zeds4ever
  1. If it's worth doing, do it once & do it right . You will be a lot happier by spending the extra cash on the real thing in the long run. " I know from xperience." Regards: Alan.
  2. Read previous post on checking Tacho. Found this the best & quickesr way to test when not installed in car. (1) Obtain four lengths of electrical wire. Better if four different colours. I used Blk/grn/red/blue. (2) Strip a small section of each end of the wire about six to 8 ml should suffice. (3) Connect wires as follow. Black wire from Neg battery terminal & connect other end to black wire situated in white tacho terminal. (4) Green wire from Pos battery terminal & connect other end to green wire ,situated also in white terminal. (5) Where the Igntn wire connects to the + side of the coil discnct this wire & cnct one end of red wire to same, cnct other end of red wire to green & white wire that has small piece of spaghetti tubing attached, situated in white terminal. (Primary wire) (6) Blue wire connects up to +terminal of coil & thence to the green & white wire immediately next to green & white wire that red wire was cnctd to prvsly. You guessed it situated in the white terminal. (Secondary wire) Would point out that car will start even when you reverse the last two procedures ,except Test Tacho won't function. (These wires form a circuit which you must have.) Found it easiest to press ends of wires that hook up to "White trmnl" into the back of same where Tacho wires enter making sure that they make contact with termnl cnctns. Be sure that Tacho is in a safe postn .I sat mine on a piece of cloth on bonnet so that I could check it against in car unit. Hope this clarify's everything OK for everyone. Regards: Alan.
  3. Don't know if youv'e already done it but make sure you empty the fuel tank of all fuel & clear out any fuel that may be left in your fuel lines. Made the mistake of not doing this myself & because I let the car sit for a few years the bloody fuel lines rusted out from the inside in the shape of very small & hard to see pit holes. Only found out when I tried to start car & the pressure of pump dumped fuel out from said holes. Nearly crapped myself. Could have blown my Baby up. Regards: Alan.
  4. By the way you will need a elctrnc or similar type coil to match your dizzy. 260Z coil not suitable. Regards: Alan.
  5. Any body heading from or thru Mont Albert Nrth " Bigfella's" place across to Whittington near East Geelong. Need a Tow bar to be transported. A small supply of Stubbies for the parched victim will be awaiting them at the final destination. No rush, whenever will do . Regards: Alan.
  6. Thanks Lynton already noted that one but it would appear that they are only into leather goods & not rubber. LOL If I find a location I'll let you know. There is a place in vic that do a lot of resto work but are "EXPENSIVE". Regards. Alan.
  7. Leak could also be coming from water heater container unit itself. Had same problem as yours so pulled whole unit out & re soldered it totally all round. Fixed the problem for me. Regards: Alan.
  8. As per heading ,anyone out there know of where I can have this repaired & approximate cost please. Sydney area if possible if not then Vic area. Regards : Alan.
  9. Hey fella's, put donation into Web site OK. So Gav's got enough to keep it going. LOL. Regards: Alan.
  10. No worries mate. Regards: Alan.
  11. Have a good 2nd hand one for $30.oo plus postage. Outer casing included. Regards: Alan
  12. Spotted up here in The Blue Mntns heading up thru Springwood Gt Western hghwy, a radical 240Z/260Z not sure .Deep blue clr big trnsfrmtn all over. With great sound. Looked magic. Regards : Alan.
  13. Thanks for the info mate. PM sent regards sale. Regards: Alan
  14. Hey Fu, whats happening. ?!?!?!?! Regards : Alan.
  15. Pity, got a 260Z housing unit you could have had for nix. Oh well. Regards: Alan.
  16. :-\ G'day Fella's. Found amongst my spare stuff a dash wiring harness,wondering what it's out off. Has three main cnctn trmnals ( Lrge Black/Med white/Med blue). Has ID tag #24013-N3500(6). Any ideas of origin please. Regards : Alan.
  17. Lucky you. Up in the Mountains here all we get is COPS & heaps of traffic, with the occasional speed camera plus the mongrel mobile camera units. Oh well. Regards : Alan'
  18. :-\ Hey John just out of curiosity is yours from a 260Z or a 240Z. I know the shallow unit one I have is out of a 2+2. While the other one was in a 260Z. Regards: Alan.
  19. Hey Fu which fan blade are you after. Have two of them one is shallow dished which retracts fan back from radiator .While the other one is deep dished which projects blades closer to radiator, the blades on this unit have been rounded off on one side. Both are in good shape. Also have a couple of good fan clutch units if your interested. PM me. Regards : Alan.
  20. Hey Fellas how good is this, as you can understand all I'm doing is offering fellow Zdr's the opportunity to obtain the parts they need at Ausie prices. As a result of your help should I buy you a beer when we finally cross paths or should I just make a donation to the site. Quite happy to do both actually. Regards: Alan.
  21. With apologies to Sirpent. To many items to list mate. Recently posted on Ebay: ( Cars,truck parts.) 240/260z Petrol cap_ 240/260Z Plastic Seat brkt covers L&R_ 240/260Z Horn button_260/280Z Arm rests door pulls_260Z 2+2 Door lever covers L&R_240/260/280Z Window winders. Regards: Alan.
  22. Hey Mossy, are 260 compatible, if so can assist you. Regards : Alan
  23. Thanks mate I'll do my best.They say it's hard to teach an old dog new tricks but I'll do my best. Regards: Alan.
  24. Thanks john, pardon my ignorance but how. Please explain & i'll do my best. There all listed in the 240Z/260Z sectn. Cars /trucks/parts. Regards: Alan
