Administrators gav240z Posted November 11, 2018 Author Administrators Posted November 11, 2018 White 71 240z with Blue interior. 5/71 build date. https://www.ebay.com/itm/1971-Datsun-Z-Series/264030801530 HLS30 - 31944 L24 - 040765 This is a couple of months earlier than my 904 white/blue 71 240z which has (L24 - 055449) delivered 3/11/71. Quote “THIS IS A RARE SURVIVOR THAT I WAS FORTUNATE ENOUGH TO HAVE ACQUIRED FROM THE ORIGINAL OWNER NEARLY 13 YEARS AGO. IT CONTINUES TO BE COMPLETELY RELIABLE, STRONG & SMOOTH RUNNING, GO ANYWHERE WITH CONFIDENCE, A THRILL TO DRIVE. ORIGINAL ENGINE- ACCURATE MILEAGE. THE VALVE TORQUE WAS ADJUSTED, COULDN'T SOUND OR PERFORM ANY BETTER,TRANSMISSION SHIFTS PERFECTLY & SMOOTHLY THROUGH ALL GEARS. PARTS REPLACED: BATTERY, CLUTCH MASTER CYLINDER, CLUTCH SLAVE CYLINDER, WATER PUMP, RADIATOR, STRUT ROD BUSHINGS ,GAS TANK DROPPED REPLACED NECESSARY FUEL HOSES. BODY INTEGRITY: THOROUGHLY RUST FREE- ALL PANELS, FLOOR, UNDERSIDE. NEVER AN ACCIDENT. PAINT DONE IN KILIMANJARO WHITE PAINT CODE 904 ORIGINAL TO Z. ALL NEW OEM WEATHERSTRIPPING. INTERIOR: RARE TURQUOISE, SELDOM SEEN!3 CRACKS IN DASH. NOT WORKING: AC, CLOCK,ANTENNA. ALL OTHER FEATURES DO. HAVE OWNER'S MANUAL, ORIG MAGS, OVERRIDER BAR, JACK & TOOL KIT, RECEIPTS, ORIG CA BLUE PLATES, LOW RESERVE,THIS MATCHING #'s Z WILL SELL! BEST OF LUCK!” Quote
Administrators gav240z Posted November 11, 2018 Author Administrators Posted November 11, 2018 Another 71/70 car. Current bid:US $5,101.00 Reserve not met https://www.ebay.com/itm/1971-Datsun-Z-Series/183519132558 HLS30 17022 ' Quote “Not currently running. Serviceable - Manheim Grade 5. The front and rear carburetors and fuel tank have been removed. Car has rust over both rear fenders, as well as some rust on underside of hood and driver side door corner just under front lower edge of window. There is primer over significant portions of the rear fenders and body, as can be seen in the listing images. The interior has significant wear. Door panels are missing. Seats are worn. Windshield is cracked and needs to be replaced. Headlights and tires need to be replaced.” Title is clear and in possession of seller. Vehicle will be sold as is, where in. Buyer responsible for pickup. 1971 Datsun 240Z - Series 1. This car has the Series 1 chrome 240Z badge on the sail pillar, and two horizontal vents in the rear hatch below the glass molding providing flow through ventilation. Estate Item located in Idaho. Car is not currently running. Serviceable - Manheim Grade 5. The Front and rear carburetors and fuel tank have been removed. Car has rust over both rear fenders, as well as some rust on underside of hood and driver side door corner just under front lower edge of window. There is primer over significant portions of the rear fenders and body, as can be seen in the listing images. The interior has significant wear. Door panels are missing. Seats are worn. Windshield is cracked and needs to be replaced. Headlights and tires need to be replaced. Odometer Reading os 00623. This item is an item from an estate. We expect that the car has been driven enough to have turned the odometer over. Quote
Administrators gav240z Posted November 13, 2018 Author Administrators Posted November 13, 2018 https://losangeles.craigslist.org/wst/cto/6746795647.html 1970 Datsun 240Z 2 Owner From New Early Vin Manual Trans Dark Green - $18500 (Los Angeles California) HLS30 01850 Early Vin Right Year 02/ 1970 Matching Number Engine: L24 4468 Quote
