Replace the dovetails with the billet items - they are much stronger.
And have all the rusty parts you intend to get plated, hydrajet blasted first.
Sound advice
i'm sure not to everyones taste but am trying to replicate 50 year old car without the rust
So plan on using original unrestored parts and only use new when have no choice ie hoses ,bonnet, rubbers and mechanical components
Just a pity that I have so many little bits to get and the hoses are so expensive!!!!!
Nick
2 hours ago, Millerman said:
I bought a whole nolathane bush kit for complete car recently. Looks great and is black too instead of usual red!
Hi
Where did you get the kit from Nolathane said nothing available for 240Z
Thanks
Nick
There's a bloke here in Brisbane making all the bushes for Zeds. I will find out details for you.
Most bushes you can still buy new from Nissan if you know the part numbers. The only exception I've found so far are the moustache bar bushings (which I used Whiteline insead of OEM).
  • 4 months later...
Posted (edited)
A few bits sorted over last couple of months
Rebuilt drivers side hinges, repaired top of screen surround drivers side, cut out rust and repaired both doors
Removed a 2.0lt bucket of body filler from doors and removed most of the dents, used a shrinking disc on high spots works pretty well
welded up holes that had been left from slide hammer.
My welding is pretty ugly but seem to be solid think I might try .06mm easier on thin metal???
Edited by NickF
  • 1 year later...
Its been a long time but thanks to the help and generosity of Lochy at C.A.R I've finished the rear valance and rear 1/4 repairs.
Lochy fabricated the valance and supplied the trim clips. Without the clips I couldn't moved forward as I couldn't position the trim.
The job would have been so much easier if I had a car to reference as photos are not really good enough, getting gaps right and shaping
the rear 1/4s was tedious.
Now that the rear is in primer I am torn between keeping the car original 905 red or going for a grey not metallic  (very popular at the moment)????
Plan to move on to  repairing floor pans (Keep as much original material as possible)
I wish I had a factory 905 red Z myself.
