3,086 -
25
Everything posted by d3c0y
Everything is better about the RB crank apart from the cost, but as highlighted previously the difference is insignificant to the rest of the build. Neither does staying with a stock bore in my opinion. Are you planning on driving 300,000km in your stroker zed?
I'm going with 110 Red on this one too. Its a redy orange colour and have seen a few '73s wearing it. Very different to 905 red.
I was thinking of my mate Doug's car but he has TTT camber tops which raise the shock about 10mm apparently. Mine are inverted monotubes at the front so no problems.
Always wanted to do the elusive quad carb on the straight six conversion.
While you are doing the bodywork, check the clearance of your front shock adjusters to the bonnet. You may need to make some modifications.
Who is it? Or does that mean it's me?
The calipers are going to be repainted and i'm tossing up between Brembo stickers or doing up some San Maru heat proof stickers with the logo. And I already have an automatic racecar!
it's a 240Z so it's only got an amp gauge, but like 2000rpm or something from vague memory.
I finally got the brackets made for my front brake kit that I've been talking about for years. 16" Wats barely clear the caliper, but a couple of millimeters is all you need, any more is a waste. Also the rotor combo combined with a 260Z hub means no spacers to clear the calipers like the Z32 upgrade. Now it's finished I want to weigh this setup vs the stock setup. I have done this once before and the weights were pretty close especially for the size! The strut also had a hole drilled in it to fit the clicker extenders for the shocks since they are an inverted monotube. No pulling the suspension apart to adjust the suspension for me. The rears will be next and I'm running a Porsche caliper on the rear too, so I need to figure out the handbrake caliper setup. I ruled out internal drum for two reasons: Weight: can't run a two piece rotor Comlexity and Cost The first step will be to determine the rotor offset and there should be tones more options since i can run a 114.3x4 PCD on the back! I think it all looks pretty good to me. I also bought a new crank pulley for my ATI balancer from SW Motorsport since the standard one is full race and under drives the alternator so much that driving at night with the fans going is a worrying situation. Even driving in the traffic during the day was a bit nervy with twin plate clutch in the car. On one of the few times I drove it, I nearly got stuck on a bridge in traffic due to stalling it while hot a couple of times trying to move in stop go traffic.
I don't think I need pics, there is a very simple answer to this question. You need to buy one in decent condition right now. They will continue to go up You are going to have to spend the time to fully strip the car If you pull it apart you its going to take up 3x the space (i know this because mine's pulled apart) You will loose bits while it's apart (i've been actively working on mine since it got back from the panel shop and this has happened). By the time you get around to working on it, it might have developed more rust issues. You can't fix it permanently! Your body job will probably run well over $15k It sounds like this car is going to need to need a lot of other things doing. In short you don't do any sort of decent resto for $30k As a previous owner of both a 260Z 2+2 and a 300ZX twin turbo the 240Z is the pick and maybe the answer is to sell all 3 and have one good 240Z that you can actually enjoy now.
Yesss now i can buy that 275 GTB i have been holding out for with the drop in price that's coming. haha This article is stating the obvious for me. The people that aren't the 'real' enthusiasts are getting out and trying to make their money before it goes too far wayward. Car share market stuff right there, which a lot of people were taking advantage of while other types of investments weren't returning. I don't think this effects the price of 240Zs and especially Australian ones.
I vote to ban Gav for being a prick.
That's not an Subaru diff though.
I thought you had a SureTrak? For the record Suretraks have smooth carriers and mechanical are cast from memory.
With the 0.75 5th you can run a nice diff ratio and still be able to drive it on the highway though.
Lol yeah i'm sure that it's whopping 150hp would be amazing. Like an L28 but with less torque and 4 cyl sound... I'm sure it's not even in the same realm as your FJ24 Jason.
If it's a 4.11 and 2.0L car it will be an R160 and not from an STi. To my knowledge Subaru didn't use 4.11 R180s. The type of LSD center you want depends on what you are using the car for. All three will work and be better than an open diff especially on the street, but I would probably rate Mechanical, Torsen, SureTrak with mechanical being the best if you are going to the race track. Torsens only come in 3.5 ratio and are found in the GDG hatchback shape, but i think that is a bad ratio for any zed. 3.9 ratio Suretracks are the easiest to find and came in all GDB - GDC models excluding the STi Spec-C models which came with 3.9 ratio mechanical diffs. If you want an R180 LSD this is the easiest way to do it.
Just pull the hat off and the ratio is stamped on the crown wheel. Also you can see what sort of LSD is in the diff by looking at the carrier. All STi rear diffs are LSD but there are three different types. I would be guessing it's a 3.9 with a suretrak centre (torque sensing).
It's not a Kameari, this one attaches to the factory valance and the Kameari replaces it. They are a different shape too. Ben/Otomoto posted a pic of the black Kameari type 1 higher up on the last page and it's the most popular one.
Wow that's really interesting that it will totally jam the selector fork. I take it this fork is submerged and there for the oil can't just drain away? I wonder how long it took the factory to figure out it needed to make that modification when they were testing it haha.
That really makes me want to spend the money on Fairlady 240Z badges... not so much on rear bumper rubbers all the way round...
Secret spoiler club, we would tell you but it's 1000:1 that someone else would want one... haha
In reference to your earlier post (and I'm no expert), but pretty sure you are loosing some HP through the lack of volume in that airbox with 44s behind it. In addition to that your really short velocity stacks will be costing your some torque.