Administrators gav240z Posted November 14, 2018 Author Administrators Posted November 14, 2018 https://bringatrailer.com/listing/1972-datsun-240z-70/ Quote
Administrators gav240z Posted November 18, 2018 Author Administrators Posted November 18, 2018 Lovely 72 240z for sale. https://www.classiczcars.com/forums/topic/61075-1972-datsun-240z-for-sale-port-orange-florida/ OdinZ 1 Quote
Administrators gav240z Posted November 19, 2018 Author Administrators Posted November 19, 2018 https://page.auctions.yahoo.co.jp/jp/auction/c695604104 Buy it now: 6,980,000 yen (AU$88,506.40) Quote Vehicle condition 47 years formula S30Z ZG specification Body three years ago, full restoration After the total peeling, all painted in genuine green Front fender + rear bumper only FRP, all others are new exchange and sheet metal. You do not have fenders cut before and after. After assembly engine L28 modified 3.1L, about 2000㎞ traveling Turtle Ali piston LD28 crank (short process) L14 connecting rod (up balance) Big valve 46X38㎜ Kameari 75A cam port polishing Solex 50 Steel 48 pie, such as length octopus foot steel 80 pie muffler (tail, stainless steel) Kameari ATI damper pulley reduction starter motor professional Mobit large-capacity aluminum oil pan Bikkudesubi, Furutora + MSD (CDI) for injection fuel pump (2 group seat regulator) OS twin-plate clutch large capacity release electric fan specifications battery luggage compartment movement Glove box in the fuel pressure gauge oil temperature gauge oil pressure gauge Mission 71B Kameari, 5-speed cross Undercarriage before and after harmonic drive front MK63 caliper (bench disk) R200LSD (4.375) Wheel 14 inches, Watanabe R type 8.5J-15 (205/60/14) 9J-20 (225/60/14) Quote
Administrators gav240z Posted November 21, 2018 Author Administrators Posted November 21, 2018 Bring a Trailer, brings out the money for the beige colour car! https://bringatrailer.com/listing/1972-datsun-240z-70/ SOLD FOR $40,000 ON 11/20/18 Quote
Administrators gav240z Posted November 23, 2018 Author Administrators Posted November 23, 2018 73 HLS30 painted in Safari Gold. https://buyee.jp/item/yahoo/auction/g282381072 4,500,000 yen (AU$57,600.00) buy it now. Quote
Administrators gav240z Posted November 23, 2018 Author Administrators Posted November 23, 2018 https://bringatrailer.com/listing/1973-datsun-240z-80/ Quote
Administrators gav240z Posted November 24, 2018 Author Administrators Posted November 24, 2018 https://bringatrailer.com/listing/1972-datsun-s30-fairlady-z-right-hand-drive-japan-only/ I've seen this car in person. If anyone wants an honest assessment. It will need work. Body is quite rough in usual spots. Probably should have bought it 2+ years ago as a non runner.. OdinZ 1 Quote
Administrators gav240z Posted November 29, 2018 Author Administrators Posted November 29, 2018 Takeeys has a Z423-R tribute car for sale. Looks more 905 red than 918 orange to me? http://www.goo-net-exchange.com/usedcars/NISSAN/FAIRLADY_Z/700060083430181010001/index.html Quote
Administrators gav240z Posted November 29, 2018 Author Administrators Posted November 29, 2018 The car Mr Lee's tried to pass off a while ago as being in his possession. http://www.goo-net-exchange.com/usedcars/NISSAN/FAIRLADY_Z/700060083430181009003/index.html Quote
Hardman Posted November 29, 2018 Posted November 29, 2018 (edited) 9 hours ago, gav240z said: The car Mr Lee's tried to pass off a while ago as being in his possession. http://www.goo-net-exchange.com/usedcars/NISSAN/FAIRLADY_Z/700060083430181009003/index.html Hey Gav, I'm genuinely curious as to how you find these listings. Do you have alerts set up for anything z car on every sales website you can find or do you constantly search? I've been keeping an eye out for a rally clock but the only place I can find stuff is listings you post. Haha Edited November 29, 2018 by gav240z Removed quoted images. Quote
