned off. A new alternator had to be fitted. Take you car to an auto sparky for a checkup. David.
Hi Rev, Check the timing on the distributor as this will sound like a low battery if it is too far advanced. Good luck. David.
Hi Dave, Take Zedmans advice and replace the broken bolt or you could be in for major expense if the pressure plate comes adrift. In fact replace all of the bolts. If you over stressed one bolt than the others may be as well. Buy a tension wrench and do the job properly. A tension wrench should always be used and manufacturers recommendations adhered to unless you are a backyard cowboy. It's you life and you passengers that you are playing with if you do botchy jobs. That's my 2 cents. Have a nice day. David.
Hi Guys, Don't know if you can take it as gospel but the only info I could find regarding the difference between the RB and the RBR series is that the RBR is for rear wheel drive fitment. They have a lower offset than the RB and a bigger lip. Apparently made for drifters. This came from an American webpage. Regards David.
G'day, Try priming the oil pump with STP oil additive. The stickiness creates suction. I had a new L26 motor about 4 years ago that would not show oil pressure when cranking over on the battery, so I hooked up the electrics and fired it up. The oil pressure came straight up. This was safe because the bearings all had been lubed with STP on the rebuild. Regards David.
Hi Rev, I use Redline water wetter in my radiator. This reduces temperatures in the engine. Check out the redline website to explain why it works. Regards David.
Not firing on 3 cylinders think it might be fuel related
Enzo replied to ol_skl_jp's topic in Fuel Systems
Hi Sach, The fuel leak will be from a blocked pump jet. Remove and blow through it. More info required as to what changes you made when fitting the manifold and over what period of time.Also check the plug leads and cap. What fuel pressure are you running. Should be about 2.5 psi. Regards David. -
Hi guys and gals, I just received my new catalogue from Black Dragon Automotive on friday. ( 2008 Spring Edition ). For those that don't know this used to be called Victoria British. It has accessories and parts for 240z, 260z, 280z (1970-78 ); 280zx (1979-83 ); 300zx (1984-96 );and 350z (2003-05 ). This is an American catalogue and can be ordered free at www.blackdragonauto.com . Took about two weeks to arrive. Check them out online . They have some hard to get parts and the exchange rate is good at the moment. Happy motoring. David.
Hi Richard, I buy Redline products from Coventry's. I also use their engine assembly lube and their water wetter for the radiator. Check out their website. It's a good read. www.redlineoil.com. regards David.
