3,086 -
25
Everything posted by d3c0y
240Z Stainless Center Console, Because Race Car...
d3c0y replied to Dionysus's topic in Parts and Tools for Sale
Why does a race car need a centre console? -
Totally agree! No covers, no g.
Who want's to buy my 240Z-G replica for $110k when it's done? I'll take the deposit now!
[Qld] Genuine Nissan Cowling Panel Locators
d3c0y replied to d3c0y's topic in Parts and Tools for Sale
Should be, if they fall through i will let you know. No problems, part number is 66815-E4100. -
[How To] Install headlight covers in fiberglass headlight buckets! Not something that everyone does to their Z, but for those that want headlight covers specifically in fiberglass headlight buckets, I've come up with what i regard to be a pretty good way to mount them (will work for metal too though). Generally they are just screwed in with self-tapping screws and that's not the best for us running FRP buckets as over time the vibrations will loosen the screws. Less than ideal for us running a G-Nose, early 240Z OEM or aftermarket buckets especially when exposed to the high speeds encountered on a race track. My solution to the problem is to use rubber wellnuts, the same things used to secure windscreens to ABS plastic fairings on motorcycles. As you tighten the bolt, the rubber shaft bulges out much like a pop rivet, providing you with a secure fastening that is insulated to vibration. They are cheap and easy to get and take metric counter-sunk machine screws which fit perfectly into the recesses of the headlight cover trim. To do this installation on a G-Nose, you will need 12 x M4 x 12mm Wellnuts and 12 x M4 x 24mm counter-sunk Allen machine screws in your desired finish - I used stainless steel as they will be exposed to the weather. I can't help out too with an exact positions for the covers on the G, as I just based mine on photos of cars that I thought looked right. If anyone wants I am happy to do up a diagram of where mine are mounted. There are a few tricks to getting them right, but the covers will generally sit where they want to: 1. The covers will sit differently when you put the trim on them and I recommend you mark the holes without the trim towards the outside of the holes. Then re-fit the trim and check that you are close to your marks. 2. Check for gaps, especially around the rear upper corner. If you don't push down on the cover when you are marking the holes and stretch the cover out, it won't hug the headlight bucket and you will end up with gaps under the seal which will suck dirt in and put dirt on the inside of the cover. 3. Make sure the front of the trim doesn't sit too low. One of the biggest things to worry about when positioning the covers to drill the holes is to make sure the hole doesn't hang down and contact the bumper. I ended up doing pretty much everything I could to push the front of the cover as high as I could (while maintaining the natural fit) to keep the trim high and even then its only 1mm off the bumper. 4. Start with the smallest drill bit you have and step up in small increments. I like a really snug fit for any sort of rivet/rivnut/wellnut and found that i could fit the M4 with a 7.5mm drill bit (it's 8mm wide). I started out with a 3mm then went 4mm and 5mm before switching to 0.5mm increments for the final step ups. Make sure you put some sort of masking tape over the holes before you drill them and and put a fresh bit of tape down each time if you have already painted your buckets. This minimizes the paint from chipping while drilling. A mistake i made was not to drill these holes before painting them! 5. Be super careful drilling the holes on the side of the bucket! There is not a lot of space between the side of the bucket and where the inside curve comes down behind it. I actually had the last drill bit pull through the hole and contact the inside curve of the bucket and put a hole in it! You will also need to shorten one of the screws about 8mm for the same reason, I just cut the end off one with a hacksaw. Make sure you thread a nut on before you cut it! Hopefully after all that you will end up with something like the pictures.
I've managed to score a couple of interesting Z parts recently that I am fixing up for sale that i thought i would share. First item is a "Calendar" clock made by Citizen, which was a factory option for RS30/S31/260Z/280Z series 1 models ('74 - '76). It uses a quartz movement unlike the electric motor driven motor in the 240z and is way more reliable. This particular one looked like it had taken a hit and the pendulum shaft had fallen off the locating screw and the electromagnet coil had been bent against the magnets. Luckily this was a pretty simple fix and the clock is ticking away again. It has had the light cut off the plug for some reason so i'm going to reattach one from a spare to complete it. Shoot us a message if you are interested in buying it. Item number 2 is an Nissan Type B works rear spoiler I bought off a guy that pulled it off a car he is restoring. From the back story i got it's probably from the 80s and half a chance at being a somewhat genuine item. But as always who knows? It will cop a sand, fill in the rivet holes and a prime.
Lol obviously, why do you want it? Just buy mine, they were $40 and i had to wait 3 weeks and ride to the Nissan dealer and pick them up. -
Needed a set for my car but the Nissan dealer would only sell me 10, so I have the other 5 for sale. $25 plus post.
Supercheap Auto Chassis Stands - Product Recall
d3c0y replied to PB260Z's topic in Tools and Equipment
I have these stands, used them for years and have my race car on them right now. Would be interesting to hear why they dont comply with the Australian standard. All their new stands have two pins in them could be something as simple as that. Maybe someone used the in a silly manor and common sense didn't prevail. I have nothing but good things to say generally about my chinese tools and their low price enables me to have a variety that i couldnt afford in name brands... -
Fullnoise 260Z 2+2 Rb26/34 Na Build
d3c0y replied to Fullnoisezed's topic in Members Project(s) Journal
There was a guy over on Hybridz grafting JZZ30 soarer suspension front and rear. Way better than either Z32 or S13. -
Shame they weren't circuit raced more in Australia
That will be an impressive engine, the Greddy car only managed 220rwhp on a US dyno... -
Good luck with the build! You didn't happen to buy that blue 2+2 that's been for sale on car sales for ages with the big guards? Interested to see what you can get out of the engine combination. Benchmark is 360hp at the crank for 3.35L 2 valve L6. How long until the motor is bolted together? -
Maybe we are waiting for the film to develop from the kodak disposable?
Seriously Richard, where the hell are the pictures???!!?!?
Cant wait to see it at WTAC this year. Get a chance to open up that motor!
Hate the interior but a cheap way to put 400hp under the bonnet. It would handle better too.
Bolts in, it's a long nose R180.
SWM are making the stub axles that go in the diff now to use the stock half shafts. So no USD and shipping problems there.
Subaru WRX STi diffs come in 3.9 and 4.44 which are factory LSDs. They are probably the best options for ease of procurement.
Sell them on Aus300ZX.com you will probably sell them easier there.
Me And My 73' 240Z
d3c0y replied to VintageNissanEnthusiast's topic in Introductions and Forum Etiquette
Man I love that half cage, looks so tough! It looks like a nice car. Just stick the L24 on a pallet and ship it back. -
I find it funny when you look at what popular parts are these days and generally it's not always what looks the best or give the best performance but is the rarest and will give the car the most kudos. Not that i am above this of course.
I really hate those Konig rewinds, it's like they didnt know if they were copying a superlite or a watanabe so they did a bit of both.
240Zs came with sealed beams.