Administrators gav240z Posted November 29, 2018 Author Administrators Posted November 29, 2018 There is just a number of sites to keep an eye on for S30Z's. Goo Net is great, just search by chassis eg: S30, PS30, HS30 etc.. As for Rally Clock's, from memory you have a 260z right? You'll probably want a Calendar Clock instead. Quote
OdinZ Posted December 4, 2018 Posted December 4, 2018 https://jdmlegends.com/collections/comming-soon-vehicles-for-sale/products/1973-240z 1973 240z US$ 89,000.00 GongZ, Hokin, JDM-TOY and 1 other 4 Quote
Administrators gav240z Posted December 4, 2018 Author Administrators Posted December 4, 2018 Beautiful car, well worth it in my opinion. Hokin and OdinZ 2 Quote
Administrators gav240z Posted December 7, 2018 Author Administrators Posted December 7, 2018 https://denver.craigslist.org/ctd/d/1971-nissan-skyline-2000gt/6765780706.html Quote
Administrators gav240z Posted December 8, 2018 Author Administrators Posted December 8, 2018 https://bringatrailer.com/listing/1970-datsun-240z-31/ Quote
Administrators gav240z Posted December 11, 2018 Author Administrators Posted December 11, 2018 Beautiful 260z in the US sold for $17,000 USD. https://bringatrailer.com/listing/1974-datsun-260z-16/ Probably 1 of the better deals in the last few years on BAT. Quote
Kuba Posted December 11, 2018 Posted December 11, 2018 Clean looking 260z on Facebook gav240z 1 Quote
Administrators gav240z Posted December 19, 2018 Author Administrators Posted December 19, 2018 https://www.trademe.co.nz/motors/used-cars/nissan/auction-1866251685.htm Nissan Datsun 240z 1973 Australian delivered car: HS30 103464 Currently in NZ. Prince: $59,000 NZD. Quote Datsun 240z1973 manual 5 speed, rust free survivor, has later l28 motor fitted,also comes with 240 motor, carbs , air cleaner etc , two sets of mags and set of original hubcaps, excellent driver Quote
Administrators gav240z Posted December 19, 2018 Author Administrators Posted December 19, 2018 RHD Fairlady Z in the US. https://www.ebay.com/itm/1970-Datsun-Z-Series-Fairlady-240Z-/163439575664?_ul=AU OdinZ 1 Quote
Administrators gav240z Posted January 4, 2019 Author Administrators Posted January 4, 2019 https://www.ebay.com.au/itm/163467339751?ul_noapp=true Price:AU $11,500.00 buy it now. Honda S600 Convertible. Rare bird. Quote On offer is my Honda S600 Roadster project and a heap of spare parts. Car is in great condition and the paintwork won't take too much to detail. The engine is out of the car as is the gear box but they are all there. There is a heap of spares where there is too much to list. Car also comes with a new stainless steel replica exhaust system which cost $2000. Additional to the spares there is a complete spare engine. There is also a heater, new gaskets, new brake lines, alternators, gauges, electrical parts and more. Car has no apparent accident damage and body and chassis have no rust. The car also comes with a rare original removable hard top. These cars are getting very hard to find in good condition will most certainly become a worthy investment. Car is located in the Northern Suburbs of Wollongong. Pick up only but can assist with loading for interstate buyers. If buyer pays by pay pal buyer to pay fees unless already agreed to. Thanks for looking. Quote
