juz0 Posted March 3, 2015 Posted March 3, 2015 Hello everyone. It's been a long long time since i've posted on these forums! I'm doing a bit of a clean out before I move interstate in a few months so I've got some parts up for sale All located in South East Brisbane 2001 ADM s15 6 speed gearbox with around 88,000klm. didnt crunch any gears when removed from the car. it has the spline/flange from the tailshaft in the rear end ready for a conversion. Also has all the sensors and wiring plugs. $450 flat top carbies with manifold and all other bits $80 280zx efi set up, removed from running engine last year. includes ecm and wiring loom. $200 260Z boot, heavily rusted around the 4 corners of the glass seal. might be good for repairing? $20 55mm front and rear suspension tubes/knucles/hubs whatever they're called $250 260Z rear LCA's x2 $20 each RH tabco brand rocker panel replacement $120 sold pending payment RH tabco brand dog leg repair panel $60 sold pending payment single belt damper with 36 -1 tooth trigger wheel for aftermarket efi hall sensor $40 sold 260Z engine bay wiring loom, 90% complete, missing fuseable link box and some other bits $50 sold pending pick up Red polyurethane bump stop set and various sway bar bushes $20 sold pending payment 260Z vented bonnet, rust along front edge and around vents $100 sold pending pick up 260Z front LH fender, has rust in bottom corner and has been bogged up at the front from a previous accident but still looks fine and sugar scoop bolts on $50 sold pending pick up LH and RH sugar scoops $20 each sold pending pick up 260Z 2+2 front RH fender, has been cut up a bit for metal sections. FREE to anyone that can use it prefer pick up or can meet up in brisbane somewhere. I can post some stuff but the bigger stuff if you want posted will be done through pack n send regards Justin Quote
juz0 Posted March 3, 2015 Author Posted March 3, 2015 Also have front and rear suspension tubes ready to be cut up for coil over conversion $300 2x Factory rear LCA's $20 each Quote
ackent1 Posted March 3, 2015 Posted March 3, 2015 I will take the dogleg repiar section and the bump stop set. Postage required as I am in melbourne. pm me total cost and bank details Quote
Scoota G Posted March 3, 2015 Posted March 3, 2015 Bags 2nd dibs on bonnet after scootar. Can pick up as in south Bris area. Adam was going to come look at it for me but pass it to this man. Quote
Administrators gav240z Posted March 3, 2015 Administrators Posted March 3, 2015 I'm interested in dog leg (if not taken) and rocker panel repair piece for RH sides. Quote
pauly_adams Posted March 3, 2015 Posted March 3, 2015 might be interested in the harmonic balancer, any chance you could give me a rough idea on postage to albury nsw Quote
240ZR Posted March 3, 2015 Posted March 3, 2015 I'll take the HL sugar scoops if u will post them to 2500 NSW. Quote
luvemfast Posted March 5, 2015 Posted March 5, 2015 2001 ADM s15 6 speed gearbox with around 88,000klm. didnt crunch any gears when removed from the car. it has the spline/flange from the tailshaft in the rear end ready for a conversion. Also has all the sensors and wiring plugs. $450 What's involved in the conversion? Does an L series bell housing attach to the front? So just machining to that? And maybe a custom tail shaft? What ratios are they? Quote
dat2kman Posted March 5, 2015 Posted March 5, 2015 What's involved in the conversion? Does an L series bell housing attach to the front? So just machining to that? And maybe a custom tail shaft? What ratios are they? A lot. No Yes Dont bother using First gear, and there are two overdrives! Get yourself a series 2 S14, then a series 1 S14, then any S13. If atmo car, fit the C/R set Quote
juz0 Posted March 5, 2015 Author Posted March 5, 2015 you'd have to get the bellhousing cut and shut. So cut off the original front part of the bellhousing and then welding on the front part of an L series bell housing. I was going to keep it and do this to mine but thats probably never going to happen haha. me and my big plans. you'd then need to fab up a gearbox mount and get a tailshaft made or use the end that comes with the gearbox, welded on to your current tailshaft. There is a thread on this site somewhere with lots of details on whats needed to get the bellhousing done. Just about any machining shop might be able to do it though? 6-speed manual 1st gear ratio 3.626 2nd gear ratio 2.200 3rd gear ratio 1.541 4th gear ratio 1.213 5th gear ratio 1.000 6th gear ratio 0.767 Quote
Triptych Posted March 8, 2015 Posted March 8, 2015 260Z 2+2 front RH fender, has been cut up a bit for metal sections. FREE to anyone that can use it 260Z engine bay wiring loom, 90% complete, missing fuseable link box and some other bits 260Z vented bonnet, rust along front edge and around vents 260Z front LH fender, has rust in bottom corner and has been bogged up at the front from a previous accident but still looks fine and sugar scoop bolts on LH and RH sugar scoops Just to let others know these parts have now been sold and picked up. Quote
Triptych Posted March 29, 2015 Posted March 29, 2015 I forgot about the clutch, Sorry buddy will send you a SMS during the week to sort something out. I will take your 260z as well so you don't have to move it Quote
juz0 Posted March 30, 2015 Author Posted March 30, 2015 thats all good, i'm back out to Moura for work this week and won't be back until the 9th of April. we can work something out The 260 is not for sale! it's so close to being on the road! just needs paint and a tune then good to go! UPDATE!!! also found some headlight buckets $20 a Pair of Bosch H4 headlights that have been modified to have a park bulb in the housing $40 for the pair Quote
Triptych Posted March 30, 2015 Posted March 30, 2015 Haahahaha, did you end up getting it started the other week? Would love to hear it running. Quote
juz0 Posted March 30, 2015 Author Posted March 30, 2015 yes mate it sure is running again. I haven't cleaned out the webers but it clears up after a few mins of running should be fine haha Quote
wings Posted March 30, 2015 Posted March 30, 2015 Hi the 260z boot you refer to is it the rear hatch door and if so is it off a 2seater Craig Quote
zeds4ever Posted March 31, 2015 Posted March 31, 2015 PM sent re: Bosch h/lghts & buckets. Regards: Alan. Quote
zeds4ever Posted April 9, 2015 Posted April 9, 2015 G'day Justin, will take the headlight holders please mate. Can you send approx postage cost to Winmalee Pc #2777 & payment choice. Regards: Alan. Quote
Kirby Posted April 13, 2015 Posted April 13, 2015 Hey Mate, What condition are the rear LCA's in? I am in need of a few spares. I also am chasing a rear spindle/stub axle, any chance you have one that you could split from your rear struts? Quote
peter t Posted April 13, 2015 Posted April 13, 2015 Brother works at Moura, Maybe you know him. David Tronc. Quote
