Thats cool i didnt know they came in that size, i wonder if they are any good.
Rare in that size, I sold 1 carb a while back for about $300. So if you can get a matched set of 3 for $1,200 I reckon that's not bad.
I'm not sure with Dellorto's but with Mikuni's you can choke them down. Better to go big and make em smaller than go small and try and make em' bigger.
I have a pair of those, good for 40mm carbs. That eBay seller deals a lot in Mikuni's I believe they have a website.
https://www.youtube.com/channel/UClHMvCcDDaBXz9TMsu4MXiw
http://www.gl2007.com/usa_kyusha.html
Sadly deleted a bunch of their videos on Youtube. I used to like going there and listening to an L-series scream! :D
Fek.....so these are good carbs then. I see all of these different numbers and stuff after DCOE, 2,3,13 so i wasnt sure.
May be a little on the smaller side, but could be a cheap way of getting some triples.
https://www.gumtree.com.au/s-ad/hallam/engine-engine-parts-transmission/solex-mikuni-carburetors/1166455154
I assume hard to tell from these photos, but they kind of look different, is it possible though that there is atleast 1x S4 and 1x S5? i.e. not matched?
https://www.ebay.com.au/itm/Datsun-240Z-Triple-Mikuni-40PHH-36-Venturi-Horns-and-Extra-Jets/263345096796
Triple 40mm Mikuni's.
AU $1,300.00 buy it now.
40 mm Solex/Mikuni Triple Carbs with 36 mm (Chokes) Venturis  .. Includes Air horns and Isolators--  ALL HAVE BEEN ZINC PLATED !!
Completely rebuilt and Micro polished in USA by PALTECH.
Originally bought these from the USA. They are set up for a 3.1. We found a set for our standard Z with a manifold so we have never used or installed these - so, as nice as they are, they have to go
Jets etc included:
36mm venturis
165 fuel
210 air
60 pilot
45 pump nozzle
155, 160, 170 and 175 fuel jets
190 and 230 air jets
Have a manual for tuning etc
These carbs are still popular in the US with various parts available
Needs a manifold to suit but will fit the standard Weber compatable manifold readily available.
Would also suit twin cam 4 cylinders - have a spare carb!
The middle carb is a solex and the other two are Mikunis. Interesting...
I think that's just the jet cover, I am actually more worried about the serious level of corrosion I see... seller got a bit upset when I queried that on Facebook.
Perhaps best avoid this set..
